[FPGA]
ILI9325 TFT驱动问题
2966|6
163hxing|  楼主 | 2015-3-11 23:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近在学习FPGA驱动TFT屏,手上有一块2.8寸的 ILI9325 TFT 屏,根据厂家给的初始化参数,写出了
Verilog驱动程序,但是一直未能显示,改了好久也不能成功,也未能找到原因,请大家帮我看看。我写
的代码和TFT屏的参数如下:
source code.zip (8.47 KB)
LCD_2.8SCH.pdf (215.37 KB)
ILI9325的初始化参数如下:
函数名:Lcd初始化函数
功能:初始化Lcd
入口参数:无
返回值:无
void Lcd_Initialize(void)
        Lcd_Light_ON;
        DataToWrite(0xffff);//数据线全高
        Set_nWr;
        Set_Cs;
        Set_Rs;
        Set_nRd;
        Set_Rst;
        Set_Rst;
        Delay_nms(1);
        Clr_Rst;
        Delay_nms(1);
        Set_Rst;
        Delay_nms(1);
#ifdef ILI9325
        LCD_WR_REG(0x00e3,0x3008);
        LCD_WR_REG(0x00e7,0x0012);
        LCD_WR_REG(0x00ef,0x1231);//Set the internal vcore voltage
        LCD_WR_REG(0x0001,0x0100);//S
#endif
#ifdef ILI9320
        LCD_WR_REG(0x00e5,0x8000);
        LCD_WR_REG(0x0000,0x0001);
        Delay_nms(10);
#endif
        LCD_WR_REG(0x0002,0x0700);//Line inversion
#if   ID_AM==000
        LCD_WR_REG(0x0003,0x0000);//屏幕旋转控制 TFM=0,TRI=0,SWAP=1,16 bits system interface  swap RGB to BRG,此处ORG和HWM 为0
#elif ID_AM==001
        LCD_WR_REG(0x0003,0x0008);
#elif ID_AM==010
        LCD_WR_REG(0x0003,0x0010);
#elif ID_AM==011
        LCD_WR_REG(0x0003,0x0018);
#elif ID_AM==100
        LCD_WR_REG(0x0003,0x0020);
#elif ID_AM==101
        LCD_WR_REG(0x0003,0x0028);
#elif ID_AM==110
        LCD_WR_REG(0x0003,0x0030);
#elif ID_AM==111
        LCD_WR_REG(0x0003,0x0038);
#endif
        LCD_WR_REG(0x0004,0x0000);
        LCD_WR_REG(0x0008,0x0207);
        LCD_WR_REG(0x0009,0x0000);
        LCD_WR_REG(0x000a,0x0000);
        LCD_WR_REG(0x000c,0x0001);//此处配置接口类型 16位 system接口
        LCD_WR_REG(0x000d,0x0000);
        LCD_WR_REG(0x000f,0x0000);
        //电源配置
        LCD_WR_REG(0x0010,0x0000);
        LCD_WR_REG(0x0011,0x0000);
        LCD_WR_REG(0x0012,0x0000);
        LCD_WR_REG(0x0013,0x0000);
        Delay_nms(200);
        LCD_WR_REG(0x0010,0x17b0);
        LCD_WR_REG(0x0011,0x0137);
        Delay_nms(50);
        LCD_WR_REG(0x0012,0x0139); /////从此处开始********************
        Delay_nms(50);
        LCD_WR_REG(0x0013,0x1700);
        LCD_WR_REG(0x0029,0x000c);
        //LCD_WR_REG(0x002b,0x000d);
        Delay_nms(50);
#if   ID_AM==000
        LCD_WR_REG(0x0020,0x00ef);//GRAM水平起始位置
        LCD_WR_REG(0x0021,0x013f);
#elif ID_AM==001
#elif ID_AM==010
        LCD_WR_REG(0x0020,0x0000);
#elif ID_AM==011
#elif ID_AM==100
        LCD_WR_REG(0x0021,0x0000);
#elif ID_AM==101
#elif ID_AM==110
#elif ID_AM==111
#endif
        LCD_WR_REG(0x0030,0x0000);
        LCD_WR_REG(0x0031,0x0507);
        LCD_WR_REG(0x0032,0x0104);
        LCD_WR_REG(0x0035,0x0105);
        LCD_WR_REG(0x0036,0x0404);
        LCD_WR_REG(0x0037,0x0603);
        LCD_WR_REG(0x0038,0x0004);
        LCD_WR_REG(0x0039,0x0007);
        LCD_WR_REG(0x003c,0x0501);
        LCD_WR_REG(0x003d,0x0404);
        LCD_WR_REG(0x0050,0x0000);//水平 GRAM起始位置
        LCD_WR_REG(0x0051,0x00ef);//水平GRAM终止位置
        LCD_WR_REG(0x0052,0x0000);//垂直GRAM起始位置
        LCD_WR_REG(0x0053,0x013f);//垂直GRAM终止位置
#ifdef ILI9325
        LCD_WR_REG(0x0060,0xa700);//G
#endif
#ifdef ILI9320
        LCD_WR_REG(0x0060,0x2700);//G
#endif
        LCD_WR_REG(0x0061,0x0001);//Enables the grayscale inversion of the image by setting REV=1.??????????????????????????????
        LCD_WR_REG(0x006a,0x0000);//不使用卷曲功能
        LCD_WR_REG(0x0080,0x0000);
        LCD_WR_REG(0x0081,0x0000);
        LCD_WR_REG(0x0082,0x0000);
        LCD_WR_REG(0x0083,0x0000);
        LCD_WR_REG(0x0084,0x0000);
        LCD_WR_REG(0x0085,0x0000);
        LCD_WR_REG(0x0090,0x0010);
        LCD_WR_REG(0x0092,0x0000);
        LCD_WR_REG(0x0093,0x0003);
        LCD_WR_REG(0x0095,0x0110);
        LCD_WR_REG(0x0097,0x0000);
        LCD_WR_REG(0x0098,0x0000);
        //显示画面写入 0x0130是不显示当前画面
        //0x0173是显示当前画面
        LCD_WR_REG(0x0007,0x0130);
#ifdef Immediately
        LCD_WR_REG(0x0007,0x0173);
#endif
        //第一个像素的读取数据是无效值,这里事先读取一次,舍去无效值
163hxing|  楼主 | 2015-3-12 22:30 | 只看该作者
求助啊
风魔小象| | 2015-3-16 19:56 | 只看该作者
写出他的读写时序,然后寄存器一个一个配置好就行啦。
163hxing|  楼主 | 2015-3-16 22:48 | 只看该作者
你好,谢谢你的回复,我是按照ILI9325提供的时序来操作的,但是一直是白屏,不显示任何图形。
弄了好长时间,都没搞好
弄了好长时间,都没搞好。你有没有时间呢,能否帮我看看,谢谢!
163hxing|  楼主 | 2015-5-26 23:01 | 只看该作者
仍然没有解决
qq1196117065| | 2015-6-23 17:10 | 只看该作者
楼主,我也是一直白屏。不知道你解决没有。@@1196117065。欢迎指导。
