[STM8] stm8调试硬件i2c RDA5807读总出错
2895|2
 楼主| machao070 发表于 2015-3-10 23:08 | 显示全部楼层 |阅读模式
#include "include.h"
static unsigned int CurrFrequency;
static unsigned int Currchan;
RDA5807P相关寄存器镜像
static unsigned char RDA5807P_reg[]={
0xd0, 0x01, //02H;
0x00, 0x00, //03H;
0x84, 0x04, //04H;
0x88, 0xA1, //05H;
static void delayms(uint16_t nCount)
  while (nCount != 0)
    nCount--;
/**************************实现函数********************************************
*函数原型: void InitIIC(void)
*功  能: 初始化外设IIC
void InitIIC(void)
  //I2C_DeInit();
  //I2C_Init(IICSPEED, Radio_Address, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT,2);
  //I2C_Cmd(ENABLE);
   /* 使能I2C */
  I2C_Cmd(ENABLE);
        设置I2C时钟速度为400K
        I2C1_SLAVE_ADDRESS7  自身7位从地址(对10位地址不响应)
        I2C_DUTYCYCLE_2  时钟占空比 1:2
        I2C_ACK_CURR 收到一个字节后(匹配的地址字节或者数据字节)后返回应答。
        I2C_ADDMODE_7BIT  从机地址为7位
        16  当前系统时钟速度,单位MHz
  I2C_Init(IICSPEED, 0xa0, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, 2);
        //RDA5807P_Intialization();
*函数原型: unsigned char OperationRDAFM_2w(unsigned char operation, unsigned char *data, unsigned char numBytes)
*功  能: 读或者写数据到RDA5807P
operation 功能选择 读READ 或者写
data 读或者写的数据指针
numBytes 需要读或者写numBytes个字节
        unsigned char j;
  /* Send STRAT condition */
  I2C_GenerateSTART(ENABLE);
  /* Test on EV5 and clear it */
  while(!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT));
    if(operation == READ)
             I2C_Send7bitAddress(Radio_Address, I2C_DIRECTION_RX);
    else
             I2C_Send7bitAddress(Radio_Address, I2C_DIRECTION_TX);
  /* Test on EV6 and clear it */
  while(!I2C_CheckEvent(I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
        I2C_ClearFlag(I2C_FLAG_ADDRESSSENTMATCHED);
for(j = 0; j < numBytes; j++, data++)
    /* Test on EV7 and clear it */
    //if(I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_RECEIVED))
    while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_RECEIVED));
      /* Read a byte */
      *data = I2C_ReceiveData();
                if(j == (numBytes -1))
      /* Disable Acknowledgement */
      I2C_AcknowledgeConfig(I2C_ACK_NONE);
      /* Send STOP Condition */
      I2C_GenerateSTOP(ENABLE);
        else {
                I2C_SendData(*data);
   /* Send the byte to be written */
  /* Test on EV8 and clear it */
  while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* Send STOP condition */
      return 1;
*函数原型: void RDA5807P_Init(void)
*功  能: 初始化RDA5807P
/* OperationRDAFM_2w(WRITE, RDA5807P_reg, 8);  //上电
  RDA5807P_reg[1] |= 0x02;
  delayms(50);
  OperationRDAFM_2w(WRITE, RDA5807P_reg, 8); //软件复位
  RDA5807P_reg[1] &= ~(0x02);
  delayms(50);
  OperationRDAFM_2w(WRITE, RDA5807P_reg, 8); //上电*/
  RDA5807P_reg[1] = 0x02;//软复位
  OperationRDAFM_2w(WRITE, RDA5807P_reg, 2);
  delayms(5);
  RDA5807P_reg[1] = 0x01;
  OperationRDAFM_2w(WRITE, RDA5807P_reg, 8);//上电
*函数原型: void RDA5807P_PowerOffProc(void)
*功  能: 开机,关机RDA5807
void  RDA5807P_Power_Off_ON(void)
  static unsigned char flag = 0;
  flag ++;
  if(flag == 1)
   RDA5807P_reg[1] &= (~1);
  else if(flag == 2)
          RDA5807P_reg[1] |= 1;
          RDA5807P_SetFreq(9210);
          flag = 0;
*函数原型: void RDA5807P_Mute(unsigned char mute)
*功  能: 静音RDA5807
void RDA5807P_Mute(unsigned char vol_mute)
  if(vol_mute == mute)
          RDA5807P_reg[0] &= ~(1<<6);
  else if(vol_mute == NO_mute)
          RDA5807P_reg[0] |= 1<<6;
  delayms(50);    //delayms 50 ms
*函数原型: unsigned int RDA5807P_FreqToChan(unsigned int frequency)
*功  能: 通过频率设置信道chan
  unsigned char channelSpacing;
  unsigned int bottomOfBand;
  unsigned int channel;
  if ((RDA5807P_reg[3] & 0x0c) == 0x00)
          bottomOfBand = 8700;
  else if ((RDA5807P_reg[3] & 0x0c) == 0x04)
          bottomOfBand = 7600;
  else if ((RDA5807P_reg[3] & 0x0c) == 0x08)
  if ((RDA5807P_reg[3] & 0x03) == 0x00)
          channelSpacing = 10;
  else if ((RDA5807P_reg[3] & 0x03) == 0x01)
          channelSpacing = 20;
