VGA时序分析
电阻DAC转换网络和640X480的VGA时序图:
图1
扫描频率
显示器采用光栅扫描方式,即轰击荧光屏的电子束在CRT屏幕上从左到右(受水平同步信号HSYNC控制)、从上到下(受垂直同步信号VSYNC控制)做有规律的移动。光栅扫描又分逐行扫描和隔行扫描。电子束采用光栅扫描方式,从屏幕左上角一点开始,向右逐点进行扫描,形成一条水平线;到达最右端后,又回到下一条水平线的左端,重复上面的过程;当电子束完成右下角一点的扫描后,形成一帧。此后,电子束又回到左上方起点,开始下一帧的扫描。这种方法也就是常说的逐行扫描显示。
Horizonal Timing
图2
A (us) Line PeriodB (us) Sync pulse lenght C (us) Back porchD (us) Active video timeE (us) Front porch
Vertical Timing
O (ms) Frame PeriodP (ms) Sync lengthQ (ms) Back porchR (ms) Active video timeS (ms) Front porch
Horizonal timing information
水平扫描时序
Notes:
Active area is actually an active area added with 6 overscan border pixels (in some other VGA timing tables those border pixels are included in back and front porch)
Vertical timing information
垂直扫描时序
Notes:
Active area is actually an active area added with 4 overscan border lines (in some other VGA timing tables those border lines are included in back and front porch)
Note than when the active part of VGA page is widened, it passes by the rising edge of the vertical sync signal in some modes (marked with *)
