今天用库函数跑下RTT,这个程序很简单用串口同单片机通读,可以输入R复位RTT,也可输入S来设定报警时间、
程序如下:
- #include "asf.h"
- #include "stdio_serial.h"
- #include "conf_board.h"
- #include "conf_clock.h"
- /** Device state: in the main menu. */
- #define STATE_MAIN_MENU 0
- /** Device state: user is setting an alarm time. */
- #define STATE_SET_ALARM 1
- /** ASCII char definition for backspace. */
- #define ASCII_BS 8
- /** ASCII char definition for carriage return. */
- #define ASCII_CR 13
- #define STRING_EOL "\r"
- #define STRING_HEADER "-- RTT Example --\r\n" \
- "-- "BOARD_NAME" --\r\n" \
- "-- Compiled: "__DATE__" "__TIME__" --"STRING_EOL
- /** Current device state. */
- volatile uint8_t g_uc_state;
- /** New alarm time being currently entered. */
- volatile uint32_t g_ul_new_alarm;
- /** Indicate that an alarm has occurred but has not been cleared. */
- volatile uint8_t g_uc_alarmed;
- * \brief Refresh display on terminal.
- * Update the terminal display to show the current menu and the current time
- * depending on the device state.
- static void refresh_display(void)
- printf("%c[2J\r", 27);
- printf("Time: %u\n\r", (unsigned int)rtt_read_timer_value(RTT));
- /* Display alarm */
- if (g_uc_alarmed) {
- puts("!!! ALARM !!!\r");
- /* Main menu */
- if (g_uc_state == STATE_MAIN_MENU) {
- puts("Menu:\n\r"
- " r - Reset timer\n\r"
- " s - Set alarm\r");
- puts(" c - Clear alarm notification\r");
- puts("\n\rChoice? ");
- } else {
- if (g_uc_state == STATE_SET_ALARM) {
- puts("Enter alarm time: ");
- if (g_ul_new_alarm != 0) {
- printf("%u", (unsigned)g_ul_new_alarm);
- * \brief RTT configuration function.
- * Configure the RTT to generate a one second tick, which triggers the RTTINC
- * interrupt.
- static void configure_rtt(void)
- uint32_t ul_previous_time;
- /* Configure RTT for a 1 second tick interrupt */
- #if SAM4N || SAM4S || SAM4E || SAM4C || SAM4CP || SAM4CM || SAMV71 || SAMV70 || SAME70 || SAMS70
- rtt_sel_source(RTT, false);
- #endif
- rtt_init(RTT, 32768);
- ul_previous_time = rtt_read_timer_value(RTT);
- while (ul_previous_time == rtt_read_timer_value(RTT));
- /* Enable RTT interrupt */
- NVIC_DisableIRQ(RTT_IRQn);
- NVIC_ClearPendingIRQ(RTT_IRQn);
- NVIC_SetPriority(RTT_IRQn, 0);
- NVIC_EnableIRQ(RTT_IRQn);
- rtt_enable_interrupt(RTT, RTT_MR_RTTINCIEN);
- * \brief Configure the console UART.
- static void configure_console(void)
- const usart_serial_options_t uart_serial_options = {
- .baudrate = CONF_UART_BAUDRATE,
- #ifdef CONF_UART_CHAR_LENGTH
- .charlength = CONF_UART_CHAR_LENGTH,
- #endif
- .paritytype = CONF_UART_PARITY,
- #ifdef CONF_UART_STOP_BITS
- .stopbits = CONF_UART_STOP_BITS,
- #endif
- /* Configure console UART. */
- sysclk_enable_peripheral_clock(CONSOLE_UART_ID);
- stdio_serial_init(CONF_UART, &uart_serial_options);
- * \brief Interrupt handler for the RTT.
- * Display the current time on the terminal.
- void RTT_Handler(void)
- uint32_t ul_status;
- /* Get RTT status */
- ul_status = rtt_get_status(RTT);
- /* Time has changed, refresh display */
- if ((ul_status & RTT_SR_RTTINC) == RTT_SR_RTTINC) {
- refresh_display();
- /* Alarm */
- if ((ul_status & RTT_SR_ALMS) == RTT_SR_ALMS) {
- g_uc_alarmed = 1;
- * \brief Application entry point for RTT example.
- * Initialize the RTT, display the current time and allow the user to
- * perform several actions: clear the timer, set an alarm, etc.
- * \return Unused (ANSI-C compatibility).
- int main(void)
- uint8_t c;
- /* Initialize the SAM system */
- sysclk_init();
- board_init();
- /* Configure console UART */
- configure_console();
- /* Output example information */
- puts(STRING_HEADER);
- /* Configure RTT */
- configure_rtt();
- /* Initialize state machine */
- g_uc_state = STATE_MAIN_MENU;
- g_uc_alarmed = 0;
- /* User input loop */
- while (1) {
- /* Wait for user input */
- scanf("%c", (char *)&c);
- /* Main menu mode */
- /* Reset timer */
- if (c == 'r') {
- configure_rtt();
- } else if (c == 's') { /* Set alarm */
- g_uc_state = STATE_SET_ALARM;
- g_ul_new_alarm = 0;
- } else { /* Clear alarm */
- if ((c == 'c') && g_uc_alarmed) {
- g_uc_alarmed = 0;
- } else if (g_uc_state == STATE_SET_ALARM) { /* Set alarm mode */
- /* Number */
- if ((c >= '0') && (c <= '9')) {
- g_ul_new_alarm = g_ul_new_alarm * 10 + c - '0';
- } else if (c == ASCII_BS) {
- printf("%c", c);
- g_ul_new_alarm /= 10;
- } else if (c == ASCII_CR) {
- /* Avoid newAlarm = 0 case */
- rtt_write_alarm_time(RTT, g_ul_new_alarm);
以下是运行截图:
