| 对STM32进行软件开发时,最基本的就是对STM32芯片进行时钟和端口配置,然后是对项目所用到的片上资源进行配置并驱动,下面给出时钟和端口配置代码,该代码几乎涵盖了片上所有时钟和端口配置项目,可根据自己需要进行删除不必要的配置项: /******************************************************************************* * Function Name : RCC_Configuration 复位时钟控制配置 * Description : Configures the different system clocks. * Input : None * Output : None * Return : None *******************************************************************************/ void RCC_Configuration(void) { /* system clocks configuration -----------------系统时钟配置-------------------*/ /* RCC system reset(for debug purpose) */ RCC_DeInit(); //将外设RCC寄存器重设为缺省值 /* Enable HSE */ RCC_HSEConfig(RCC_HSE_ON); //开启外部高速晶振(HSE) /* Wait till HSE is ready */ HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待HSE起振 if(HSEStartUpStatus == SUCCESS) //若成功起振,(下面为系统总线时钟设置) { /* Enable Prefetch Buffer */ FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //使能FLASH预取指缓存 /* Flash 2 wait state */ FLASH_SetLatency(FLASH_Latency_2); //设置FLASH存储器延时时钟周期数(根据不同的系统时钟选取不同的值) /* HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); //设置AHB时钟=72 MHz /* PCLK2 = HCLK/2 */ RCC_PCLK2Config(RCC_HCLK_Div2); //设置APB1时钟=36 MHz(APB1时钟最大值) /* PCLK1 = HCLK/2 */ RCC_PCLK1Config(RCC_HCLK_Div1); //设置APB2时钟=72 MHz /* Configure ADCCLK such as ADCCLK = PCLK2/2 */ RCC_ADCCLKConfig(RCC_PCLK2_Div2); //RCC_PCLK2_Div2,4,6,8 /* PLLCLK = 8MHz * 9 = 72 MHz */ RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); //PLL必须在其激活前完成配置(设置PLL时钟源及倍频系数) /* Enable PLL */ RCC_PLLCmd(ENABLE); /* Wait till PLL is ready */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { } /* Select PLL as system clock source */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* Wait till PLL is used as system clock source */ while(RCC_GetSYSCLKSource() != 0x08) { } } /* Enable peripheral clocks -----------------外设时钟使能-------------------*/ /* Enable AHB peripheral clocks -----------------AHB外设时钟使能-------------------*/ /* Enable DMA clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//使能DMA时钟 /* Enable SRAM clock */ // RCC_AHBPeriphClockCmd(RCC_AHBPeriph_SRAM, ENABLE);//使能SRAM时钟 /* Enable FLITF clock */ // RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FLITF, ENABLE);//使能FLITF时钟 /* Enable APB1 peripheral clocks -----------------APB1外设时钟使能-------------------*/ /* TIM2,3,4 clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//使能TIM2时钟 if (APB1 prescaler="1") x1 // RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);//使能TIM3时钟 else x2 // RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);//使能TIM4时钟 /* WWDG clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);//使能WWDG时钟 /* Enable SPI2 clocks */ // RCC_APB1PeriphClockCmd(RCC_APB2Periph_SPI2, ENABLE);//使能SPI2时钟 /* USART2,3 clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);//使能USART2时钟(对应万利开发板上的USART1) // RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//使能USART3时钟(万利开发板上未接该串口) /* I2C1,2 clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);//使能I2C1时钟 // RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);//使能I2C2时钟 /* USB clock enable / PLL clock divided by 1.5 used as USB clock source */ // RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5); //根据不同PLLCLK选择分频比,必须确保USBCLK始终是48MHz // RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB, ENABLE);//使能USB时钟 /* CAN clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);//使能CAN时钟 /* BKP clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP, ENABLE);//使能BKP时钟 /* PWR clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);//使能PWR时钟 /* APB1Periph_ALL clock enable */ // RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL, ENABLE);/使能APB1Periph_ALL时钟 /* Enable APB2 peripheral clocks -----------------APB2外设时钟使能-------------------*/ /* Enable GPIOA,B,C,D,E clocks */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能GPIOA时钟 // RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能GPIOB时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能GPIOC时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能GPIOD时钟 // RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//使能GPIOE时钟 /* AFIO clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);////使能AFIO时钟 /* Enable ADC1,2clocks */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);//使能ADC1时钟 //RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);//使能ADC2时钟 /* TIM1 clock enable */ // RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//使能TIM1时钟 /* Enable SPI1 clocks */ // RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);//使能SPI1时钟 /* USART1 clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);//使能USART1时钟(对应万利开发板上的USART0) /* APB1Periph_ALL clock enable */ // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL, ENABLE);//使能APB2Periph_ALL时钟 /* Enable no peripheral clocks -----------------非总线上外设时钟配置-------------------*/ /* Enable Internal High Speed oscillator */ //RCC_HSICmd(ENABLE); /* Enable the Internal Low Speed oscillator */ //RCC_LSICmd(ENABLE); //给IWDG提供时钟信号(如果IWDG运行的话,LSI不能被失能) /* Configure RTCCLK such as ADCCLK = PCLK2/2 */ // RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);///* Select the LSE as RTC clock source */ // RCC_RTCCLKCmd(ENABLE);///* Enable the RTC clock */ /* Enable the Clock Security System */ //RCC_ClockSecuritySystemCmd(ENABLE); /* Output PLL clock divided by 2 on MCO pin */ //RCC_MCOConfig(RCC_MCO_PLLCLK_Div2);// 警告:当选中系统时钟作为MCO管脚的输出时,注意它的时钟频率不超过50MHz(最大I/O速率)。 } |
