[AVR单片机] 求助:atmega16运行跑飞
1197|3
 楼主| kingdian1983 发表于 2014-3-19 20:53 | 显示全部楼层 |阅读模式
小弟新手,最近用16芯片做个项目,发现在运行中出现重启的现象,重启的时间不固定。从现象看感觉像软件的问题,下面我将代码贴出来,望各位大虾帮忙看看是否有BUG,小弟先行谢了!:)
 楼主| kingdian1983 发表于 2014-3-19 21:01 | 显示全部楼层
void test(void)
        run_state=T_B;
        PORTD|=0x1b;
        for(;;) {
                if (warn!=0||run_stop==0) {
                        PORTD=0;
                        break;
                if(run_mode!=RUN_NORMAL){
                        break;
                Pause();
                PineTesting();
                if(flag_monitor_ok!=0){
                        flag_monitor_ok=0;
                        clear_p=RealPressure();
                if(time_out>TIMEOVER){//判断计时是否超30S,超过报警
                        Warning(1);
                        flag_timeout_ok=0;
                        time_out=0;
                switch(run_state){
                        case T_B://状态1
                                if((clear_p>=p_min) && (minus==1)){//转到下一状态
                                        PORTD=0x1f;
                                        time_keep=0;
                                        flag_keep_ok=1;
                                        flag_keeprun_ok=0;
                                        run_state=K_B;
                                        flag_timeout_ok=0;//关闭30S计时
                                        if(time_out>TIMEOVER){//判断计时是否超30S,超过则报警
                                                Warning(1);
                                                flag_timeout_ok=0;
                                                time_out=0;
                                        }else{//否则重新开始下一轮计时
                                                time_out=0;
                                                flag_timeout_ok=1;//打开30S计时
                                        flag_timereduce_ok=0;//关闭5S递减计时
                                        if(time_reduce!=0){//判断计时是否超5S,不超过报警
                                                Warning(2);
                                                time_reduce=TIMEREDUCE;
                                        }else{//否则重新开始下一轮计时
                                                flag_timereduce_ok=1;
                        case K_B://状态2
                                if(flag_keeprun_ok==1 && (clear_p<p_min-5)) {
                                        PORTD=0x1b;
                                        flag_keeprun_ok=0;
                                if(clear_p>=p_min+2){
                                        PORTD=0x1f;
                                if(flag_keep_ok!=1){//转到下一状态
                                        PORTD=0x15;
                                        flag_ph=0;
                                        run_state=B_T;
                                break;
                        case B_T://状态3
                                if((clear_p>5) && (flag_ph==0) && (minus==0)){
                                        flag_ph=1;
                                        PORTD=0x17;
                                if ((clear_p>=p_max) && (minus==0)) {//转到下一状态
                                        PORTD=0x1f;
                                        time_keep=0;
                                        flag_keep_ok=1;
                                        flag_keeprun_ok=0;
                                        run_state=K_T;
                                                Warning(1);
                                                flag_timeout_ok=0;
                                                time_out=0;
                                        }else{//否则重新开始下一轮计时
                                                time_out=0;
                                        if(time_reduce!=0){//判断计时是否超5S,不超过则报警
                                                Warning(2);
                                        }else{//否则重新开始下一轮计时
                                break;
                        case K_T://状态4
                                if(flag_keeprun_ok==1 && (clear_p<p_max-10)) {
                                        PORTD=0x17;
                                        flag_keeprun_ok=0;
                                if(clear_p>=p_max+2){
                                        PORTD=0x1f;
                                        PORTD=0x1b;
                                        flag_pmax=1;
                                        clear_count++;
                                        flow_in+=CLEAR_LIQIUD;
                                        if (clear_count>999) clear_count=0;
                                        if (flow_in>50000) flow_in=0;
                                        run_state=T_B;
                                break;
                        default:
                                break;
                DisplayNum(1,1);//显示
 楼主| kingdian1983 发表于 2014-3-19 21:06 | 显示全部楼层
unsigned char readAdc(unsigned char chanel)
        unsigned char i;
        unsigned char dat=0;
        unsigned char dat1=0;
        unsigned char dat2=0;
        PORTB|=0x08;//准备
        NOP();
        PORTB&=0xf7;//片选有效cs
    Delay_us();
        PORTB&=0xfe;
        Delay_us();
        PORTB|=0x02;//启动信号
    Delay_us();
        PORTB|=0x01;//第一个下降沿
    Delay_us();
        PORTB&=0xfe;
        Delay_us();
        PORTB|=0x02;//SGL,单极性
    Delay_us();
        PORTB|=0x01;//第二个下降沿
    Delay_us();
        PORTB&=0xfe;
        Delay_us();
        if(chanel==0){//通道0//通道选择
                PORTB&=0xfd;
        } else{//通道1
                PORTB|=0x02;
    Delay_us();
        PORTB|=0x01;//第三个下降沿
    Delay_us();
        PORTB&=0xfe;
    Delay_us();
        Delay_us();
        for(i=0;i<8;i++){//读取一个字节,高位在前
                PORTB|=0x01;
                Delay_us();
                PORTB&=0xfe;
                Delay_us();
                dat1=PINB;
                dat=dat<<1;
                if((dat1&0x04)==0x04){
                        dat|=0x01;
                }else{
                        dat|=0x00;
        Delay_us();
        for(i=0;i<8;i++){//读取一个字节,低位在前
                PORTB|=0x01;
                Delay_us();
                PORTB&=0xfe;
                Delay_us();
                dat1=PINB;
                dat2=dat2<<1;
                        dat2|=0x01;
                }else{
                        dat2|=0x00;
        PORTB|=0x08;//拉高片选
        PORTB&=0xfe;//拉低时钟
        Delay_us();
        return dat;
unsigned char RealPressure(void)//压力值读取
        unsigned char temp;
        unsigned char nPress;
        unsigned char nPress1;
        unsigned char nPress2;
        temp=readAdc(0);
        if(temp<=50||temp>=186){
                flag_adcover=1;
        }else{
                flag_adcover=0;
                time_adcover=0;
        if(temp>=p_zero){
                minus=0;
                nPress=temp-p_zero;
                nPress2=nPress;
                nPress1=nPress+(nPress2>>=3);
                nPress=nPress1+nPress1/6;
        }else{
                minus=1;
                nPress=p_zero-temp;
                nPress2=nPress;
        if(nPress>(p_min+5)||nPress>(p_max+5)){/
                flag_pover=1;
        }else{
                flag_pover=0;
                time_pover=0;
        return nPress;
void PineTesting(void)
        unsigned char br=0;
        br=readAdc(1);
        if(br<50){
                flag_leak=1;
        }else{
                time_leak=0;
                flag_leak=0;
void Warning(unsigned char nAlarm)//警报声光提示
     run_stop=0;
         PORTD=0x80;
         second_flag=1;
         switch(nAlarm)
          case 1:
                 warn=1;
                 state0|=0x02;
                         break;
          case 2:
                 warn=2;
                 flow_alarm|=0x10;
                 break;
          case 3:
                 warn=3;
                 state1|=0x02;
                 break;
          case 4:
                 warn=4;
                 leak_alarm|=0x10;
                         break;
          default:
                 warn=0;
                 break;
 楼主| kingdian1983 发表于 2014-3-19 21:08 | 显示全部楼层
