DSP中的键盘控制程序的算法(5509)
1551|5
 楼主| huangfeng33 发表于 2013-11-25 09:59 | 显示全部楼层 |阅读模式
DSP中的键盘控制程序的算法,基于TI公司的5509这款DSP芯片
clude "scancode.h"
#define REGISTERCLKMD (*(unsigned int *)0x58)
ioport unsigned int port8000;
ioport unsigned int port8001;
ioport unsigned int port8002;
ioport unsigned int port8005;
ioport unsigned int port8007;
void Delay(unsigned int nTime);  // 延时子程序
void RefreshLEDArray();   // 刷新显示
void SetLEDArray(int nNumber);  // 修改显示内容
char ConvertScanToChar(unsigned char cScanCode); // 将键盘扫描码转换为字符
unsigned int nScreenBuffer[1024];
unsigned char ledbuf[8],ledx[8];
unsigned char ledkey[10][8]=
{0x00,0x00,0x7C,0x82,0x82,0x82,0x7C,0x00},
{0x00,0x00,0x00,0x84,0xFE,0x80,0x00,0x00}, //1
{0x00,0x00,0x84,0xC2,0xA2,0x92,0x8C,0x00}, //2
{0x00,0x00,0x44,0x92,0x92,0x92,0x6C,0x00},
{0x00,0x00,0x30,0x28,0x24,0xFE,0x20,0x00},
{0x00,0x00,0x4E,0x92,0x92,0x92,0x62,0x00},
{0x00,0x00,0x7C,0x92,0x92,0x92,0x64,0x00},
{0x00,0x00,0x02,0xC2,0x32,0x0A,0x06,0x00},
{0x00,0x00,0x6C,0x92,0x92,0x92,0x6C,0x00},
{0x00,0x00,0x4C,0x92,0x92,0x92,0x7C,0x00}
unsigned int uPort8000;
main()
int nCount,nCursorCount;
unsigned int nScanCode,nKeyCode;
unsigned char cKey;
REGISTERCLKMD=0;
port8000=0;  // 初始化ICETEK-CTR
port8000=0x80;
port8000=0;
port8007=0;   // 关闭东西方向的交通灯
port8007=0x40; // 关闭南北方向的交通灯
uPort8000=port8002;  // 清键盘缓冲区
for ( nCount=0;nCount<8;nCount++ )
  ledbuf[nCount]=0x0ff;  // 显示为空白
  ledx[nCount]=(nCount<<4); // 生成显示列控制字
RefreshLEDArray();
nCount=nCursorCount=0;
for (;;)
  nScanCode=port8001;
  nScanCode&=0x0ff;
  uPort8000=port8002;
  if ( nScanCode!=0 && nScanCode!=0x0ff )
   if ( nScanCode==SCANCODE_Enter ) break;
   else
    cKey=ConvertScanToChar(nScanCode);
    if ( cKey!=0 )
     nKeyCode=cKey-'0';
     SetLEDArray(nKeyCode);
  Delay(16);
  nCursorCount++; nCursorCount%=4;
  if ( nCursorCount==0 ) ledbuf[7]^=0x80;
RefreshLEDArray();
exit(0);
void Delay(unsigned int nDelay)
int ii,jj,kk=0;
for ( ii=0;ii<nDelay;ii++ )
  for ( jj=0;jj<64;jj++ )
   RefreshLEDArray();
   kk++;
int i;
for ( i=0;i<8;i++ )
  port8000=ledx;
  port8005=ledbuf;
int i;
for ( i=0;i<8;i++ )
  ledbuf=~ledkey[nNumber][7-i];
char cReturn;
cReturn=0;
switch ( cScanCode )
  case SCANCODE_0: cReturn='0'; break;
  case SCANCODE_1: cReturn='1'; break;
  case SCANCODE_2: cReturn='2'; break;
  case SCANCODE_3: cReturn='3'; break;
  case SCANCODE_4: cReturn='4'; break;
  case SCANCODE_5: cReturn='5'; break;
  case SCANCODE_6: cReturn='6'; break;
  case SCANCODE_7: cReturn='7'; break;
  case SCANCODE_8: cReturn='8'; break;
  case SCANCODE_9: cReturn='9'; break;
return cReturn;
评分
参与人数 1威望 +2 收起 理由
zhangmangui + 2 赞一个!
查看全部评分
zhangmangui 发表于 2013-11-25 10:57 | 显示全部楼层
键盘应该是外扩到CPLD上的?
谢谢分享
vivilzb1985 发表于 2013-11-25 20:49 | 显示全部楼层
键盘扫描处理算法的,也是很不错的,这个应用是非常广泛的
G21372 发表于 2013-11-25 22:45 | 显示全部楼层
谢谢楼主的分享 学习了
拿起书本 发表于 2014-1-24 21:41 | 显示全部楼层
实现简洁高效的键盘处理对于提高单片机系统的可靠性及速度有重要意义。学习!
firstblood 发表于 2014-1-26 14:48 | 显示全部楼层
先帮着顶一下的了,这个讨论还是蛮重要的
