这是一个液晶程序的底层驱动的几个函数,原来在51中可以正常工作,移植到LPC2114上却不行了.<br />它是16位数据方式,在51中P1输出高8位,P0输出低8位,<br />在2114中P0.0~P0.15为数据,P0.16~20为控制信号<br /><br /><br />#define LCD_RST (1<<20) //复位<br />#define LCD_RD (1<<19) //读<br />#define LCD_WR (1<<18) //写<br />#define LCD_RS (1<<17) //命令<br />#define LCD_CE (1<<16) //片选<br /><br />/******************DRIVE IC寄存器寻址 8080 SERIES*******************************/<br />void write_command(uint8 addr1,uint8 addr2)<br />{ <br /> IO0CLR = LCD_RS; //rs=0;<br /> IO0CLR = LCD_CE ; //ce=0;<br /> IO0SET = LCD_RD; //rd=1;<br /> <br /> //OutData((addr1<<8)+addr2); <br /> IO0CLR = 0xffff; <br /> IO0SET = (addr1<<8)&0xff00; //p1=dat1;<br /> IO0SET = addr2 & 0xff; //p0=dat2;<br /> <br /> IO0CLR = LCD_WR; //wr=0;<br /> IO0SET = LCD_WR; //wr=1;<br /> IO0SET = LCD_CE; //ce=1;<br />}<br /><br />/*****************DRIVE IC寄存器写数据 8080 SERIES******************************/<br />void write_para(uint8 para1,uint8 para2)<br />{ <br /> <br /> IO0SET = LCD_RS; //rs=1;<br /> IO0CLR = LCD_CE ; //ce=0;<br /> IO0SET = LCD_RD; //rd=1;<br /> //OutData((para1<<8)+para2); <br /> IO0CLR = 0xffff;<br /> IO0SET = (para1<<8)&0xff00; //p1=para1;<br /> IO0SET = para2 & 0xff; //p0=pata2;<br /> <br /> IO0CLR = LCD_WR; //wr=0;<br /> IO0SET = LCD_WR; //wr=1;<br /> IO0SET = LCD_CE; //ce=1<br />}<br /> <br />/****************DRIVE IC GDRAM 写数据 16BITS 8080 SERIES*****************************/<br />void write_data(uint8 dat1,uint8 dat2)<br />{ <br /> IO0SET = LCD_RS; //rs=1;<br /> IO0CLR = LCD_CE ; //ce=0;<br /> IO0SET = LCD_RD; //rd=1;<br /> <br /> //OutData((dat1<<8)+dat2);<br /> IO0CLR = 0xffff;<br /> IO0SET = (dat1<<8)&0xff00; //p1=dat1;<br /> IO0SET = dat2 & 0xff; //p0=dat2;<br /> <br /> IO0CLR = LCD_WR; //wr=0;<br /> IO0SET = LCD_WR; //wr=1;<br /> IO0SET = LCD_CE; //ce=1<br />} |
