请教12864读数据,怎么读到的总0xff
1381|2
 楼主| loyforever 发表于 2014-4-1 21:31 | 显示全部楼层 |阅读模式
#include <iom128v.h>
#include <macros.h>
#define uchar unsigned char
#define uint  unsigned int
#include "LCD12864.h"
//*****LCD起始行列页定义********************
#define LCD_START_ROM 0XC0                        //起始行
#define LCD_PAGE      0XB8                        //页指令
#define LCD_COL                  0X40                        //列指令
#define LCD_OFF           0x3E                         //关显示
#define LCD_ON                   0x3F                        //开显示
//*****液晶控制引脚*************************
#define E                          PC0
#define RW                           PC1
#define RS                          PC2
#define RST                          PC3
#define CS2                          PC4
#define CS1                          PC5
//*****液晶端口*****************************
#define LCD_PORT          PORTA
#define LCD_DDR                  DDRA
#define LCD_PIN                  PINA
#define LCD_CTRL_PORT PORTC
#define LCD_CTRL_DDR  DDRC
#define LCD_CTRL_PIN  PINC
//*****液晶引脚操作定义*********************
#define RW_1()        LCD_CTRL_PORT|=BIT(RW)
#define RW_0()        LCD_CTRL_PORT&=~BIT(RW)
#define RS_1()        LCD_CTRL_PORT|=BIT(RS)
#define RS_0()        LCD_CTRL_PORT&=~BIT(RS)
#define E_1()         LCD_CTRL_PORT|=BIT(E)
#define E_0()         LCD_CTRL_PORT&=~BIT(E)
#define CS1_1()       LCD_CTRL_PORT|=BIT(CS1)
#define CS1_0()       LCD_CTRL_PORT&=~BIT(CS1)
#define CS1X-PIN      ((LCD_CTRL_PIN)&0X05)
#define CS2_1()       LCD_CTRL_PORT|=BIT(CS2)
#define CS2_0()       LCD_CTRL_PORT&=~BIT(CS2)
#define CS2X-PIN      LCD_CTRL_PIN&0X04
#define RST_1()       LCD_CTRL_PORT|=BIT(RST)
#define RST_0()       LCD_CTRL_PORT&=~BIT(RST)
unsigned char tab[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};//一个字节中的8个位,此处要控制点,因此要处理八位中的一位。
//*****带显示汉字矩阵****************************
const uchar word_dot_matrix[]=
{/*--  文字:  中  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
0x00,0x00,0xFC,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,
0x00,0x00,0x07,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x07,0x00,0x00,0x00,
/*--  文字:  华  --*/
0x20,0x10,0x08,0xFC,0x03,0x02,0x10,0x10,0x7F,0x88,0x88,0x84,0x86,0xE4,0x00,0x00,
0x00,0x04,0x04,0x05,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
/*--  文字:  人  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0xC2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x01,0x06,0x0C,0x18,0x30,0x60,0x20,0x00,
/*--  文字:  民  --*/
0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0xF2,0x92,0x92,0x92,0x9E,0x80,0x80,0x00,0x00,
0x00,0x00,0xFF,0x40,0x20,0x10,0x00,0x00,0x03,0x0C,0x10,0x20,0x40,0xF0,0x00,0x00,
