转载——MSP430FR5969学习笔记---gpio中断
1067|4
 楼主| huigoushang 发表于 2014-11-28 19:40 | 显示全部楼层 |阅读模式
实现按下P11。led2交替点亮。
代码:
#include "driverlib.h"
//!   Empty Project that includes driverlib
void main(void)
        WDT_A_hold(WDT_A_BASE);
        GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1,GPIO_PIN1);                                                //P11设置为 上拉 输入
        GPIO_interruptEdgeSelect(GPIO_PORT_P1,GPIO_PIN1,GPIO_HIGH_TO_LOW_TRANSITION);                //P11设置为下降沿中断
        GPIO_enableInterrupt(GPIO_PORT_P1,GPIO_PIN1);        //使能P11中断
        GPIO_clearInterruptFlag(GPIO_PORT_P1,GPIO_PIN1);        //清除P11中断标志//
        GPIO_setAsOutputPin(GPIO_PORT_P1,GPIO_PIN0);        //设置P10为输出//
        GPIO_setOutputHighOnPin(GPIO_PORT_P1,GPIO_PIN0);        //点亮LED2(P10)
        PMM_unlockLPM5();
        //Enter LPM4 w/interrupt
         __bis_SR_register(LPM4_bits + GIE);        //LPM4+使能总中断//
                //For debugger
          __no_operation();
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=PORT1_VECTOR
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(PORT1_VECTOR)))
#endif
void Port_1(void)
        GPIO_toggleOutputOnPin(GPIO_PORT_P1,GPIO_PIN0);        //翻转LED2
大家没事看一看吧
dirtwillfly 发表于 2014-11-28 19:55 | 显示全部楼层
:handshake感谢分享