  else if ((RDA5807P_reg[3] & 0x03) == 0x02)
          channelSpacing = 5;
  channel = (frequency - bottomOfBand) / channelSpacing;
  return (channel);//10位的2进制数
*函数原型: unsigned int RDA5807P_ChanToFreq(unsigned int chan)
*功  能: 通过信道chan设置频率
  unsigned int freq;
          channelSpacing = 5;
  freq = bottomOfBand + chan * channelSpacing;
  return (freq);
*函数原型: void RDA5807P_SetFreq( unsigned int curFreq )
*功  能: 频率设置 调用RDA5807P_FreqToChan函数
  unsigned int curChan;
  curChan=RDA5807P_FreqToChan(curFreq);
  //SetNoMute
  RDA5807P_reg[0] |=        1<<7;
  RDA5807P_reg[2]=curChan>>2;
  RDA5807P_reg[3]=(((curChan&0x0003)<<6)|TUNE) | (RDA5807P_reg[3]&0x0f);        //set tune bit
  OperationRDAFM_2w(WRITE, RDA5807P_reg, 4);
  delayms(50);     //Delay five ms
  RDA5807P_reg[3] = RDA5807P_reg[3] & 0xef;
  curr_fre_chan();
*函数原型: static void curr_fre_chan(void)
*功  能: 保存当前频点及chan值
  Currchan = ((((unsigned int)( RDA5807P_reg[2])<<8) | (RDA5807P_reg[3]&0xc0))>>6);//保存当前频点
  CurrFrequency = Currchan * 10 + 8700;
*函数原型: unsigned char RDA5807P_GetSigLvl( unsigned int curf )
*功  能: 返回当前频率下的RSSI
unsigned char RDA5807P_GetSigLvl( void )
  unsigned char RDA5807P_reg_data[4]={0};
  OperationRDAFM_2w(READ,RDA5807P_reg_data, 4);
      delayms(50);    //Dealy 50 ms
  return  (RDA5807P_reg_data[2]>>1);  /*返回rssi*/
*函数原型: void RDA5807P_SetVolumeLevel(unsigned char level)
*功  能: 声音大小调节
  unsigned char RDA5807P_reg_data[8];
  unsigned char i = 0;
  unsigned char vol;//当前声音大小
  for (i=0;i<8;i++)
      RDA5807P_reg_data[i] = RDA5807P_reg[i];
  vol = (RDA5807P_reg_data[7] & 0x0f);
  if(vol_add == level)//声音增加
    if(vol == vol_max)
      RDA5807P_reg_data[7] = ( RDA5807P_reg_data[7] & 0xf0 )|vol;
    else
      RDA5807P_reg_data[7] = ( RDA5807P_reg_data[7] & 0xf0 )|(++vol);
  else if(vol_dec == level)//声音减小
          if(vol == vol_min)
          else
            RDA5807P_reg_data[7] = ( RDA5807P_reg_data[7] & 0xf0 )|(--vol);
/* for (i=0;i<8;i++)
      RDA5807P_reg[i] = RDA5807P_reg_data[i];*/
  RDA5807P_reg[7] = RDA5807P_reg_data[7];//保存当前VOL
  RDA5807P_reg_data[3] &= (~(TUNE));
  OperationRDAFM_2w(WRITE, RDA5807P_reg_data, 8);
i2c写正常,读的时候,第一次正常,第二次就不正常了,找不到错误呀,帮忙找下吧,谢谢大虾们了!
 楼主| machao070 发表于 2015-3-10 23:09 | 显示全部楼层
自己先顶一个。还有就是用的是复位后的hsi  2M
 楼主| machao070 发表于 2015-3-10 23:10 | 显示全部楼层
#ifndef _radio_h_
#define _radio_h_
//typedef unsigned char           uint8;
//typedef unsigned short int      uint16;
//typedef short int               int16;
//RA5807
#define Radio_WAddress 0x20
#define Radio_RAddress 0x21
#define Radio_Address 0x20
#define READ 1
#define WRITE 0
#define I2C_ACK  1
#define I2C_NACK 0
#define vol_add 1
#define vol_dec 0
#define vol_max 15
#define vol_min 0
#define mute 1
#define NO_mute 0
#define seek_up 1
#define seek_down 0
#define SEEKUP 0x02
#define SEEKDOWN (~SEEKUP)
#define SEEKON 0x01
#define TUNE 0x10
#define STC 0x40
#define READ_num 4
#define WRITE_num 8
//#define I2CRaido_Speed 400000
//#define I2CRaido_SLAVE_ADDRESS7 0xA0
static void delayms(uint16_t nCount);
RDA5807P interfaces
extern void RDA5807P_Init(void);//初始化RDA5807
extern void  RDA5807P_Power_Off_ON(void);//开机关机RDA5807
extern void RDA5807P_Mute(unsigned char vol_mute);//静音RDA5807
unsigned int RDA5807P_FreqToChan(unsigned int frequency);//通过频率设置信道chan
unsigned int RDA5807P_ChanToFreq(unsigned int chan);//通过信道chan设置频率
extern void RDA5807P_SetFreq( unsigned int curFreq );//频率设置 调用RDA5807P_FreqToChan函数
static void curr_fre_chan(void);
extern unsigned char RDA5807P_GetSigLvl( void );//返回当前频率下的RSSI
extern void RDA5807P_SetVolumeLevel(unsigned char level);//声音大小调节level==vol_add增加;level==vol_dec减小
static unsigned char RDA5807P_reg[];
/*I2C interface*/
#define IICSPEED 400000       //100K速度,时钟速度至少1M,400K速度,时钟速度至少4M
extern void InitIIC(void);
unsigned char OperationRDAFM_2w(unsigned char operation, unsigned char *data, unsigned char numBytes);
#endif
/******************* (C) COPYRIGHT 2014 LENCHIMCU.TAOBAO.COM ******************/
