请教s3c44b0x的cache问题
2320|1
 楼主| hitoolarm 发表于 2008-7-30 21:10 | 显示全部楼层 |阅读模式
请教s3c44b0x的cache问题<br />请教s3c44b0x的cache问题<br />数据手册的191页上写道:<br />Cache&nbsp;Replace&nbsp;Operation<br />After&nbsp;a&nbsp;system&nbsp;is&nbsp;initialized,&nbsp;the&nbsp;value&nbsp;of&nbsp;CS&nbsp;is&nbsp;set&nbsp;to&nbsp;&quot;0000&quot;,&nbsp;signifying&nbsp;that&nbsp;the&nbsp;contents&nbsp;of&nbsp;set&nbsp;0,&nbsp;set1,&nbsp;set2&nbsp;and&nbsp;set<br />3&nbsp;cache&nbsp;memories&nbsp;are&nbsp;invalid.&nbsp;When&nbsp;a&nbsp;cache&nbsp;fill&nbsp;occurs,&nbsp;the&nbsp;value&nbsp;of&nbsp;CS&nbsp;is&nbsp;changed&nbsp;to&nbsp;&quot;0110&quot;&nbsp;at&nbsp;the&nbsp;specified&nbsp;line,<br />which&nbsp;signifies&nbsp;that&nbsp;only&nbsp;set&nbsp;0&nbsp;is&nbsp;valid.&nbsp;When&nbsp;the&nbsp;subsequent&nbsp;cache&nbsp;fill&nbsp;occurs,&nbsp;the&nbsp;value&nbsp;of&nbsp;CS&nbsp;will&nbsp;be&nbsp;&quot;0011&quot;&nbsp;at&nbsp;the<br />specified&nbsp;line,&nbsp;which&nbsp;represents&nbsp;that&nbsp;contents&nbsp;of&nbsp;both&nbsp;set&nbsp;0&nbsp;and&nbsp;set&nbsp;2&nbsp;are&nbsp;valid.&nbsp;When&nbsp;the&nbsp;subsequent&nbsp;cache&nbsp;fill<br />occurs,&nbsp;the&nbsp;value&nbsp;of&nbsp;CS&nbsp;will&nbsp;be&nbsp;&quot;0101&quot;&nbsp;at&nbsp;the&nbsp;specified&nbsp;line,&nbsp;which&nbsp;represents&nbsp;that&nbsp;contents&nbsp;of&nbsp;set&nbsp;0,&nbsp;set&nbsp;1,&nbsp;and&nbsp;set&nbsp;2<br />are&nbsp;valid.&nbsp;And&nbsp;succesive&nbsp;cache&nbsp;fill&nbsp;make&nbsp;CS&nbsp;&quot;1000&quot;&nbsp;at&nbsp;the&nbsp;specified&nbsp;line,&nbsp;which&nbsp;represents&nbsp;that&nbsp;all&nbsp;caches&nbsp;are&nbsp;valid.<br />========================================================================<br />我不理解的地方:<br />1.&nbsp;CS是什么东西?没有解释啊.<br />2.&nbsp;为什么CS的内容为0110时,选择set&nbsp;0,有什么规律或原则?<br /><br /><br />请教各位了.&nbsp;
 楼主| hitoolarm 发表于 2008-7-31 14:13 | 显示全部楼层
感谢楼上的哥们回复.
