cc2530和STC12C5A60S2的串口通信
1586|3
 楼主| dzzpec 发表于 2018-5-3 17:46 | 显示全部楼层 |阅读模式
大神们,交流一下cc2530和STC12C5A60S2的串口通信,包括它们的接线和程序实现。
 楼主| dzzpec 发表于 2018-5-4 17:36 | 显示全部楼层
1.硬件连接
CC2530串口(UART0)               STC12串口(UART1)
Rx/P0.2  ------------------------------ TxD/P3.1
Tx/P0.3  ------------------------------  RxD/P3.0
GND       ------------------------------  GND(共地)
+5V        ------------------------------ +5V(共5V电源)
coody 发表于 2018-5-5 21:40 | 显示全部楼层
RCD TXD最好串个300~510欧姆电阻。
 楼主| dzzpec 发表于 2018-6-7 20:32 | 显示全部楼层
STC12C5A60S2的串口通信程序,在此记录
/*************        ±¾³ÌÐò¹¦ÄÜ˵Ã÷        **************
        ²âÊÔ·½·¨£º
        ¸ù¾ÝÄúµÄÖ÷ʱÖӺͲ¨ÌØÂÊÐÞ¸ÄÏÂÃæµÄÏà¹Ø¶¨Ò壬±àÒëºóÏÂÔØµ½MCU¡£
        ͨ¹ý´®¿ÚÖúÊÖÏòMCU·¢ËÍÊý¾Ý£¬MCUÊÕµ½ºóÔ­Ñù·µ»Ø¡£
#include        <reg51.h>
sfr        AUXR = 0x8E;
#define                BUF_LENTH        128                //¶¨Òå´®¿Ú½ÓÊÕ»º³å³¤¶È
unsigned char         RX0_Cnt;
unsigned char        RX0_TimerOut;
unsigned char         xdata RX0_Buffer[BUF_LENTH];
bit                B_TI;
void        uart0_init(void);
/*************** Óû§¶¨Òå²ÎÊý *****************************/
#define MAIN_Fosc                11059200L        //define main clock
#define Baudrate0                9600                //define the baudrate,
        //12T mode: 600~115200 for 22.1184MHZ, 300~57600 for 11.0592MHZ
        //1T  mode: 7200~1382400 for 22.1184MHZ, 3600~691200 for 11.0592MHZ
/****************** ±àÒëÆ÷×Ô¶¯Éú³É£¬Óû§ÇëÎðÐÞ¸Ä ************************************/
#define T1_TimerReload                (256 - MAIN_Fosc / 192 / Baudrate0)                //Calculate the timer1 reload value        at 12T mode
//#define T1_TimerReload        (256 - MAIN_Fosc / 16 / Baudrate0)                //Calculate the timer1 reload value ar 1T mode
#define        TimeOut                                (28800 / (unsigned long)Baudrate0 + 2)
void        main(void)
        unsigned char i;
        unsigned int  j;
        uart0_init();
        while(1)
                for(j=0; j<1500; j++)        ;        //14T per loop, delay 1ms
                if(RX0_TimerOut != 0)
                        if(--RX0_TimerOut == 0)
                                if(RX0_Cnt != 0)
                                        for(i=0; i<RX0_Cnt; i++)
                                                B_TI = 0;
                                                SBUF = RX0_Buffer[i];
                                                while(!B_TI)        ;
                                                B_TI = 0;
                                RX0_Cnt = 0;
        PCON |= 0x80;                //UART0 Double Rate Enable
        SCON = 0x50;                //UART0 set as 10bit , UART0 RX enable
        TMOD &= ~(1<<6);                //Timer1 Set as Timer, 12T
        TMOD = (TMOD & ~0x30) | 0x20;        //Timer1 set as 8 bits auto relaod
//        AUXR |=  (1<<6);                //Timer1 set as 1T mode
        TH1 = T1_TimerReload;                //Load the timer
        TR1  = 1;
        ES  = 1;
        EA = 1;
void UART0_RCV (void) interrupt 4
        if(RI)
                RI = 0;
                if(RX0_Cnt >= BUF_LENTH)                RX0_Cnt = 0;
                RX0_Buffer[RX0_Cnt++] = SBUF;
                RX0_TimerOut = TimeOut;        //5ms time out for >= 4800
        if(TI)
                TI = 0;
                B_TI = 1;
