tiantian815 发表于 2013-10-28 08:46
到现在我还没找出问题出在哪了呢,还是不能正常擦除,完全没有头绪,不知道怎么修改 ...
首先,要相信经过量产的芯片不会有这么低级的BUG! :)
其次,要多看数据表,往往解决后才发现原来这么简单!
===================欢乐分割线==================
1、认真查看看数据手册的312页起的相关章节,然后用万用表检查单片机的供电是否大于4.1V, 否则会无效。
2、使用STC-ISP V6.59 的【范例程序】标签,导出STC11F的EEPROM程序(见下)认真看看,确保每句都知道是什么意思和作用。该程序使用了P1口连接的LED作为指示用,你也可以加上,就很直观了。
重新使用KEIL 建立工程,编译烧写,一定可以成功的(当然必要时需换另一片芯片试试,排除损坏的可能)。
官方C源程序:
/* --- STC MCU Limited ---------------------------------------------*/
/* --- STC10/11xx Series MCU ISP/IAP/EEPROM Demo -------------------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-755-82905966 ----------------------------------------*/
/* --- Tel: 86-755-82948412 ----------------------------------------*/
/* --- Web: www.**.com -----------------------------------------*/
/* If you want to use the program or the program referenced in the */
/* article, please specify in which data and procedures from STC */
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/*Declare SFR associated with the IAP */
sfr IAP_DATA = 0xC2; //Flash data register
sfr IAP_ADDRH = 0xC3; //Flash address HIGH
sfr IAP_ADDRL = 0xC4; //Flash address LOW
sfr IAP_CMD = 0xC5; //Flash command register
sfr IAP_TRIG = 0xC6; //Flash command trigger
sfr IAP_CONTR = 0xC7; //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE 0 //Stand-By
#define CMD_READ 1 //Byte-Read
#define CMD_PROGRAM 2 //Byte-Program
#define CMD_ERASE 3 //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
//#define ENABLE_IAP 0x80 //if SYSCLK<30MHz
//#define ENABLE_IAP 0x81 //if SYSCLK<24MHz
#define ENABLE_IAP 0x82 //if SYSCLK<20MHz
//#define ENABLE_IAP 0x83 //if SYSCLK<12MHz
//#define ENABLE_IAP 0x84 //if SYSCLK<6MHz
//#define ENABLE_IAP 0x85 //if SYSCLK<3MHz
//#define ENABLE_IAP 0x86 //if SYSCLK<2MHz
//#define ENABLE_IAP 0x87 //if SYSCLK<1MHz
//Start address for STC10/11xx EEPROM
#define IAP_ADDRESS 0x0000
void Delay(BYTE n);
void IapIdle();
BYTE IapReadByte(WORD addr);
void IapProgramByte(WORD addr, BYTE dat);
void IapEraseSector(WORD addr);
void main()
WORD i;
P1 = 0xfe; //1111,1110 System Reset OK
Delay(10); //Delay
IapEraseSector(IAP_ADDRESS); //Erase current sector
for (i=0; i<512; i++) //Check whether all sector data is FF
if (IapReadByte(IAP_ADDRESS+i) != 0xff)
goto Error; //If error, break
P1 = 0xfc; //1111,1100 Erase successful
Delay(10); //Delay
for (i=0; i<512; i++) //Program 512 bytes data into data flash
IapProgramByte(IAP_ADDRESS+i, (BYTE)i);
P1 = 0xf8; //1111,1000 Program successful
Delay(10); //Delay
for (i=0; i<512; i++) //Verify 512 bytes data
if (IapReadByte(IAP_ADDRESS+i) != (BYTE)i)
P1 = 0xf0; //1111,0000 Verify successful
while (1);
Error:
P1 &= 0x7f; //0xxx,xxxx IAP operation fail
while (1);
Software delay function
void Delay(BYTE n)
WORD x;
while (n--)
x = 0;
while (++x);
Disable ISP/IAP/EEPROM function
Make MCU in a safe state
void IapIdle()
IAP_CONTR = 0; //Close IAP function
IAP_CMD = 0; //Clear command to standby
IAP_TRIG = 0; //Clear trigger register
IAP_ADDRH = 0x80; //Data ptr point to non-EEPROM area
IAP_ADDRL = 0; //Clear IAP address to prevent misuse
Read one byte from ISP/IAP/EEPROM area
Input: addr (ISP/IAP/EEPROM address)
Output:Flash data
BYTE dat; //Data buffer
IAP_CONTR = ENABLE_IAP; //Open IAP function, and set wait time
IAP_CMD = CMD_READ; //Set ISP/IAP/EEPROM READ command
IAP_ADDRL = addr; //Set ISP/IAP/EEPROM address low
IAP_ADDRH = addr >> 8; //Set ISP/IAP/EEPROM address high
IAP_TRIG = 0x5a; //Send trigger command1 (0x5a)
IAP_TRIG = 0xa5; //Send trigger command2 (0xa5)
_nop_(); //MCU will hold here until ISP/IAP/EEPROM operation complete
dat = IAP_DATA; //Read ISP/IAP/EEPROM data
IapIdle(); //Close ISP/IAP/EEPROM function
return dat; //Return Flash data
Program one byte to ISP/IAP/EEPROM area
dat (ISP/IAP/EEPROM data)
Output:-
IAP_CMD = CMD_PROGRAM; //Set ISP/IAP/EEPROM PROGRAM command
IAP_DATA = dat; //Write ISP/IAP/EEPROM data
IapIdle();
Erase one sector area
Output:-
IAP_CMD = CMD_ERASE; //Set ISP/IAP/EEPROM ERASE command
IapIdle();
BTW: STC单片机的FLASH 官方保证10W次刷写,我使用程序破坏性实际测试过多个芯片,日常环境下基本都有60W次刷写才出现有字节的某位由0变不回1。
(92)
