从VESA显卡的时代起VGA接口的几根空余口线被当作显示器ID接口,其定义如下:<br />管脚 名称 功能描述<br />1 RED Red Video (75 ohm, 0.7 V p-p)<br />2 GREEN Green Video (75 ohm, 0.7 V p-p)<br />3 BLUE Blue Video (75 ohm, 0.7 V p-p)<br />4 ID2 Monitor ID Bit 2<br />5 GND Ground<br />6 RGND Red Ground<br />7 GGND Green Ground<br />8 BGND Blue Ground<br />9 KEY Key (No pin)<br />10 SGND Sync Ground<br />11 ID0 Monitor ID Bit 0<br />12 ID1 or SDA Monitor ID Bit 1<br />13 HSYNC or CSYNC Horizontal Sync (or Composite Sync)<br />14 VSYNC Vertical Sync<br />15 ID3 or SCL Monitor ID Bit 3
