使用STM32F072B-DISCO板,开发板函数版本为1.6, 使用CUBE MX软件初始化PB6为PWM输出。有谁帮忙看下是什么原因吗?之前试过用PA15管脚输出PWM2, 可以正常输出。 有谁试出来,可以参考一下?
下面是我的部分配置程度:
//main.c
static void MX_TIM16_Init(void)
TIM_OC_InitTypeDef sConfigOC;
TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig;
htim16.Instance = TIM16;
htim16.Init.Prescaler = 0;
htim16.Init.CounterMode = TIM_COUNTERMODE_UP;
htim16.Init.Period = 0xffff;
htim16.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim16.Init.RepetitionCounter = 0;
if (HAL_TIM_Base_Init(&htim16) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_Init(&htim16) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 0;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
if (HAL_TIM_PWM_ConfigChannel(&htim16, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
sBreakDeadTimeConfig.DeadTime = 0;
sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
if (HAL_TIMEx_ConfigBreakDeadTime(&htim16, &sBreakDeadTimeConfig) != HAL_OK)
Error_Handler();
HAL_TIM_MspPostInit(&htim16);
HAL_TIM_PWM_Start(&htim16, TIM_CHANNEL_1);
//stm32f0xx_hal_msp.c
void HAL_MspInit(void)
__HAL_RCC_SYSCFG_CLK_ENABLE();
/* System interrupt init*/
/* SVC_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SVC_IRQn, 0, 0);
/* PendSV_IRQn interrupt configuration */
HAL_NVIC_SetPriority(PendSV_IRQn, 0, 0);
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
if(htim_base->Instance==TIM16)
/* Peripheral clock enable */
__HAL_RCC_TIM16_CLK_ENABLE();
void HAL_TIM_MspPostInit(TIM_HandleTypeDef* htim)
GPIO_InitTypeDef GPIO_InitStruct;
if(htim->Instance==TIM16)
/**TIM16 GPIO Configuration
PB6 ------> TIM16_CH1N
GPIO_InitStruct.Pin = GPIO_PIN_6;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.Alternate = GPIO_AF2_TIM16;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base)
/* Peripheral clock disable */
__HAL_RCC_TIM16_CLK_DISABLE();