/*--  文字:  共  --*/
0x00,0x10,0x10,0x10,0x10,0xFE,0x10,0x10,0x10,0x10,0xFE,0x10,0x10,0x10,0x00,0x00,
0x02,0x02,0x82,0x42,0x32,0x1F,0x0A,0x02,0x02,0x06,0x0B,0x32,0xE2,0x42,0x02,0x00,
/*--  文字:  和  --*/
0x00,0x24,0x24,0xA4,0xFC,0x22,0x22,0x22,0x00,0xF8,0x08,0x08,0x08,0xF8,0x00,0x00,
0x10,0x08,0x06,0x01,0xFF,0x01,0x0E,0x04,0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00,
/*--  文字:  国  --*/
0x00,0xFE,0x02,0x0A,0x8A,0x8A,0x8A,0xFA,0x8A,0x8A,0x8A,0x0A,0x02,0xFE,0x00,0x00,
0x00,0xFF,0x40,0x48,0x48,0x48,0x48,0x4F,0x48,0x49,0x4E,0x48,0x40,0xFF,0x00,0x00,};
//*****是否反相显示(白底黑字/黑底白字)****
uchar Reverse_Display=0;
//*****等待液晶就绪*************************
void wait_lcd_ready(void)//读状态时CS1,CS0一定要置0,否则无法读取,这是必须读CS1,CS0的当前状态
  uchar st,cs1,cs2;
  cs1 = ((LCD_CTRL_PIN)&BIT(CS1));
  cs2 = ((LCD_CTRL_PIN)&BIT(CS2));
  CS1_0();CS2_0();
  do
  LCD_DDR=0X00;
  LCD_PORT=0xff;
  RW_1(); delay_us(1); RS_0();E_1();
  st=LCD_PIN;
  E_0();
  }while(st>>7);
  LCD_CTRL_PORT|=cs1;
  LCD_CTRL_PORT|=cs2;
//*****向LCD发送命令************************
void lcd_write_cmd(uchar cmd)
  wait_lcd_ready();
  LCD_DDR=0xff;
  LCD_PORT=0xff;
  RW_0();delay_us(1);RS_0();
  LCD_PORT=cmd;
  E_1();delay_us(1); E_0();
//*****向LCD发送数据************************
void lcd_write_data(uchar dat)
  wait_lcd_ready();
  LCD_DDR=0xff;
  LCD_PORT=0xff;
  RW_0();delay_us(1);RS_1();
  if(!Reverse_Display)LCD_PORT=dat;else LCD_PORT=~dat;
//*****读数据************************
uchar lcd_read_data(void)
uchar dat=0;
wait_lcd_ready();
LCD_DDR = 0X00;
LCD_PORT=0xff;
RW_1();RS_1();E_1();delay_us(2);
E_0();
dat = LCD_PIN;
delay_us(2);
E_0();
return dat;
//*****初始化LCD****************************
void lcd_init()
  LCD_CTRL_PORT=0xff;
  LCD_CTRL_DDR=0XFF;
  LCD_DDR =0XFF;
  LCD_PORT = 0XFF;
  lcdsel(0);
  lcd_write_cmd(0x3f);
  delay_ms(15);
void lcdsel(uchar sel)//选择屏幕
  switch(sel)
    case 0: CS1_0();CS2_0();break; //选择两个屏幕
        case 1: CS1_0();CS2_1();break; //选择左半屏幕
        case 2: CS1_1();CS2_0();break; //选择右半屏幕
        default:break;
void setx(uchar x)//页选择0~7
  lcd_write_cmd(LCD_PAGE+x);
//LCD_COL是0x40,列初始地址,Y地址自动加一
void sety(uchar y)
  lcd_write_cmd(LCD_COL+y);
//LCD_START_ROM是0xC0,起始行地址
void setz(uchar z)
  lcd_write_cmd(LCD_START_ROM+z);
//清屏
void clearlcd()
  int i,j;
  lcdsel(0);//选择两个屏幕
  for(j=0;j<8;j++)
   lcd_write_cmd(LCD_ON);//开显示
   setx(j); //从0到7选择每一页
   lcd_write_cmd(LCD_COL); //写入列的初始地址,列地址会自动加1
   setz(0);//DDEAM和屏幕的对应关系是DDRAM中第0行对应屏幕的第1行。
   for (i=0;i<64;i++)
    lcd_write_data(0x00);//选中了两个半屏,向两个半屏相同列号处同时写入0x00,清屏。
//左上角第一个点为原点,向下Y为轴,向右为X轴
//x:0~63~127 列号 y:0~63行号
//由于是由页和列控制的,因此此处给出的x必须转化为页,即除以8即可,由于是处理一个点,还要得到这一页的第几行,即对8求余
//flag : 0:擦除某个点, 1:显示某个点 ,其本质就是赋值,赋值0是清除一个点,赋值1是显示一个点
