请问数字示波器100MS/S的采样率能做到多少MHz的带宽?
4111|6
 楼主| edanzg 发表于 2007-11-23 23:47 | 显示全部楼层 |阅读模式
请问数字示波器100MS/S的采样率能做到多少MHz的带宽?(8bit ADC)
xwj 发表于 2007-11-23 23:58 | 显示全部楼层
根据奈奎斯特采样定律最多50MHz,但这时的波形都是方波了
而且此时混叠现象严重<br /><br />要想波形显示出来象正弦波,只能最多10MHz
 楼主| edanzg 发表于 2007-11-24 00:57 | 显示全部楼层
Lecroy 9400A(老古董,停产了)示波器做到了175M
The&nbsp;9400A’s&nbsp;&nbsp;two&nbsp;identical&nbsp;&nbsp;input&nbsp;&nbsp;channels&nbsp;&nbsp;are&nbsp;equipped&nbsp;&nbsp;with&nbsp;a<br /><b><font color=#0000FF>I00&nbsp;megasample/second&nbsp;(megasample/sec),&nbsp;</font></b>8-bit&nbsp;ADC&nbsp;and&nbsp;a&nbsp;32&nbsp;kiloword<br />acquisition&nbsp;memory&nbsp;(See&nbsp;Figure&nbsp;2.1).&nbsp;This&nbsp;dual&nbsp;ADC&nbsp;architecture&nbsp;ensures<br />absolute&nbsp;amplitude&nbsp;and&nbsp;phase&nbsp;correlation,&nbsp;maximum&nbsp;ADC&nbsp;performance&nbsp;for<br />both&nbsp;single&nbsp;and&nbsp;dual&nbsp;channel&nbsp;acquisition&nbsp;modes,&nbsp;large&nbsp;record&nbsp;lengths<br />and&nbsp;high&nbsp;time&nbsp;resolution.<br />The&nbsp;9400A’s&nbsp;two&nbsp;32K&nbsp;acquisition&nbsp;memories&nbsp;simplify&nbsp;transient&nbsp;capture&nbsp;by<br />providing&nbsp;very&nbsp;long&nbsp;waveform&nbsp;records&nbsp;that&nbsp;capture&nbsp;waveform&nbsp;features<br />even&nbsp;when&nbsp;trigger&nbsp;timing&nbsp;is&nbsp;uncertain.&nbsp;In&nbsp;addition,&nbsp;very&nbsp;accurate&nbsp;time<br />measurement&nbsp;is&nbsp;made&nbsp;possible&nbsp;by&nbsp;a&nbsp;digitally&nbsp;controlled&nbsp;zoom&nbsp;providing<br />an&nbsp;expansion&nbsp;factor&nbsp;of&nbsp;up&nbsp;to&nbsp;I00&nbsp;times&nbsp;the&nbsp;time&nbsp;base&nbsp;speed.<br />The&nbsp;&nbsp;9400A&nbsp;&nbsp;oscilloscope&nbsp;&nbsp;is&nbsp;&nbsp;capable&nbsp;&nbsp;of&nbsp;&nbsp;acquiring&nbsp;&nbsp;and&nbsp;&nbsp;storing&nbsp;&nbsp;repetitive<br />signals&nbsp;&nbsp;at&nbsp;&nbsp;a&nbsp;&nbsp;Random&nbsp;&nbsp;Interleaved&nbsp;&nbsp;Sampling&nbsp;&nbsp;rate&nbsp;&nbsp;of&nbsp;&nbsp;5&nbsp;&nbsp;gigasamples/second<br />(gigasamples/sec).&nbsp;&nbsp;An&nbsp;&nbsp;exclusive&nbsp;&nbsp;high-precision&nbsp;&nbsp;time&nbsp;&nbsp;digitizing<br />technique&nbsp;&nbsp;enables&nbsp;&nbsp;measurement&nbsp;&nbsp;of&nbsp;&nbsp;repetitive&nbsp;&nbsp;signals&nbsp;&nbsp;to&nbsp;&nbsp;a&nbsp;&nbsp;<font color=#0000FF>bandwidth&nbsp;&nbsp;of&nbsp;175&nbsp;&nbsp;MHz</font>&nbsp;at&nbsp;&nbsp;an&nbsp;&nbsp;effective&nbsp;&nbsp;measuring&nbsp;&nbsp;interval&nbsp;&nbsp;of&nbsp;&nbsp;200&nbsp;&nbsp;psec.<br /><br />当然,上面也说了是重复信号,
jmu2001 发表于 2007-11-25 01:35 | 显示全部楼层
hehe
&nbsp;&nbsp;&nbsp;谈论带宽,不要离开信号呀,就是需要测试的信号!
王紫豪 发表于 2007-11-26 11:03 | 显示全部楼层
你要是等效采样做好的话,带宽可以高于采样率!
不过:<br />高速采样好做,高的带宽就难鸟。。。
 楼主| edanzg 发表于 2007-11-26 20:58 | 显示全部楼层
呵呵,我打算买回来看看,就是太笨重了。
whnzcm 发表于 2007-12-10 16:56 | 显示全部楼层
直流耦合
是直流耦合,看来我得给你们上上课了。
