3.2寸TFT彩屏初始化代码 控制器1289
2465|2
 楼主| fmzhangpei241 发表于 2013-10-27 10:25 | 显示全部楼层 |阅读模式
u16 BACK_COLOR, POINT_COLOR;   //背景色,画笔色
#ifdef  Bus_16    //条件编译-16位数据模式
void LCD_Writ_Bus(char VH,char VL)   //并行数据写入函数
    LCD_DataPortH=VH;
        LCD_DataPortL=VL;
        LCD_WR=0;
        LCD_WR=1;
#else                        //条件编译-8位数据模式
    LCD_DataPortH=VH;
           LCD_WR=0;
        LCD_WR=1;
        LCD_DataPortH=VL;
        LCD_WR=0;
        LCD_WR=1;
#endif
void LCD_WR_DATA8(char VH,char VL) //发送数据-8位参数
    LCD_RS=1;
        LCD_Writ_Bus(VH,VL);
void LCD_WR_DATA(int da)
    LCD_RS=1;
        LCD_Writ_Bus(da>>8,da);
void LCD_WR_REG(int da)
    LCD_RS=0;
void LCD_WR_REG_DATA(int reg,int da)
    LCD_WR_REG(reg);
        LCD_WR_DATA(da);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
        LCD_WR_REG_DATA(0x0044,(x2<<8)+x1);
        LCD_WR_REG_DATA(0x0045,y1);
        LCD_WR_REG_DATA(0x0046,y2);
        LCD_WR_REG_DATA(0x004e,x1);
        LCD_WR_REG_DATA(0x004f,y1);
    LCD_WR_REG(0x0022);
void Lcd_Init(void)
//调用一次这些函数,免得编译的时候提示警告
           LCD_CS =1;
        if(LCD_CS==0)
           LCD_WR_REG_DATA(0,0);
           LCD_ShowString(0,0," ");
           LCD_ShowNum(0,0,0,0);
           LCD_Show2Num(0,0,0,0);
           LCD_DrawPoint_big(0,0);
           LCD_DrawRectangle(0,0,0,0);
           Draw_Circle(0,0,0);
    LCD_REST=1;
    delayms(5);
        LCD_REST=0;
        delayms(5);
        LCD_REST=1;
        LCD_CS=1;
        LCD_RD=1;
        LCD_WR=1;
        delayms(5);
        LCD_CS =0;  //打开片选使能
        LCD_WR_REG_DATA(0x0000,0x0001);    delayms(1);  //打开晶振
    LCD_WR_REG_DATA(0x0003,0xA8A4);    delayms(1);   //0xA8A4
    LCD_WR_REG_DATA(0x000C,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x000D,0x080C);    delayms(1);
    LCD_WR_REG_DATA(0x000E,0x2B00);    delayms(1);
    LCD_WR_REG_DATA(0x001E,0x00B7);    delayms(1);
    LCD_WR_REG_DATA(0x0001,0x2B3F);    delayms(1);   //驱动输出控制320*240  0x6B3F
    LCD_WR_REG_DATA(0x0002,0x0600);    delayms(1);
    LCD_WR_REG_DATA(0x0010,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0011,0x6070);    delayms(1);        //0x4030           //定义数据格式  16位色
    LCD_WR_REG_DATA(0x0005,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0006,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0016,0xEF1C);    delayms(1);
    LCD_WR_REG_DATA(0x0017,0x0003);    delayms(1);
    LCD_WR_REG_DATA(0x0007,0x0233);    delayms(1);        //0x0233
    LCD_WR_REG_DATA(0x000B,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x000F,0x0000);    delayms(1);        //扫描开始地址
    LCD_WR_REG_DATA(0x0041,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0042,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0048,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0049,0x013F);    delayms(1);
    LCD_WR_REG_DATA(0x004A,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x004B,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0044,0xEF00);    delayms(1);
    LCD_WR_REG_DATA(0x0045,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0046,0x013F);    delayms(1);
    LCD_WR_REG_DATA(0x0030,0x0707);    delayms(1);
