| //命令结构体 struct CMD_STRUCT{
 char name;        /* Command Name        */
 char *usage;/* Usage message */
 void (*CmdFun)(char *para);/* Command execute function */
 //命令列表
 struct CMD_STRUCT CmdTbl[] = {
 {'h', "h - help, list all cmd\n\r",                 HelpCmdExeFun},
 {'s', "s - view log status\n\r",                         StatusCmdExeFun},
 {'f', "f - find in root dir\n\r",                        FindCmdExeFun},
 {'o', "o - open directory\n\r",                         OpenCmdExeFun},
 {'g', "g - get specific file\n\r",                         GetCmdExeFun},
 {'b', "b - back to root directory\n\r",         BackCmdExeFun},
 {'n', "n - next 10 dirent\n\r",                         NextCmdExeFun},
 {'t', "t - go to top of directory\n\r",         TopCmdExeFun},
 {'d', "d - download a file from pc\n\r",         DownloadCmdExeFun},
 {'e', "e - exit shell\n\r",                                 NULL}
 //打印当前目录名字
 static void ShowCurDirectory(void)
 USART_PutStr(COMMUNICATE_USART, "---------------- in directory : ");
 USART_PutStr(COMMUNICATE_USART, CirDirName);
 USART_PutStr(COMMUNICATE_USART, " ----------------\n\r");
 //帮助
 void HelpCmdExeFun(char *para)
 int n;
 USART_PutStr(COMMUNICATE_USART, "---------------- here is all cmd supported ----------------\n\r");
 for(n=0; n<sizeof(CmdTbl)/sizeof(struct CMD_STRUCT); n++){
 USART_PutStr(COMMUNICATE_USART, CmdTbl[n].usage);
 //查看日志系统状态
 void StatusCmdExeFun(char *para)
 unsigned int num;
 num = 100 * yaffs_freespace(ROOT_DIR_NAME) / yaffs_totalspace(ROOT_DIR_NAME);
 USART_PutStr(COMMUNICATE_USART, "---------------- here is log system status ----------------\n\r");
 if(1 == pSystemUnitModule->LogFileSystemCtrl)
 USART_PutStr(COMMUNICATE_USART, "log system status : open\n\r");
 else
 USART_PutStr(COMMUNICATE_USART, "log system status : close\n\r");
 USART_PutStr(COMMUNICATE_USART, "yaffs space use status : ");
 USART_PutChar(COMMUNICATE_USART, '0' + num/10%10 );
 USART_PutChar(COMMUNICATE_USART, '0' + num%10 );
 USART_PutChar(COMMUNICATE_USART, '%' );
 USART_PutStr(COMMUNICATE_USART, "\n\r");
 //在根目录中查找参数中指定的文件夹或文件,并列出以它开始的10个目录项
 void FindCmdExeFun(char *DirentName)
 struct yaffs_dirent *pDirent;
 int n;
 char NameBuff[64];
 //切换到根目录
 yaffs_closedir(pCurDirectory);
 pCurDirectory = yaffs_opendir(ROOT_DIR_NAME);
 yaffs_rewinddir(pCurDirectory);
 //设置当前目录名字
 strcpy(CirDirName, ROOT_DIR_NAME);
 //打印当前目录名字
 ShowCurDirectory();
 //名字连接,例如:将根目录"/nand/"和文件夹"2010-01-26"连接为"/nand/2010-01-26"
 strcpy(NameBuff, ROOT_DIR_NAME);
 strncpy(NameBuff + strlen(ROOT_DIR_NAME), DirentName, sizeof(NameBuff)-strlen(ROOT_DIR_NAME));
 do{
 pDirent = yaffs_readdir(pCurDirectory);
 if(0 == strcmp(pDirent->d_name, DirentName))
 break;
 }while(NULL != pDirent);
 if(NULL == pDirent){
 USART_PutStr(COMMUNICATE_USART, "not find\n\r");
 return;
 //打印找到的目录项名字
 strncpy(ListFileName[0], pDirent->d_name, FILE_NAME_MAXLEN);
 ListFileName[0][FILE_NAME_MAXLEN-1] = 0;
 USART_PutChar(COMMUNICATE_USART, '0');
 if(YAFFS_OBJECT_TYPE_DIRECTORY == pDirent->d_type)
 USART_PutStr(COMMUNICATE_USART, " - dir  - ");
 else
