ST9xx MCLK 96Mhz 单步执行,出错无法进行下!
3748|4
 楼主| 加加 发表于 2007-9-3 10:58 | 显示全部楼层 |阅读模式
hz, ST, IO, TI, pi
 GPIO_InitTypeDef  GPIO_InitStructure;
  TIM_InitTypeDef   TIM_InitStructure;
  UART_InitTypeDef UART_InitStructure;
  #if 1
/* SYSTEM CLOCK Configuration ------------------------------------------------*/
  //CPU = 25MHZ
  SCU_MCLKSourceConfig(SCU_MCLK_OSC);
  SCU_RCLKDivisorConfig(SCU_RCLK_Div1024);//执这里出错
  //PLL = 96MHz
  SCU_PLLCmd(DISABLE);
  SCU_PLLFactorsConfig(0xC0,0x19,0x2);
  SCU_PLLCmd(ENABLE);
  //CPU = 96MHZ
  SCU_MCLKSourceConfig(SCU_MCLK_PLL);
#endif
  SCU_AHBPeriphClockConfig(__VIC, ENABLE);
  VIC_DeInit();
  /* VIC configuration */
  VIC_Config(TIM0_ITLine, VIC_IRQ, TIM0_ITLine);
  VIC_ITCmd(TIM0_ITLine, ENABLE);
  VIC_Config(UART0_ITLine, VIC_IRQ, UART0_ITLine);
  VIC_ITCmd(UART0_ITLine, ENABLE);
/* TIMER Configuration -------------------------------------------------------*/
  /* TIM0 Deinitialization */
  SCU_APBPeriphClockConfig(__TIM01, ENABLE); /* Enable the clock for TIM0 and TIM1 */
  TIM_DeInit(TIM0);
  /* TIM0 Structure Initialization */
  TIM_StructInit(&TIM_InitStructure);
  TIM_InitStructure.TIM_Mode = TIM_OCM_CHANNEL_1;
  TIM_InitStructure.TIM_Clock_Source = TIM_CLK_APB;
  TIM_InitStructure.TIM_Prescaler = 0;
  TIM_InitStructure.TIM_Pulse_Level_1 = TIM_HIGH;
  TIM_InitStructure.TIM_Period_Level = TIM_LOW;
  TIM_InitStructure.TIM_Pulse_Length_1 = 0x200;
  TIM_InitStructure.TIM_Full_Period = 0x404;
  TIM_InitStructure.TIM_OC1_Modes=TIM_TIMING;
  TIM_Init (TIM0, &TIM_InitStructure);
  /* Clear TIM0 ISR registers */
  TIM_ClearFlag(TIM0, TIM_FLAG_OC1| TIM_FLAG_OC2| TIM_FLAG_TO|TIM_FLAG_IC1|TIM_FLAG_IC2);
  /* Enable TIM0 IC1 interrupt */
  TIM_ITConfig(TIM0, TIM_IT_OC1, ENABLE);
  /* Start the counter of TIM0 */
  TIM_CounterCmd(TIM0, TIM_START);
/* GPIO Configuration --------------------------------------------------------*/
  SCU_APBPeriphClockConfig(__GPIO3, ENABLE); /* Enable the clock for GPIO3 */
  GPIO_DeInit(GPIO3);                        /* GPIO3 Deinitialization */
  GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;//GPIO_Pin_0 |GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ;
  GPIO_InitStructure.GPIO_Alternate=GPIO_OutputAlt1;
  GPIO_Init (GPIO3, &GPIO_InitStructure);
   /*Gonfigure UART0_Tx pin GPIO3.4*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3  ;
  GPIO_DeInit(GPIO5);
  /*Gonfigure UART0_Rx pin GPIO5.1*/
  GPIO_InitStructure.GPIO_Direction = GPIO_PinInput;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_IPConnected = GPIO_IPConnected_Enable;
  GPIO_Init (GPIO5, &GPIO_InitStructure);
/* UART Configuration --------------------------------------------------------*/
  SCU_APBPeriphClockConfig(__UART0, ENABLE);
  UART_InitStructure.UART_WordLength = UART_WordLength_8D;
  UART_InitStructure.UART_StopBits = UART_StopBits_1;
  UART_InitStructure.UART_Parity = UART_Parity_No ;
  UART_InitStructure.UART_BaudRate = 115200;
  UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None;
  UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx;
  UART_InitStructure.UART_FIFO = UART_FIFO_Enable;
  UART_InitStructure.UART_TxFIFOLevel = UART_FIFOLevel_1_2; /* FIFO size 16 bytes, FIFO level 8 bytes */
  UART_InitStructure.UART_RxFIFOLevel = UART_FIFOLevel_1_2; /* FIFO size 16 bytes, FIFO level 8 bytes */
  UART_DeInit(UART0);
  UART_Init(UART0, &UART_InitStructure);
  /* Clear UART flags*/
  UART_ClearFlag(UART0);
  /* Enable UART interrupt */
  UART_ITConfig(UART0, UART_IT_Receive, ENABLE);
  /* Enable the UART0 */
  UART_Cmd(UART0, ENABLE);
为什么会这样,请各位大侠帮我看看,究竟是怎么回事?有什么办法解决!谢谢各位了!
ST_ARM 发表于 2007-9-3 13:02 | 显示全部楼层
什么错误?
没有说明清楚。
浪淘沙 发表于 2007-9-3 13:17 | 显示全部楼层
LZ说“单步执行出错”,是否意味着连续运行正确?
不是所有部分都是可以单步运行的,“连续运行正确但单步执行出错”,很可能就是这个原因。
 楼主| 加加 发表于 2007-9-3 16:27 | 显示全部楼层
连续可以正常运行,如果是单步执行运行 DEBUG错误中止.
如果MCLK 是25Mhz  就不会出现这个问题!是不是我的设置CLOCK 有问题哦?
STF 发表于 2007-9-7 15:02 | 显示全部楼层
flash的等待
你好,
你有没有配置flash的等待?
你的频率是66MHz以上的话你一定要用两个等待,96Mhz没有配置这个的话STR9会死掉。
你可以试一试最前面用这个函数:
FMI_Config(FMI_READ_WAIT_STATE_2, FMI_WRITE_WAIT_STATE_0, FMI_PWD_ENABLE,
             FMI_LVD_ENABLE, FMI_FREQ_HIGH); /* FMI Waite States */
Best Regards,
Stephane
