【分享】+MSP430按键扫描
5485|43
 楼主| zxf0168 发表于 2013-12-29 21:42 | 显示全部楼层 |阅读模式
include <msp430x14x.h>
void Init_Port(void)
P1口所有的管脚在初始化的时候设置为输入方式
    P1DIR = 0;
P1口所有的管脚设置为一般I/O
    P1SEL = 0;
P1.4 P1.5 P1.6 P1.7设置为输出方向
    P1DIR |= BIT4;
    P1DIR |= BIT5;
P1DIR |= BIT6;
    P1DIR |= BIT7;
//先输出低电平
P1OUT = 0x00;
// 将中断寄存器清零
    P1IE = 0;
    P1IES = 0;
    P1IFG = 0;
打开管脚的中断功能
对应的管脚由高到低电平跳变使相应的标志置位
    P1IE |= BIT0;
    P1IES |= BIT0;
    P1IE |= BIT1;
    P1IES |= BIT1;
P1IE |= BIT2;
    P1IES |= BIT2;
    P1IE |= BIT3;
    P1IES |= BIT3;
_EINT();//
打开中断
    return;
void Delay(void)
int i;
for(i = 100;i--;i > 0) ;//
延时一点时间
int KeyProcess(void)
    int nP10,nP11,nP12,nP13;
int nRes = 0;
//P1.4
输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 13;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 14;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 15;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 16;
//P1.5
输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 9;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 10;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 11;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 12;
//P1.6
输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 5;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 6;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 7;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 8;
//P1.7
输出低电平
P1OUT &= ~(BIT4);
nP10 = P1IN & BIT0;
if (nP10 == 0) nRes = 1;
nP11 = P1IN & BIT1;
if (nP11 == 0) nRes = 2;
nP12 = P1IN & BIT2;
if (nP12 == 0) nRes = 3;
nP13 = P1IN & BIT3;
if (nP13 == 0) nRes = 4;
P1OUT = 0x00;//恢复以前值。
//读取各个管脚的状态
nP10 = P1IN & BIT0;
nP11 = P1IN & BIT1;
nP12 = P1IN & BIT2;
nP13 = P1IN & BIT3;
for(;;)
  if(nP10 == 1 && nP11 == 1 && nP12 == 1 && nP13 == 1)
等待松开按键
   break;
return nRes;
处理来自端口 1 的中断
interrupt [PORT1_VECTOR] void PORT_ISR(void)
Delay();
KeyProcess();
    if(P1IFG & BIT0)
     P1IFG &= ~(BIT0);//
清除中断标志位
    if(P1IFG & BIT1)
     P1IFG &= ~(BIT1);//
清除中断标志位
    if(P1IFG & BIT2)
     P1IFG &= ~(BIT2);//
清除中断标志位
if(P1IFG & BIT3)
     P1IFG &= ~(BIT3);//
清除中断标志位
void Init_CLK(void)
    unsigned int i;
    BCSCTL1 = 0X00;   //
将寄存器的内容清零
     //XT2
震荡器开启
     //LFTX1
工作在低频模式
     //ACLK
的分频因子为1
    do
IFG1 &= ~OFIFG;                       //
清除OSCFault标志
for (i = 0x20; i > 0; i--);
    while ((IFG1 & OFIFG) == OFIFG);      //
如果OSCFault =1
    BCSCTL2 = 0X00;   //
将寄存器的内容清零
    BCSCTL2 += SELM1;  //MCLK
的时钟源为TX2CLK,分频因子为1
    BCSCTL2 += SELS;  //SMCLK
的时钟源为TX2CLK,分频因子为
 楼主| zxf0168 发表于 2013-12-29 21:45 | 显示全部楼层
u880 发表于 2013-12-29 21:55 | 显示全部楼层
消灭零回复
huigoushang 发表于 2013-12-29 22:04 | 显示全部楼层
以后有时间尝试一下 楼主辛苦了
 楼主| zxf0168 发表于 2013-12-29 22:34 | 显示全部楼层
消灭零回复
:(零回复竟然被你消灭了
 楼主| zxf0168 发表于 2013-12-29 22:35 | 显示全部楼层
以后有时间尝试一下 楼主辛苦了
恩 啊,其实这不是我的,分享一下吧
firstblood 发表于 2013-12-29 23:53 | 显示全部楼层
按键扫描的话主要需要注意按键的抖动处理的就可以拉
firstblood 发表于 2013-12-29 23:54 | 显示全部楼层
一般除开在硬件上选取非常好的按键硬件外,最常用的软件方面的防抖动措施就是延时处理的
该延时时间的需要合理就可以启动防抖动的效果的
yangguangaisha 发表于 2013-12-30 13:19 | 显示全部楼层
了解了 马上要接手这里
gexingyouxian 发表于 2013-12-30 13:21 | 显示全部楼层
额 看得不是特别懂 收藏了 慢慢研究
acer4736 发表于 2013-12-30 13:30 | 显示全部楼层
学习一下 楼主码字不容易 顶了
jinpaidianzi 发表于 2013-12-30 13:32 | 显示全部楼层
楼上的总结的很好啊 互相学习了
小营七郎 发表于 2013-12-30 15:56 | 显示全部楼层
动作很迅速,这么快就赶上了。https://bbs.21ic.com/icview-585059-1-1.html
胡斯哲 发表于 2013-12-30 20:35 | 显示全部楼层
这个程序也太长了吧
 楼主| zxf0168 发表于 2013-12-30 20:39 | 显示全部楼层
恩,消除抖动嘛
 楼主| zxf0168 发表于 2013-12-30 20:41 | 显示全部楼层
一般除开在硬件上选取非常好的按键硬件外,最常用的软件方面的防抖动措施就是延时处理的 ...
恩,确实是这样,很有经验啊
 楼主| zxf0168 发表于 2013-12-30 20:42 | 显示全部楼层
嗯啊,学习了
了解了 马上要接手这里
那可得好好学习啊
 楼主| zxf0168 发表于 2013-12-30 20:43 | 显示全部楼层
额 看得不是特别懂 收藏了 慢慢研究
好好学习天天向上嘛
