lpc2131+TFT。。急!!!
2395|3
 楼主| 不懂ARM 发表于 2010-5-11 14:18 | 显示全部楼层 |阅读模式
若用LPC的GPIO口模拟其总线时序,点不亮TFT屏....
其中:数据输出端口为:P0.2~P0.17
#define LCD_CS_1     {IO0SET |= (1<<18);}// rPDATD |=(1<<2)
#define LCD_CS_0     {IO0CLR |= (1<<18);}// rPDATD &=~(1<<2)
#define LCD_RS_1     {IO0SET |= (1<<19);}//rPDATD |=(1<<1)
#define LCD_RS_0     {IO0CLR |= (1<<19);}//rPDATD &=~(1<<1)
#define LCD_WR_1     {IO0SET |= (1<<20);}// rPDATD |=(1<<5)
#define LCD_WR_0     {IO0CLR |= (1<<20);}// rPDATD&=~(1<<5)
#define LCD_RD_1     {IO0SET |= (1<<21);}//rPDATD |=(1<<3)
#define LCD_RD_0     {IO0CLR |= (1<<21);}// rPDATD&=~(1<<3)
#define LCD_RESET_1  {IO0SET |= (1<<22);}//rPDATD |= 1
#define LCD_RESET_0  {IO0CLR |= (1<<22);}//rPDATD &=~1
* 名    称:
* 功    能:
* 参    数:
* 返 回 值:
void WriData(uint16 ch)
   uint32 dat = ch;
   uint32 dat2;
   dat =(dat<<2)&0x0003FFFC;
   dat2 = (~dat)&0x0003FFFC;
    LCD_RS_1;
    LCD_WR_0;
    LCD_CS_0;
//    rPDATC=ch;//LCD_DATA(ch);
   // PORT_DATA(ch);
  // temp1 = IO0SET&0x0000FFFF;
  // temp2 = IO0CLR&0x0000FFFF;
   //IO0SET |= dat;
  // IO0CLR |= dat2;
   IO0PIN |= dat;
    LCD_WR_1;
    LCD_CS_1;
* 名    称:
* 功    能:
* 参    数:
* 返 回 值:
void WriCom(uint16  ch)
   uint32 dat = ch;
   uint32 dat2;
   dat = (dat<<2)&0x0003FFFC;
    LCD_RS_0;
    LCD_WR_0;
    LCD_CS_0;
  // PORT_DATA(ch);
   // IO0SET |= dat;
  // IO0CLR |= dat2;
    IO0PIN |= dat;
    LCD_WR_1;
    LCD_CS_1;
int main (void)
    uint16 i;
    PINSEL0 = 0;
    PINSEL1 = 0;
    PINSEL2 = 0;
    IO0DIR  = 0xFFFFFFFF;
具体程序如附件.....
 楼主| 不懂ARM 发表于 2010-5-11 14:26 | 显示全部楼层
不好单思,第一次发贴,紧张....发错了.....
* 名    称:
* 功    能:
* 参    数:
* 返 回 值:
   uint32 dat = ch;
   uint32 dat2;
    LCD_RS_1;
    LCD_WR_0;
    LCD_CS_0;
   // PORT_DATA(ch);
   IO0SET |= dat;
   IO0CLR |= dat2;
   //IO0PIN |= dat;//仿一下周立功的,直接端口输出
    LCD_WR_1;
    LCD_CS_1;
* 名    称:
* 功    能:
* 参    数:
* 返 回 值:
   uint32 dat = ch;
   uint32 dat2;
    LCD_RS_0;
    LCD_WR_0;
    LCD_CS_0;
  // PORT_DATA(ch);
   IO0SET |= dat;
   IO0CLR |= dat2;
    LCD_WR_1;
    LCD_CS_1;
int main (void)
    uint16 i;
    PINSEL0 = 0;
    PINSEL1 = 0;
    PINSEL2 = 0;
具体程序如附件.....
 楼主| 不懂ARM 发表于 2010-6-5 12:56 | 显示全部楼层
问题已解决。。。。 有一个端口出现问题,无论怎么设置,都没变化....:(
arm86 发表于 2010-6-5 20:05 | 显示全部楼层
P0.3为I2C的端口,开漏输出,内部无上拉电阻,是不是这个地方有问题呢?呵呵
