[STM32F1] KEIL 编译器报的一个语法错误
1945|3
 楼主| dudongdao 发表于 2014-7-17 13:10 | 显示全部楼层 |阅读模式
__packed struct SPacketQueue
        struct SPacketQueue  *pNext;
        struct SPacketQueue  *pPre;
        DWORD        Seq;                                /* sequence of this packet */
        struct SMemHead  *MemHead;        /* packet store in MemHead' playload */
/* tcb (transmit control block). used to keep tcp state
information */
__packed struct STCB
        struct STCB  *pNext;   /* Next Node */
        BYTE        TCPState;
        WORD        PortScr;
        WORD        PortDest;
        IP_ADDR        IPScr;
        IP_ADDR IPDest;
        DWORD        SeqMine;
        struct SPacketQueue  *QUnacked;
上面是定义的结构体,函数如下:
void TCPRelease(struct STCB  *pTCB)
        struct SPacketQueue  *pQ;
        /* reclaim Q, and free packet in queue */
        while(pQ = TCPOutQ(&(pTCB->QUnacked)))
                MemFree(pQ->MemHead);
这个函数里面报错  error:  #167: argument of type "struct SPacketQueue *__packed *" is incompatible with parameter of type "struct SPacketQueue **"
如果去掉 __packed struct STCB前面的__packed ,就不报错,请问各位大侠,这是什么毛病,我想所有的参数都对其。
mmuuss586 发表于 2014-7-17 13:31 | 显示全部楼层
结构体里又定义结构体,这样不支持吧;
爱不孤单 发表于 2014-7-17 13:54 | 显示全部楼层
pTCB->QUnacked本来就是 struct SPacketQueue  *,如果你再一次取地址就变成struct SPacketQueue  **类型,我想TCPOutQ()函数参数类型应该不是吧,struct SPacketQueue *__packed *这个是什么类型,LZ最好把TCPOutQ()的函数原型也发出来
 楼主| dudongdao 发表于 2014-7-18 10:51 | 显示全部楼层
好的~~
/* move the last unit in queue outof queue,if the queue
is empty return FALSE.actrually last unit is *ppQ */
struct SPacketQueue  * TCPOutQ(struct SPacketQueue  ** ppQ)
        /* a empty queue? */
        if((pQ = *ppQ) == NULL)
                return NULL;
        /* after remove it, the queue is empty? */
        if(pQ->pNext == pQ)
                *ppQ = NULL;
        else
                /* relink */
                pQ->pPre->pNext = pQ->pNext;
                pQ->pNext->pPre = pQ->pPre;
                /* and the queue head *ppQ point to pQ->pPre */
                *ppQ = pQ->pPre;
        /* relaim it. link to QFreeList */
        pQ->pNext = QFreeList;
        QFreeList = pQ;
        return pQ;
