/* Code adapted from Atmel AVR Application Note AVR306
* Interrupt mode driver for UART.
#include <io8515v.h>
#include <macros.h>
#include "uart.h"
/* IMPORTANT: these vector numbers are for 8515! If you use other devices
* you must change them to the different set of numbers.
* UART_RX_interrupt set to UART, Rx Complete
* UART_TX_interrupt set to UART Data Register Empty
#pragma interrupt_handler UART_RX_interrupt:10 UART_TX_interrupt:11
/* UART Buffer Defines */
#define UART_RX_BUFFER_SIZE 128 /* 1,2,4,8,16,32,64,128 or 256 bytes */
#define UART_RX_BUFFER_MASK ( UART_RX_BUFFER_SIZE - 1 )
#define UART_TX_BUFFER_SIZE 128 /* 1,2,4,8,16,32,64,128 or 256 bytes */
#define UART_TX_BUFFER_MASK ( UART_TX_BUFFER_SIZE - 1 )
#if ( UART_RX_BUFFER_SIZE & UART_RX_BUFFER_MASK )
#error RX buffer size is not a power of 2
#endif
/* Static Variables */
static unsigned char UART_RxBuf[UART_RX_BUFFER_SIZE];
static volatile unsigned char UART_RxHead;
static volatile unsigned char UART_RxTail;
static unsigned char UART_TxBuf[UART_TX_BUFFER_SIZE];
static volatile unsigned char UART_TxHead;
static volatile unsigned char UART_TxTail;
/* initialize UART */
void InitUART( unsigned char baudrate )
unsigned char x;
UBRR = baudrate; /* set the baud rate */
/* enable UART receiver and transmitter, and
receive interrupt */
UCR = ( (1<<RXCIE) | (1<<RXEN) | (1<<TXEN) );
x = 0; /* flush receive buffer */
UART_RxTail = x;
UART_RxHead = x;
UART_TxTail = x;
UART_TxHead = x;
/* interrupt handlers */
void UART_RX_interrupt( void )
unsigned char data;
unsigned char tmphead;
data = UDR; /* read the received data */
/* calculate buffer index */
tmphead = ( UART_RxHead + 1 ) & UART_RX_BUFFER_MASK;
UART_RxHead = tmphead; /* store new index */
if ( tmphead == UART_RxTail )
/* ERROR! Receive buffer overflow */
UART_RxBuf[tmphead] = data; /* store received data in buffer */
void UART_TX_interrupt( void )
unsigned char tmptail;
/* check if all data is transmitted */
if ( UART_TxHead != UART_TxTail )
tmptail = ( UART_TxTail + 1 ) & UART_TX_BUFFER_MASK;
UART_TxTail = tmptail; /* store new index */
UDR = UART_TxBuf[tmptail]; /* start transmition */
else
UCR &= ~(1<<UDRIE); /* disable UDRE interrupt */
/* Read and write functions */
unsigned char ReceiveByte( void )
while ( UART_RxHead == UART_RxTail ) /* wait for incomming data */
tmptail = ( UART_RxTail + 1 ) & UART_RX_BUFFER_MASK;/* calculate buffer index */
UART_RxTail = tmptail; /* store new index */
return UART_RxBuf[tmptail]; /* return data */
void TransmitByte( unsigned char data )
tmphead = ( UART_TxHead + 1 ) & UART_TX_BUFFER_MASK;
/* wait for free space in buffer */
while ( tmphead == UART_TxTail )
UART_TxBuf[tmphead] = data; /* store data in buffer */
UART_TxHead = tmphead; /* store new index */
UCR |= (1<<UDRIE); /* enable UDRE interrupt */
unsigned char DataInReceiveBuffer( void )
return ( UART_RxHead != UART_RxTail );
/* return 0 (FALSE) if the receive buffer is empty */
#ifdef TEST
/* main - a simple test program*/
void main( void )
InitUART( 25 ); /* set the baudrate to 9600 bps using a 4MHz crystal */
_SEI(); /* enable interrupts => enable UART interrupts */
while ( 1 ) /* forever */
TransmitByte( ReceiveByte() ); /* echo the received character */
#endif
