linux logrotate
895|0
 楼主| snakeemail 发表于 2018-4-24 21:48 | 显示全部楼层 |阅读模式
If daily, monthly, ... come first and after that size directive, daily, monthly, ... will be ignored and size directive will apply to the log file.
Similarly when I first use the size directive then daily, weekly, monthly, and yearly directives, the size directive will be ignored.
个人签名:提供500W线性 交流电源。0~300VAC,45~500Hz 提供10KW,0-330V直流电源,具体见http://blog.21ic.com/user1/3639/archives/2012/88528.html
547
