請問各位
perl能夠port到winbond uClinux 上使用嗎?
我在menuconfig中選取perl
compiler出現下列訊息
sv.c: In function `Perl_sv_gets':
sv.c:4419: structure has no member named `_IO_read_end'
sv.c:4419: structure has no member named `_IO_read_ptr'
sv.c:4435: structure has no member named `_IO_read_ptr'
sv.c:4473: structure has no member named `_IO_read_ptr'
sv.c:4486: structure has no member named `_IO_read_end'
sv.c:4486: structure has no member named `_IO_read_ptr'
sv.c:4487: structure has no member named `_IO_read_ptr'
sv.c:4514: structure has no member named `_IO_read_ptr'
make[2]: *** [sv.o] Error 1
make[2]: Leaving directory `/home/minyi/snmpAdaptor/code/uClinux-dist/user/perl'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/minyi/snmpAdaptor/code/uClinux-dist/user'
make: *** [user_only] Error 2 |
