* Function Name : USB_Istr
* Description : STR events interrupt service routine
* Input :
* Output :
* Return :
void USB_Istr(void)
wIstr = _GetISTR();
#if (IMR_MSK & ISTR_RESET)
if (wIstr & ISTR_RESET & wInterrupt_Mask) //这个是复位吧
_SetISTR((u16)CLR_RESET);
Device_Property.Reset();
#ifdef RESET_CALLBACK
RESET_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_DOVR) //这个是什么意思
if (wIstr & ISTR_DOVR & wInterrupt_Mask)
_SetISTR((u16)CLR_DOVR);
#ifdef DOVR_CALLBACK
DOVR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ERR) //这个是错误
if (wIstr & ISTR_ERR & wInterrupt_Mask)
_SetISTR((u16)CLR_ERR);
#ifdef ERR_CALLBACK
ERR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_WKUP) //这个是唤醒
if (wIstr & ISTR_WKUP & wInterrupt_Mask)
_SetISTR((u16)CLR_WKUP);
Resume(RESUME_EXTERNAL);
#ifdef WKUP_CALLBACK
WKUP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_SUSP) //这个是悬挂的意思吧?
if (wIstr & ISTR_SUSP & wInterrupt_Mask)
/* check if SUSPEND is possible */
if (fSuspendEnabled)
Suspend();
else
/* if not possible then resume after xx ms */
Resume(RESUME_LATER);
/* clear of the ISTR bit must be done after setting of CNTR_FSUSP */
_SetISTR((u16)CLR_SUSP);
#ifdef SUSP_CALLBACK
SUSP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_SOF) //这个是什么意思?
if (wIstr & ISTR_SOF & wInterrupt_Mask)
_SetISTR((u16)CLR_SOF);
bIntPackSOF++;
#ifdef SOF_CALLBACK
SOF_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ESOF) //这个又是什么意思
if (wIstr & ISTR_ESOF & wInterrupt_Mask)
_SetISTR((u16)CLR_ESOF);
/* resume handling timing is made with ESOFs */
Resume(RESUME_ESOF); /* request without change of the machine state */
#ifdef ESOF_CALLBACK
ESOF_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_CTR) //这个也不明白
if (wIstr & ISTR_CTR & wInterrupt_Mask)
/* servicing of the endpoint correct transfer interrupt */
/* clear of the CTR flag into the sub */
CTR_LP();
#ifdef CTR_CALLBACK
CTR_Callback();
#endif
#endif
} /* USB_Istr */
我在STM32F103 USB例程里看到USB中断里的一段程序,看不太懂。
请高手指教,谢谢!
