[i.MX] imx6dl yocto+eim+st16c554问题
1320|3
 楼主| x_ll_x 发表于 2015-12-22 14:32 | 显示全部楼层 |阅读模式
内核使用3.14.28版本,要添加一个st16c554的扩展串口,设备树配置为如下:
uart8250_1{
                pinctrl-names = "default";
                pinctrl-0 = <&pinctrl_uart8250_1>;
                compatible = "ns16550a";
                clock-frequency = <11059200>;
                interrupt-parent = <&gpio1>;
                interrupts = <10 2>;
                gpio_int = <&gpio1 10 2>;
                reg = <0x8000000 0x1000>;
                //fifo-size = <10>;
                //current-speed = <115200>;
                reg-shift = <1>;
                reg-io-width = <2>; //1:8位 2:16位
                reg-offset = <16>;        //16:0x10
                no-loopback-test;
                status = "okay";
make menuconfig下已经配置了8250_core与of_serial文件,现在发现serial8250_probe已经进入,但是没有配置的资源,for循环进不去。/dev下有ttyS0,应用程序运行出错:ttyS0: LSR safety check engaged!。
serial8250_probe如下:
static int serial8250_probe(struct platform_device *dev)
        struct plat_serial8250_port *p = dev_get_platdata(&dev->dev);
        struct uart_8250_port uart;
        int ret, i, irqflag = 0;
        memset(&uart, 0, sizeof(uart));
        if (share_irqs)
                irqflag = IRQF_SHARED;
        for (i = 0; p && p->flags != 0; p++, i++) {
                printk("iobase=0x%x\n",p->iobase);
                uart.port.iobase        = p->iobase;
                uart.port.membase        = p->membase;
                uart.port.irq                = p->irq;
                uart.port.irqflags        = p->irqflags;
                uart.port.uartclk        = p->uartclk;
                uart.port.regshift        = p->regshift;
                uart.port.iotype        = p->iotype;
                uart.port.flags                = p->flags;
                uart.port.mapbase        = p->mapbase;
                uart.port.hub6                = p->hub6;
                uart.port.private_data        = p->private_data;
                uart.port.type                = p->type;
                uart.port.serial_in        = p->serial_in;
                uart.port.serial_out        = p->serial_out;
                uart.port.handle_irq        = p->handle_irq;
                uart.port.handle_break        = p->handle_break;
                uart.port.set_termios        = p->set_termios;
                uart.port.pm                = p->pm;
                uart.port.dev                = &dev->dev;
                uart.port.irqflags        |= irqflag;
                ret = serial8250_register_8250_port(&uart);
                if (ret < 0) {
                        dev_err(&dev->dev, "unable to register port at index %d "
                                "(IO%lx MEM%llx IRQ%d): %d\n", i,
                                p->iobase, (unsigned long long)p->mapbase,
                                p->irq, ret);
        return 0;
 楼主| x_ll_x 发表于 2015-12-22 14:34 | 显示全部楼层
有大神遇到过吗???求方法,积分可加
NXP_TICS_Rita 发表于 2015-12-22 17:40 | 显示全部楼层
楼主你好,这个问题建议你到我们的官网论坛上来提问。https://community.freescale.com/community/imx/content
mini1986 发表于 2015-12-28 09:13 | 显示全部楼层
后续可能用到这个片子,先关注一下......