    LCD_WR_REG_DATA(0x0031,0x0204);    delayms(1);
    LCD_WR_REG_DATA(0x0032,0x0204);    delayms(1);
    LCD_WR_REG_DATA(0x0033,0x0502);    delayms(1);
    LCD_WR_REG_DATA(0x0034,0x0507);    delayms(1);
    LCD_WR_REG_DATA(0x0035,0x0204);    delayms(1);
    LCD_WR_REG_DATA(0x0036,0x0204);    delayms(1);
    LCD_WR_REG_DATA(0x0037,0x0502);    delayms(1);
    LCD_WR_REG_DATA(0x003A,0x0302);    delayms(1);
    LCD_WR_REG_DATA(0x003B,0x0302);    delayms(1);
    LCD_WR_REG_DATA(0x0023,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0024,0x0000);    delayms(1);
    LCD_WR_REG_DATA(0x0025,0x8000);    delayms(1);
    LCD_WR_REG_DATA(0x004f,0);        //行首址0
    LCD_WR_REG_DATA(0x004e,0);        //列首址0
        LCD_WR_REG(0x0022);
//清屏函数
//Color:要清屏的填充色
void LCD_Clear(u16 Color)
        u8 VH,VL;
        u16 i,j;
        VH=Color>>8;
        VL=Color;
        Address_set(0,0,LCD_W-1,LCD_H-1);
    for(i=0;i<LCD_W;i++)
          for (j=0;j<LCD_H;j++)
                 LCD_WR_DATA8(VH,VL);
//在指定位置显示一个汉字(32*33大小)
//dcolor为内容颜色,gbcolor为背静颜色
void showhanzi(unsigned int x,unsigned int y,unsigned char index)
        unsigned char i,j;
        unsigned char *temp=hanzi;
    Address_set(x,y,x+31,y+31); //设置区域
        temp+=index*128;
        for(j=0;j<128;j++)
                for(i=0;i<8;i++)
                         if((*temp&(1<<i))!=0)
                                LCD_WR_DATA(POINT_COLOR);
                        else
                                LCD_WR_DATA(BACK_COLOR);
                temp++;
//画点
//POINT_COLOR:此点的颜色
void LCD_DrawPoint(u16 x,u16 y)
        Address_set(x,y,x,y);//设置光标位置
//画一个大点
//POINT_COLOR:此点的颜色
void LCD_DrawPoint_big(u16 x,u16 y)
        LCD_Fill(x-1,y-1,x+1,y+1,POINT_COLOR);
//在指定区域内填充指定颜色
//区域大小:
//  (xend-xsta)*(yend-ysta)
void LCD_Fill(u16 xsta,u16 ysta,u16 xend,u16 yend,u16 color)
        u16 i,j;
        Address_set(xsta,ysta,xend,yend);      //设置光标位置
        for(i=ysta;i<=yend;i++)
                for(j=xsta;j<=xend;j++)LCD_WR_DATA(color);//设置光标位置
//画线
//x1,y1:起点坐标
//x2,y2:终点坐标
void LCD_DrawLine(u16 x1, u16 y1, u16 x2, u16 y2)
        u16 t;
        int xerr=0,yerr=0,delta_x,delta_y,distance;
        int incx,incy,uRow,uCol;
        delta_x=x2-x1; //计算坐标增量
        delta_y=y2-y1;
        uRow=x1;
        uCol=y1;
        if(delta_x>0)incx=1; //设置单步方向
        else if(delta_x==0)incx=0;//垂直线
        else {incx=-1;delta_x=-delta_x;}
        if(delta_y>0)incy=1;
        else if(delta_y==0)incy=0;//水平线
        else{incy=-1;delta_y=-delta_y;}
        if( delta_x>delta_y)distance=delta_x; //选取基本增量坐标轴
        else distance=delta_y;
        for(t=0;t<=distance+1;t++ )//画线输出
                LCD_DrawPoint(uRow,uCol);//画点
                xerr+=delta_x ;
                yerr+=delta_y ;
                if(xerr>distance)
                        xerr-=distance;
                        uRow+=incx;
                if(yerr>distance)
                        yerr-=distance;
                        uCol+=incy;
//画矩形
void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2)
        LCD_DrawLine(x1,y1,x2,y1);
        LCD_DrawLine(x1,y1,x1,y2);
