- #!/usr/bin/env python
- import sys
- import os
- import socket
- import string
- # windows only
- import msvcrt
- if len(sys.argv) != 3:
- print "usage: %s target_ip target_port" %(os.path.split(sys.argv[0])[1])
- sys.exit(0)
- try:
- target_ip = socket.gethostbyname(sys.argv[1])
- except:
- print "unknown target_ip: %s" %(sys.argv[1])
- sys.exit(0)
- try:
- target_port = int(sys.argv[2])
- except:
- print "target_port: %s error" %(sys.argv[2])
- sys.exit(0)
- if target_port <= 0:
- sys.exit(0)
- output_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
- try:
- output_socket.connect((target_ip,target_port))
- except:
- print 'connect error'
- sys.exit(0)
- output_socket.settimeout(0.5) # non-blocking
- buf = ""
- buf_output = ""
- flag_timeout=0
- while 1:
- # socket
- try:
- buf = output_socket.recv(1024)
- except socket.timeout:
- flag_timeout=1
- pass
- except:
- break
- if flag_timeout != 1:
- if len(buf) != 0:
- buf_temp = ' '.join(map(lambda c: "%02X" %ord(c), buf))
- print buf_temp
- else:
- print 'connection closed'
- break
- else:
- flag_timeout=0
- if msvcrt.kbhit(): # if a keypress is waiting to be read
- buf = sys.stdin.readline()
- if buf == '\x0A':
- output_socket.send(buf_output)
- continue
- try:
- buf_output = ""
- buf_temp = buf.split()
- for c in buf_temp:
- buf_output += chr(string.atoi('0x'+c, 16))
- except:
- print 'input format error'
- output_socket.close()
- sys.exit(0)
在windows下写就是费尽连个select都TMD不通用. 真**......
