【新手请教】51单片机一个用I2C总线点LED灯的程序,为什么不
1403|0
 楼主| 深海鱼男 发表于 2014-7-17 18:51 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
sbit SCL=P2^1;
sbit SDA=P2^0;
#define SCL_SET SCL=1
#define SCL_CLR SCL=0
#define SDA_SET SDA=1
#define SDA_CLR SDA=0
void Delay(uint cnt)
        while(--cnt);
void start()
        SDA_SET;
        Delay(1);
        SCL_SET;
        Delay(5);
        SDA_CLR;
void stop()
        SDA_CLR;
        Delay(1);
        SCL_SET;
        Delay(5);
        SDA_SET;
void ack()
        SDA_CLR;
        SCL_SET;
        Delay(1);
        SCL_CLR;
void noAck()
        SDA_SET;
        SCL_SET;
        Delay(1);
        SCL_CLR;
void send(uchar Data)
        uchar i=0;
        uchar temp=0;
        temp=Data;
        for(i=0; i<8; i++)
                SCL_CLR;
                Delay(1);
                if(temp&0x80) SDA_SET;
                else SDA_CLR;
                Delay(1);
                SCL_SET;
                Delay(1);
                temp<<=1;
        SCL_CLR;
uchar recive()
        uchar i=0;
        uchar temp=0;
        SDA_SET;
        for(i=0; i<8; i++)
                SCL_CLR;
                Delay(1);
                SCL_SET;
                Delay(2);
                if(SDA) temp|=0x01;
                else temp&=0xfe;
                if(i<7)   temp<<=1;
        SCL_CLR;
        return temp;
void main()
               start();
                send(0xa0);
                ack();
                send(23);
                ack();
                send(0xfe);
                   ack();
                stop();
                Delay(100);
                   start();
                   send(0xa0);
                ack();
                send(23);
                ack();
                start();
                   send(0xa1);
                ack();
                   P1=recive();
                noAck();
                stop();
                while(1);
我学了好几天I2C总线操作了,看了不少例程,感觉不同人都有不一样的写法,可是自己动手时总是会出问题。好不容易搞出来了,感觉像是碰巧写对的,因为换种方法又不行了,希望前辈们不吝指教!
