**是一样的
4478|8
 楼主| andrewpei 发表于 2007-5-17 21:51 | 显示全部楼层 |阅读模式
我用**版的RVD1.8,可以比较好的支持H-JTAG,但是Multi-ICE反而支持不好。因为当我使用Multi-ICE联接SmartARM2200开发板时,竟然看到警告说:<br /><br />warning:&nbsp;vector&nbsp;catching&nbsp;specification&nbsp;is&nbsp;not&nbsp;support&nbsp;by&nbsp;the&nbsp;target<br /><br />请问有兄弟遇到过这种问题吗?如何解决?
wowow 发表于 2007-5-18 08:43 | 显示全部楼层
我用RVDS2.2+multi-ice没有这种问题
 楼主| andrewpei 发表于 2007-5-18 09:49 | 显示全部楼层
to wowow
请问wowow,你的realview是这样搞定的吗?我的是在XP&nbsp;SP2&nbsp;的番茄花园版系统下使用的。<br /><br />install,&nbsp;apply&nbsp;our&nbsp;patch&nbsp;then&nbsp;generate&nbsp;license&nbsp;file&nbsp;with&nbsp;the&nbsp;keygen.<br />-------------<br />the&nbsp;files&nbsp;need&nbsp;to&nbsp;be&nbsp;patched:<br /><br />%Install&nbsp;Path%IDEsCodeWarriorCodeWarrior5.6.11592win_32-pentiuminPluginsLicenseoemlicense.dll<br />%Install&nbsp;Path%IDEsCodeWarriorRVPlugins1.086win_32-pentiumoemlicenseoemlicense.dll<br />%Install&nbsp;Path%RDIarmsd1.3.166win_32-pentiumarmsd.exe<br />%Install&nbsp;Path%RDIAXD1.3.198win_32-pentiumaxd.exe<br />%Install&nbsp;Path%RVCTPrograms2.2349win_32-pentiumarmasm.exe<br />%Install&nbsp;Path%RVCTPrograms2.2349win_32-pentiumarmcc.exe<br />%Install&nbsp;Path%RVCTPrograms2.2349win_32-pentiumarmcpp.exe<br />%Install&nbsp;Path%RVCTPrograms2.2349win_32-pentiumarmlink.exe<br />%Install&nbsp;Path%RVCTPrograms2.2349win_32-pentiumfromelf.exe<br />%Install&nbsp;Path%RVCTPrograms2.2349win_32-pentium        cc.exe<br />%Install&nbsp;Path%RVCTPrograms2.2349win_32-pentium        cpp.exe<br />%Install&nbsp;Path%RVDCore1.8734win_32-pentiumin        vs.exe<br />%Install&nbsp;Path%RVDCore1.8734win_32-pentiuminxry100.dll<br />%Install&nbsp;Path%RVARMulatorARMulator1.4.1206win_32-pentiumarmiss.sdi&nbsp;<br />%Install&nbsp;Path%RVARMulatorARMulator1.4.1206win_32-pentiumarmulate.sdi&nbsp;<br />%Install&nbsp;Path%RVARMulatorARMulator1.4.1206win_32-pentiumv6armiss.sdi&nbsp;<br />%Install&nbsp;Path%RVARMulatorv6ARMulator1.4.1238win_32-pentiumv6thumb2.sdi&nbsp;<br />%Install&nbsp;Path%RVARMulatorv6ARMulator1.4.1238win_32-pentiumv6trustzone.sdi&nbsp;<br /><br />TEAM&nbsp;Z.W.T&nbsp;2005
 楼主| andrewpei 发表于 2007-5-18 10:01 | 显示全部楼层
再to wowow
我升级Multi-ICE到2.2.6版了,但是只动了Multi-ICE安装文件夹下的几个文件,没有动RealView2.2安装文件夹下的内容。因为我只看到Multi-ICE的升级文件说明中只提到了RealView2.1版和RealView2.0。<br /><br /><br />我的使用情况是绝大多数情况下会出这个警告,在register窗口的debug&nbsp;tab内看不到vector_catch这个内部调试变量。只是偶而不会出这个警告,在register窗口的debug&nbsp;tab内可以看到vector_catch这个内部调试变量。<br />
wowow 发表于 2007-5-18 11:51 | 显示全部楼层
**是一样的
Realview的破解是一样的。RVDebug原配的是1.8.0&nbsp;build&nbsp;734,后来换成1.8.1&nbsp;build&nbsp;497(一样的方法破解),两个都能用,貌似后者稳定一些。<br /><br />MultiIce也升级到2.2.6<br /><br />XP我用的是秋无痕的版本。番茄花园以前有一个版本破解keil死活破不了,重装N次,换“WINDOWS&nbsp;XP&nbsp;SP2&nbsp;集成安装2006夏季版(秋无痕&nbsp;制作)”就好了。原因一直没弄明白,就再没用番茄花园了。<br /><br />“在register窗口的debug&nbsp;tab内看不到vector_catch这个内部调试变量”这个我没试过,手头上现在没做ARM的项目。
 楼主| andrewpei 发表于 2007-5-18 12:03 | 显示全部楼层
谢谢wowow,那么我想再深入问一下!
