DSP28069 can用TI例程初始化都死等了!
2042|6
 楼主| 耶稣欠筹了 发表于 2014-1-23 17:07 | 显示全部楼层 |阅读模式
本人菜鸟刚接触DSP做个CAN通信,上TI的例程,初始化也是。请大家帮助!程序如下:
void InitECana(void)        // Initialize eCAN-A module
/* Create a shadow register structure for the CAN control registers. This is
needed, since only 32-bit access is allowed to these registers. 16-bit access
to these registers could potentially corrupt the register contents or return
false data. */
struct ECAN_REGS ECanaShadow;
    EALLOW;     // EALLOW enables access to protected bits
/* Configure eCAN RX and TX pins for CAN operation using eCAN regs*/
    ECanaShadow.CANTIOC.all = ECanaRegs.CANTIOC.all;
    ECanaShadow.CANTIOC.bit.TXFUNC = 1;
    ECanaRegs.CANTIOC.all = ECanaShadow.CANTIOC.all;
    ECanaShadow.CANRIOC.all = ECanaRegs.CANRIOC.all;
    ECanaShadow.CANRIOC.bit.RXFUNC = 1;
    ECanaRegs.CANRIOC.all = ECanaShadow.CANRIOC.all;
/* Configure eCAN for HECC mode - (reqd to access mailboxes 16 thru 31) */
                                    // HECC mode also enables time-stamping feature
    ECanaShadow.CANMC.all = ECanaRegs.CANMC.all;
    ECanaShadow.CANMC.bit.SCB = 1;
    ECanaRegs.CANMC.all = ECanaShadow.CANMC.all;
/* Initialize all bits of 'Message Control Register' to zero */
// Some bits of MSGCTRL register come up in an unknown state. For proper operation,
// all bits (including reserved bits) of MSGCTRL must be initialized to zero
    ECanaMboxes.MBOX0.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX1.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX2.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX3.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX4.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX5.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX6.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX7.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX8.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX9.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX10.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX11.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX12.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX13.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX14.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX15.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX16.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX17.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX18.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX19.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX20.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX21.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX22.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX23.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX24.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX25.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX26.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX27.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX28.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX29.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX30.MSGCTRL.all = 0x00000000;
    ECanaMboxes.MBOX31.MSGCTRL.all = 0x00000000;
// TAn, RMPn, GIFn bits are all zero upon reset and are cleared again
//  as a matter of precaution.
    ECanaRegs.CANTA.all = 0xFFFFFFFF;   /* Clear all TAn bits */
    ECanaRegs.CANRMP.all = 0xFFFFFFFF;  /* Clear all RMPn bits */
    ECanaRegs.CANGIF0.all = 0xFFFFFFFF; /* Clear all interrupt flag bits */
    ECanaRegs.CANGIF1.all = 0xFFFFFFFF;
/* Configure bit timing parameters for eCANA*/
    ECanaShadow.CANMC.bit.CCR = 1 ;            // Set CCR = 1
    // Wait until the CPU has been granted permission to change the configuration registers
   do
      ECanaShadow.CANES.all = ECanaRegs.CANES.all;
    } while(ECanaShadow.CANES.bit.CCE != 1 );
    // Wait for CCE bit to be set..
    ECanaShadow.CANBTC.all = 0;
    /* The following block is for 80 MHz SYSCLKOUT. (40 MHz CAN module clock Bit rate = 1 Mbps
       See Note at end of file. */
    ECanaShadow.CANBTC.bit.BRPREG = 1;
    ECanaShadow.CANBTC.bit.TSEG2REG = 4;
    ECanaShadow.CANBTC.bit.TSEG1REG = 13;
    ECanaShadow.CANBTC.bit.SAM = 1;
    ECanaRegs.CANBTC.all = ECanaShadow.CANBTC.all;
    ECanaShadow.CANMC.bit.CCR = 0 ;            // Set CCR = 0
    // Wait until the CPU no longer has permission to change the configuration registers
    do
    } while(ECanaShadow.CANES.bit.CCE != 0 );       // Wait for CCE bit to be  cleared..
/* Disable all Mailboxes  */
    ECanaRegs.CANME.all = 0;        // Required before writing the MSGIDs
    EDIS;
一直红色位置死等了,这是TI的初始化配置,没有任何修改。硬件问题?但是初始化配置不可能关配置事的!
zhangmangui 发表于 2014-1-23 18:22 | 显示全部楼层
帮忙顶   高手看看DSP CAN
 楼主| 耶稣欠筹了 发表于 2014-1-24 09:58 | 显示全部楼层
高手看看DSP CAN
 楼主| 耶稣欠筹了 发表于 2014-1-24 10:37 | 显示全部楼层
帮忙顶   高手看看DSP CAN
问题我找到了,比高人指点了一下,是时钟使能问题。谢谢版主的支持!
huangfeng33 发表于 2014-1-25 20:05 | 显示全部楼层
推荐楼主一本好书《手把手教你学DSP——基于TMS320X281X》。
angerbird 发表于 2014-1-25 22:11 | 显示全部楼层
多分析看看标志为撒的吧,,或者其他哪个寄存器的没有设置正确的
zhangjin_comeon 发表于 2014-1-25 23:21 | 显示全部楼层
帮忙顶