 USART_PutStr(COMMUNICATE_USART, " - file - ");
 USART_PutStr(COMMUNICATE_USART, ListFileName[0]);
 //打印紧跟找到目录后面的9个目录项名字
 for(n=1; n<DIRENT_MAXNUM; n++){
 ListFileName[n][0] = 0;
 }else{
 strncpy(ListFileName[n], pDirent->d_name, FILE_NAME_MAXLEN);
 ListFileName[n][FILE_NAME_MAXLEN-1] = 0;
 USART_PutChar(COMMUNICATE_USART, '0' + n);
 else
 USART_PutStr(COMMUNICATE_USART, ListFileName[n]);
 USART_PutStr(COMMUNICATE_USART, "Note: reach the bottom of directory, no more file\n\r");
 //打开目录
 void OpenCmdExeFun(char *para)
 yaffs_DIR *pTempDirectory;
 int n;
 char NameBuff[64];
 //目录连接,例如:将"/nand/"和"2011-01-25"连接为"/nand/2011-01-25/"
 strcpy(NameBuff, CirDirName);
 strncpy(NameBuff + strlen(NameBuff), ListFileName[*para - '0'], sizeof(NameBuff)-strlen(NameBuff));
 strcpy(NameBuff + strlen(NameBuff), "/");
 pTempDirectory = yaffs_opendir(NameBuff);
 if(NULL == pTempDirectory){
 USART_PutStr(COMMUNICATE_USART, "faild to open directory\n\r");
 return;
 }else{
 pCurDirectory = pTempDirectory;
 //设置当前目录名字
 strncpy(CirDirName, NameBuff, sizeof(CirDirName));
 NextCmdExeFun(NULL);
 //上传文件
 void GetCmdExeFun(char *para)
 char NameBuff[64];
 //名字连接,例如:将"/nand/2011-01-25/"和"lw-c360.txt"连接为"/nand/2011-01-25/lw-c360.txt"
 //打印要上传的文件名
 USART_PutStr(COMMUNICATE_USART, "Please open zmodem to receive the file : ");
 USART_PutStr(COMMUNICATE_USART, ListFileName[*para - '0']);
 if(0 == ZmodemSendOneFile(NameBuff)){//ZMODEMOK
 USART_PutStr(COMMUNICATE_USART, "send file ok\n\r");
 }else{
 USART_PutStr(COMMUNICATE_USART, "send file error\n\r");
 //返回根目录
 void BackCmdExeFun(char *para)
 //设置当前目录名字
 strncpy(CirDirName, ROOT_DIR_NAME, sizeof(CirDirName));
 //下10个目录项
 void NextCmdExeFun(char *para)
 int n;
 //打印当前目录名字
 ShowCurDirectory();
 for(n=0; n<DIRENT_MAXNUM; n++){
 }else{
 else
 //返回目录开始位置
 void TopCmdExeFun(char *para)
 //从PC机下载一个文件
 void DownloadCmdExeFun(char *para)
 ZmodemReceiveFiles();
 * shell命令界面,进入shell界面之前,需要设置COMMUNICATE_USART
 * 工作串口波特率为115200,并关闭COMMUNICATE_USART工作串口中断。
 void shell(void)
 int n, CmdIndex;
 unsigned char CmdBuffer[32];
 //执行帮助命令
 HelpCmdExeFun(NULL);
 //打开根目录
 while(1){
 readline_into_buffer("lw360>", CmdBuffer);
 if(0 == CmdBuffer[0]){
 continue;
 //检查命令
 if( ('f' == CmdBuffer[0] || 'o' == CmdBuffer[0] || 'g' == CmdBuffer[0]) ){
 //f、o、g命令和参数之间用1个空格隔开
 if(' ' != CmdBuffer[1]){
 USART_PutStr(COMMUNICATE_USART, "cmd error, you can input h for help\n\r");
 continue;
 }else{
 //其他命令不带参数,第二个字符必须是结束符'/0'
 if(0 != CmdBuffer[1]){
 continue;
 //查找命令
 CmdIndex = -1;
 if(CmdTbl[n].name == CmdBuffer[0]){
 CmdIndex = n;
 break;
 if(-1 == CmdIndex){
 //查找命令失败
 continue;
 //如果是exit命令,则退出shell界面,机器进入正常工作模式
 if('e' == CmdTbl[CmdIndex].name){
 USART_PutStr(COMMUNICATE_USART, "Exit shell, return to work mode, good bye!^_^\n\r");
 delay_ms(1000);
 return;
 //检查enter和get命令参数
 if( ('o' == CmdTbl[CmdIndex].name || 'g' == CmdTbl[CmdIndex].name)\
 && (CmdBuffer[2]<'0' || '9'<CmdBuffer[2]) ){
 USART_PutStr(COMMUNICATE_USART, "cmd para error\n\r");
 continue;
 //执行命令
 (CmdTbl[CmdIndex].CmdFun)(&CmdBuffer[2]);
 USART_PutStr(COMMUNICATE_USART, "-\n\r");
 }//end while