void dot(uchar x,uchar y,uchar flag)
   uchar dat=0;
   if(x<64)//x属于0~63就是左半屏幕
       lcdsel(1);//选择左半屏幕
           setx(y>>3); //y是行号,y属于0~63,除以8就得到当前的页
       sety(x); //由列号设置列地址
           dat = lcd_read_data();//读数
       if(flag)//flag为1显示某个点,点显示为黑色的,液晶中每个字体的显示都是黑色的
               dat = dat|(tab[y&7]);
           else
                dat = dat&(~(tab[y&7]));
           sety(x);
           lcd_write_data(dat);
    else if(x<128)//右半屏幕
            lcdsel(2);//选择右半屏幕
                   setx(y>>3);//设置页地址
                   sety(x-64);//列地址,右屏幕的列号是从0到63
                     dat = lcd_read_data();//读数据
            if(flag)
                    dat=dat|(tab[y&7]);
                  else
                      dat=dat&(~(tab[y&7]));
                sety(x-64);//右半屏幕的列地址也是0~63
                lcd_write_data(dat);//写数据
//通用显示函数common_show
//从第P页第L列开始显示第W个数据数据在r所指向的缓冲
//每个字节8位是垂直显示的,高位在下,低位在上
//每个8*128举行区域是一页
//整个LCD由64*64左半页和64*64的右半页构成
void common_show(uchar P,uchar L,uchar W,uchar *r)
  uchar i;
  //显示在左半屏或右半屏
  if(L<64)
    CS1_1();CS2_0();
        lcd_write_cmd(LCD_PAGE + P );
        lcd_write_cmd(LCD_COL+ L );
        //全部显示在左半屏
        if((L+W)<64)
          for(i=0;i<W;i++)lcd_write_data(r[i]);
        else
          //左半屏显示
          for(i=0;i<(64-L);i++)lcd_write_data(r[i]);
          //右半屏显示
          CS1_0();CS2_1();
          lcd_write_cmd(LCD_COL );
          for(i=64 -L;i<W;i++)lcd_write_data(r[i]);
  else
  //全部显示在右半屏
    CS1_0();CS2_1();
        lcd_write_cmd(LCD_COL + L -64);
//*****显示8*16点阵字符**************************
void diaplay_a_char_8x16(uchar P,uchar L,uchar *M)
  common_show( P, L,8, M);
  common_show( P+1, L,8, M+8);
//*****显示一个16*16的点阵汉字*******************
void diaplay_a_word_16x16(uchar P,uchar L,uchar *M)
  common_show( P, L,16, M);
  common_show( P+1, L,16, M+16);
//*****显示一串16*16的点阵汉字*******************
void diaplay_word_string_16x16(uchar P,uchar L,uchar C,uchar *M)
  uchar i;
  for(i=0;i<C;i++)
    diaplay_a_word_16x16(P,L+i*16,M+i*32);
头文件
#ifndef _LCD12864_H
#define _LCD12864_H
void setx(uchar x);
void sety(uchar y);
void setz(uchar z);
void clearlcd();
void dot(uchar x,uchar y,uchar flag);
void lcdsel(uchar sel);//选择屏幕
void lcd_write_data(uchar dat);
uchar lcd_read_data(void);
void wait_lcd_ready(void);
void lcd_write_cmd(uchar cmd);
void lcd_init(void);
void diaplay_a_char_8x16(uchar P,uchar L,uchar *M);
void diaplay_a_word_16x16(uchar P,uchar L,uchar *M);
void common_show(uchar P,uchar L,uchar W,uchar *r);
void diaplay_word_string_16x16(uchar P,uchar L,uchar C,uchar *M);
#endif
huangxz 发表于 2014-4-1 23:33 | 显示全部楼层
读数据还是读状态是0xff?
 楼主| loyforever 发表于 2014-4-2 15:05 | 显示全部楼层
读数据,忙状态我可以读到
