[程序源码] 求助将Delphi的加密解密算法写成C语言
1824|0
 楼主| xfh168168 发表于 2014-5-24 10:29 | 显示全部楼层 |阅读模式
//加密关键字:key=“123”
//明码:1231adcd1234
//加密后,8FAF8FA7AC43E90F25151F0853
function TMainForm.EncryptString(Source, Key: string): string;  //加密
var
  KeyLen: integer;
  KeyPos: integer;
  Offset: integer;
  Dest: string;
  SrcPos: integer;
  SrcAsc: integer;
  Range: integer;
begin
  KeyLen := Length(Key);
  if KeyLen = 0 then
    Key := 'delphi';
    KeyPos := 0;
    Range := 256;
    randomize;
    Offset := random(Range);
    Dest := format('%1.2x', [Offset]);
    for SrcPos := 1 to Length(Source) do
      begin
        SrcAsc := (Ord(Source[SrcPos]) + Offset) mod 255;
        if KeyPos < KeyLen then
          KeyPos := KeyPos + 1
        else
          KeyPos := 1;
       SrcAsc := SrcAsc xor Ord(Key[KeyPos]);
       Dest := Dest + format('%1.2x', [SrcAsc]);
       Offset := SrcAsc;
      end;
  result := Dest;
end;
function TMainForm.UnEncryptString(Source, Key: string): string; //解密
  var
    KeyLen: integer;
    KeyPos: integer;
    Offset: integer;
    Dest: string;
    SrcPos: integer;
    SrcAsc: integer;
    TmpSrcAsc: integer;
begin
    if KeyLen = 0 then
      Key := 'delphi';
    KeyPos := 0;
    Offset := strtoint('$' + copy(Source, 1, 2));
    SrcPos := 3;
    repeat
      SrcAsc := strtoint('$' + copy(Source, SrcPos, 2));
       else
          KeyPos := 1;
     TmpSrcAsc := SrcAsc xor Ord(Key[KeyPos]);
     if TmpSrcAsc <= Offset then
      TmpSrcAsc := 255 + TmpSrcAsc - Offset
     else
      TmpSrcAsc := TmpSrcAsc - Offset;
     Dest := Dest + chr(TmpSrcAsc);
     Offset := SrcAsc;
     SrcPos := SrcPos + 2;
    until SrcPos >= Length(Source);
    result := Dest;
end;
//我用C语言写的解密算法不对?请帮忙检查,谢谢.....
char a2x( char ch )
switch( ch )
case '1':
return 1;
case '2':
return 2;
case '3':
return 3;
case '4':
return 4;
case '5':
return 5;
case '6':
return 6;
case '7':
return 7;
case '8':
return 8;
case '9':
return 9;
case 'A':
case 'a':
return 10;
case 'B':
case 'b':
return 11;
case 'C':
case 'c':
return 12;
case 'D':
case 'd':
return 13;
case 'E':
case 'e':
return 14;
case 'F':
case 'f':
return 15;
default:
break;;
return 0;
void unEncrypt( char *source, int srcLen )
xdata char        i = 0;
xdata char        keyLen;
xdata char        keyPos;
xdata char        srcPos;
xdata char        srcAsc;
xdata char        tmpSrcAsc;
xdata char        offset;
xdata char        key[]           = "123";
xdata char        dest[64]   = { 0, };
keyPos = 0;
keyLen = strlen( key );
offset = ( a2x( source[0] ) << 4 ) | a2x( source[1] );
for( srcPos = 2; srcPos < srcLen; )
srcAsc           = ( a2x( source[srcPos] ) << 4 ) | a2x( source[srcPos + 1] );
tmpSrcAsc  = srcAsc ^ key[keyPos];
if( tmpSrcAsc <= offset )
tmpSrcAsc = 255 + tmpSrcAsc - offset;
else
tmpSrcAsc = tmpSrcAsc - offset;
dest[i++] = tmpSrcAsc;
offset = srcAsc;
srcPos += 2;
if( keyPos < keyLen )
keyLen++;
else
keyPos = 0;