哪里可以搞到RVD1.1.1&nbsp;build497,这个好象是ARM公司发行的RealView&nbsp;2.2&nbsp;SP1,&nbsp;是用光盘发行的,怎么样能搞到这个版本?方便的话,可否给一点线索呢?<br /><br />我的电邮sclzpjm@163.com
wowow 发表于 2007-5-18 13:59 | 显示全部楼层
ARM网站上就有下的啊
http://www.arm.com/support/downloads/rvds22.html<br /><br />一直想找3.0的套件没找到。现在用的是Keil&nbsp;for&nbsp;arm里的RVCT&nbsp;3.0编译,RVDS&nbsp;2.2里的RVDebug调试
 楼主| andrewpei 发表于 2007-5-20 20:17 | 显示全部楼层
WOWOW请看过来!
现在网上所流传的RVDS2.2,其内含的RVD版本正是ARM公司网站上所说的RVD&nbsp;v1.8&nbsp;build&nbsp;734,而你所给的那个链接是不兼容这个版本的,所以看起来好像不能下载来直接升级,必须搞到光盘版发行的RVD&nbsp;v1.8.1&nbsp;build&nbsp;464。<br /><br />以下是我看到的ARM公司网站的说明,不知理解是否有误?<br />This&nbsp;patch&nbsp;can&nbsp;only&nbsp;be&nbsp;applied&nbsp;to&nbsp;an&nbsp;existing&nbsp;RVDS&nbsp;v2.2.1&nbsp;(RVD&nbsp;v1.8.1&nbsp;build&nbsp;464)&nbsp;for&nbsp;Windows&nbsp;install.&nbsp;To&nbsp;identify&nbsp;the&nbsp;build&nbsp;of&nbsp;RVD&nbsp;you&nbsp;are&nbsp;using,&nbsp;start&nbsp;the&nbsp;debugger&nbsp;and&nbsp;select&nbsp;Help&nbsp;--&gt&nbsp;About&nbsp;from&nbsp;the&nbsp;main&nbsp;menu.&nbsp;<br /><br />Note:<br />The&nbsp;patch&nbsp;is&nbsp;NOT&nbsp;compatible&nbsp;with&nbsp;the&nbsp;base&nbsp;RVDS&nbsp;v2.2&nbsp;(RVD&nbsp;v1.8&nbsp;build&nbsp;734),&nbsp;RVDS&nbsp;evaluation&nbsp;versions&nbsp;or&nbsp;RVDK&nbsp;products.&nbsp;If&nbsp;you&nbsp;are&nbsp;currently&nbsp;using&nbsp;RVDS&nbsp;v2.2&nbsp;please&nbsp;request&nbsp;an&nbsp;RVDS&nbsp;v2.2.1&nbsp;upgrade&nbsp;CD&nbsp;first&nbsp;from&nbsp;your&nbsp;tools&nbsp;supplier<br />
wowow 发表于 2007-5-21 09:37 | 显示全部楼层
我是直接覆盖的
我也看到了那个警告,覆盖前备份一下试试就是了,反正我用得挺好。
