[Atmel]
读博客晒感想活动奖品开发板SAM4L8 Xplained Pro Evaluation Kit介绍
1225|0
简单地看了下,这伡是基本CORTEX-M4核的,很不错唉!!!具体的说明如:
The Atmel®™-M4 processor-based microcontroller. Extension boards can be purchased individually.
Key Features
  • SAM4LC8CA microcontroller
  • One mechanical reset button
  • One mechanical user pushbutton (wake-up, bootloader entry or general purpose)
  • One QTouch® button
  • One yellow user LED
  • USB interface, host and device function (shared physical interface)
  • 32.768kHz crystal
  • 12MHz crystal
  • 4 Xplained Pro extension headers
  • One custom extension header for segment LCD displays
  • LDO/buck regulator mode selection
  • LCD cluster power configuration option
  • Embedded debugger
    • Auto-ID for board identification in Atmel Studio 6.1*
    • One yellow status LED
    • One green board power LED
    • Symbolic debug of complex data types including scope information
    • Programming
    • Data Gateway Interface: USART, TWI, 4 GPIOs
    • Virtual COM port (CDC)
  • USB powered
  • Supported with application examples in Atmel Software Framework
Atmel-42103-SAM4L8-Xplained-Pro_User-Guide.zip (10.34 MB)
Atmel-42235-Developing-Extension-Boards-for-the-Xplained-Pro-Evaluation-Kits_AP-.pdf (256.16 KB)
Atmel-42096-Microcontrollers-Embedded-Debugger_User-Guide (1).pdf (270.61 KB)
Atmel-42023-ARM-Microcontroller-ATSAM4L-Low-Power-LCD_Datasheet.pdf (6.84 MB)
Atmel-42103-SAM4L8-Xplained-Pro_User-Guide.pdf (824.5 KB)
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2400