        LCD_DrawLine(x1,y2,x2,y2);
        LCD_DrawLine(x2,y1,x2,y2);
//在指定位置画一个指定大小的圆
//(x,y):中心点
//r    :半径
void Draw_Circle(u16 x0,u16 y0,u8 r)
        int a,b;
        int di;
        a=0;b=r;
        di=3-(r<<1);             //判断下个点位置的标志
        while(a<=b)
                LCD_DrawPoint(x0-b,y0-a);             //3
                LCD_DrawPoint(x0+b,y0-a);             //0
                LCD_DrawPoint(x0-a,y0+b);             //1
                LCD_DrawPoint(x0-b,y0-a);             //7
                LCD_DrawPoint(x0-a,y0-b);             //2
                LCD_DrawPoint(x0+b,y0+a);             //4
                LCD_DrawPoint(x0+a,y0-b);             //5
                LCD_DrawPoint(x0+a,y0+b);             //6
                LCD_DrawPoint(x0-b,y0+a);
                a++;
                //使用Bresenham算法画圆
                if(di<0)di +=4*a+6;
                else
                        di+=10+4*(a-b);
                        b--;
//在指定位置显示一个字符
//num:要显示的字符:" "--->"~"
//mode:叠加方式(1)还是非叠加方式(0)
//在指定位置显示一个字符
void LCD_ShowChar(u16 x,u16 y,u8 num,u8 mode)
    u8 temp;
    u8 pos,t;
        u16 x0=x;
        u16 colortemp=POINT_COLOR;
    if(x>LCD_W-16||y>LCD_H-16)return;
        //设置窗口
        num=num-' ';//得到偏移后的值
        Address_set(x,y,x+8-1,y+16-1);      //设置光标位置
        if(!mode) //非叠加方式
                for(pos=0;pos<16;pos++)
                        temp=asc2_1608[(u16)num*16+pos];                 //调用1608字体
                        for(t=0;t<8;t++)
                        if(temp&0x01)POINT_COLOR=colortemp;
                                else POINT_COLOR=BACK_COLOR;
                                temp>>=1;
                                x++;
                        x=x0;
                        y++;
        }else//叠加方式
                        for(t=0;t<8;t++)
                        if(temp&0x01)LCD_DrawPoint(x+t,y+pos);//画一个点
                        temp>>=1;
//m^n函数
u32 mypow(u8 m,u8 n)
        u32 result=1;
        while(n--)result*=m;
        return result;
//显示2个数字
//x,y :起点坐标
//len :数字的位数
//color:颜色
//num:数值(0~4294967295);
void LCD_ShowNum(u16 x,u16 y,u32 num,u8 len)
        u8 t,temp;
        u8 enshow=0;
        num=(u16)num;
        for(t=0;t<len;t++)
                temp=(num/mypow(10,len-t-1))%10;
                if(enshow==0&&t<(len-1))
                        if(temp==0)
                                LCD_ShowChar(x+8*t,y,' ',0);
                                continue;
                        }else enshow=1;
                 LCD_ShowChar(x+8*t,y,temp+48,0);
//显示2个数字
//x,y:起点坐标
//num:数值(0~99);
void LCD_Show2Num(u16 x,u16 y,u16 num,u8 len)
        u8 t,temp;
        for(t=0;t<len;t++)
                 LCD_ShowChar(x+8*t,y,temp+'0',0);
//显示字符串
//x,y:起点坐标
//*p:字符串起始地址
//用16字体
void LCD_ShowString(u16 x,u16 y,const u8 *p)
    while(*p!='\0')
        if(x>LCD_W-16){x=0;y+=16;}
        if(y>LCD_H-16){y=x=0;LCD_Clear(RED);}
        LCD_ShowChar(x,y,*p,0);
        x+=8;
        p++;
dirtwillfly 发表于 2013-10-27 14:33 | 显示全部楼层
好长的代码,谢谢分享
dongranmengming 发表于 2013-12-1 15:40 | 显示全部楼层
请问怎么改为8bit呢   硬件怎么改
个人签名:51/avr/stm32驱动TFT彩屏。http://tftmcu.taobao.com/
26
