[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _ir
2288|0
 楼主| sherry88 发表于 2010-8-30 11:07 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity v_ir is
port( instruction : in std_logic_vector(15 downto 0);
en, clk, clrn : in std_logic;
ir : buffer std_logic_vector(15 downto 0);
imm_value : out std_logic_vector(7 downto 0);
rd, rr : out integer range 0 to 15
end v_ir;
architecture ir of v_ir is
begin
process(clk,clrn)
begin
if clrn = '0' then
ir <= "0000000000000000";
elsif clk'event and clk = '1' then
if en = '1' then
ir <= instruction;
end if;
end if;
end process;
imm_value <= ir(11 downto 8) & ir(3 downto 0);
rd <= conv_integer(ir(7 downto 4));
rr <= conv_integer(ir(3 downto 0));
end ir;
