Ionic wind may improve the cooling rate by 250%.
2443|3
 楼主| jz0095 发表于 2007-8-22 14:12 | 显示全部楼层 |阅读模式
TE, ni, IO, Wind, ic
A&nbsp;bit&nbsp;long,&nbsp;but&nbsp;interesting&nbsp;reading&nbsp;material.<br /><br />The&nbsp;link&nbsp;is&nbsp;working&nbsp;now.&nbsp;Thanks&nbsp;IC921.<br /> 相关链接:<a href='http://www.rfglobalnet.com/content/news/article.asp?docid=4985096e-f418-4a1d-8e23-043b3cb3c699'>http://www.rfglobalnet.com/content/news/article.asp?docid=4985096e-f418-4a1d-8e23-043b3cb3c699</a>
iC921 发表于 2007-8-22 16:27 | 显示全部楼层
Ionic wind 是什么特殊“材料”?
iC921 发表于 2007-8-22 16:28 | 显示全部楼层
链接打不开
http://http://www.rfglobalnet.com/content/news/article.asp?docid=4985096e-f418-4a1d-8e23-043b3cb3c699
 楼主| jz0095 发表于 2007-8-23 06:06 | 显示全部楼层
Thanks IC921,
我没想到会打不开。<br />“Ionic&nbsp;wind&quot;,离子风,its&nbsp;mechanism&nbsp;is&nbsp;qouted&nbsp;below,<br /><br />&quot;The&nbsp;experimental&nbsp;cooling&nbsp;device,&nbsp;which&nbsp;was&nbsp;fabricated&nbsp;on&nbsp;top&nbsp;of&nbsp;a&nbsp;mock&nbsp;computer&nbsp;chip,&nbsp;works&nbsp;by&nbsp;generating&nbsp;ions&nbsp;-&nbsp;or&nbsp;electrically&nbsp;charged&nbsp;atoms&nbsp;-&nbsp;using&nbsp;electrodes&nbsp;placed&nbsp;near&nbsp;one&nbsp;another.&nbsp;The&nbsp;device&nbsp;contained&nbsp;a&nbsp;positively&nbsp;charged&nbsp;wire,&nbsp;or&nbsp;anode,&nbsp;and&nbsp;negatively&nbsp;charged&nbsp;electrodes,&nbsp;called&nbsp;cathodes.&nbsp;The&nbsp;anode&nbsp;was&nbsp;positioned&nbsp;about&nbsp;10&nbsp;millimeters&nbsp;above&nbsp;the&nbsp;cathodes.&nbsp;When&nbsp;voltage&nbsp;was&nbsp;passed&nbsp;through&nbsp;the&nbsp;device,&nbsp;the&nbsp;negatively&nbsp;charged&nbsp;electrodes&nbsp;discharged&nbsp;electrons&nbsp;toward&nbsp;the&nbsp;positively&nbsp;charged&nbsp;anode.&nbsp;Along&nbsp;the&nbsp;way,&nbsp;the&nbsp;electrons&nbsp;collided&nbsp;with&nbsp;air&nbsp;molecules,&nbsp;producing&nbsp;positively&nbsp;charged&nbsp;ions,&nbsp;which&nbsp;were&nbsp;then&nbsp;attracted&nbsp;back&nbsp;toward&nbsp;the&nbsp;negatively&nbsp;charged&nbsp;electrodes,&nbsp;creating&nbsp;an&nbsp;&quot;ionic&nbsp;wind.&quot;&nbsp;&quot;
