[DSP编程] 头文件报错
1582|5
 楼主| stdenis 发表于 2014-8-8 15:42 | 显示全部楼层 |阅读模式
头文件中的c6x.h文件报错:
  1. /*****************************************************************************/
  2. /*  C6X.H v4.32                                                             */
  3. /*  Copyright (c) 1996-2002 Texas Instruments Incorporated                   */
  4. /*****************************************************************************/
  5. #ifdef __cplusplus
  6. extern "C"
  7. {
  8. #endif /* __cplusplus */
  9. unsigned _extu          (unsigned, unsigned, unsigned);
  10. int      _ext          (int,      unsigned, unsigned);
  11. unsigned _set          (unsigned, unsigned, unsigned);
  12. unsigned _clr          (unsigned, unsigned, unsigned);
  13. unsigned _extur          (unsigned, int);
  14. int      _extr          (int,      int);
  15. unsigned _setr          (unsigned, int);
  16. unsigned _clrr          (unsigned, int);
  17. int      _sadd          (int,      int);
  18. [color=Red]long     _lsadd          (int,      long);[/color]
  19. int         _ssub          (int,      int);
  20. [color=Red]long         _lssub          (int,      long);[/color]
  21. int      _sshl          (int,      unsigned);
  22. int         _add2          (int,      int);
  23. int         _sub2          (int,      int);
  24. unsigned _subc          (unsigned, unsigned);
  25. unsigned _lmbd          (unsigned, unsigned);
  26. int      _abs          (int);
  27. [color=Red]long     _labs          (long);
  28. int      _sat          (long);[/color]
  29. unsigned _norm          (int);
  30. [color=Red]unsigned _lnorm          (long)[/color];
代码中的红色部分报错,报错类型为#149 declaration is incompatible with builtin "__int40_t _lssub(int, __int40_t)" 只要出现long就报错,求解
ayb_ice 发表于 2014-8-8 16:44 | 显示全部楼层
声明与定义不一样
NWPU_CHEN 发表于 2014-8-8 23:10 | 显示全部楼层
检查类型名
 楼主| stdenis 发表于 2014-8-9 09:57 | 显示全部楼层
声明与定义不一样
什么意思?
ayb_ice 发表于 2014-8-9 10:40 | 显示全部楼层
什么意思?
这些都是些基本错误
zhangmangui 发表于 2014-8-9 15:40 | 显示全部楼层
出现long类型就出错   与函数定义参数有关
