(转)GD32F150x之System Tick
976|1
 楼主| wowu 发表于 2018-7-27 10:21 | 显示全部楼层 |阅读模式
RM-M3 时钟控制与System Tick操作。
  • void System_Init (void)
  •   RCC->GCCR = RCC_GCCR_HSIEN;                 // 启用内部8MHz RC oscillator。
  •   while (!(RCC->GCCR & RCC_GCCR_HSISTB));     // 等待直到内部RC oscillator稳定。
  •   /* [31]      rw PLLDV    = 0,   CK_OUT的输入分频系数CK_PLL divide by 2.
  •      [30:28]   rw CKOUTDIV = 0,   CK_OUT的输出分频系数。
  •      [26:24]   rw CKOUTSRC = 0,   CKOUT时钟输出PIN的输出频率(No clock selected).
  •      [23:22]   rw USBPS    = 0,   USB时钟等于CK_PLL / 1.5
  •      [27,21:18]rw PLLMF   = 0x12, PLL倍频系数是18x.
  •      [17]      rw PLLPREDV = 0,   PLL时钟源选用HSE时钟(PLLSEL=1时有效).
  •      [16]      rw PLLSEL   = 0,   PLL时钟源等于HSI时钟除2(8MHz / 2)
  •      [15:14]   rw ADCPS    = 0,   ADC时钟等于CK_APB2 / 2.
  •      [13:11]   rw APB2PS   = 0,   APB2时钟等于CK_AHB.
  •      [10:8]    rw APB1PS   = 0,   APB1时钟等于CK_AHB.
  •      [7:4]     rw AHBPS    = 0,   AHB时钟等于CK_SYS.
  •      [3:2]     r  SCSS            System clock switch status(Read only).
  •      [1:0]     rw SCS      = 0,   CK_SYS时钟来自CK_HSI
  •   RCC->GCFGR = 0x808000C;
  •   /* [31:26]      Reserved.
  •      [25]      r  PLLSTB          PLL Clock Stabilization Flag, 0: PLL is not stable
  •      [24]      rw PLLEN    = 1,   PLL enable.
  •      [23:20]      Reserved.
  •      [19]      rw CKMEN    = 0,   Disable the External 4 ~ 32 MHz crystal oscillator (HSE) clock monitor.
  •      [18]      rw HSEBPS   = 0,   Disable the HSE Bypass mode.
  •      [17]      r  HSESTB          0: HSE oscillator is not stable
  •      [16]      rw HSEEN    = 0,   0: External 4 ~ 32 MHz crystal oscillator disabled.
  •      [15:8]    r  HSICALIB        High Speed Internal Oscillator calibration value register
  •      [7:3]     rw HSIADJ          High Speed Internal Oscillator clock trim adjust value
  •      [2]          Reserved.
  •      [1]       r  HSISTB          0: HSI oscillator is not stable
  •      [0]       rw HSIEN           1: Internal 8 MHz RC oscillator enabled
  •   RCC->GCCR |= RCC_GCCR_PLLEN;
  •   while(!(RCC->GCCR & RCC_GCCR_PLLSTB));      // Wait untill PLL is ready
  •   RCC->GCFGR |= (uint32_t)RCC_GCFGR_SCS_PLL;  // 切换CK_SYS时钟为CK_PLL
  •   /* Wait untill PLL is chosen as system clock source */
  •   while ((RCC->GCFGR & (uint32_t)RCC_GCFGR_SCSS) != (uint32_t)RCC_GCFGR_SCSS_PLL);
  •   * @brief  This function handles SysTick Handler.
  •   * @param  None
  •   * @retval None
  • void SysTick_Handler(void)
  •   if (!(++flag % 1000)) {
  •     if (GPIO_ReadOutputBit(GPIOB, GPIO_PIN_10))
  •       GPIO_ResetBits(GPIOB, GPIO_PIN_10);
  •     else
  •       GPIO_SetBits(GPIOB, GPIO_PIN_10);
  •     flag = 0;
  • void delay_us(uint32_t nTime)
  •   SysTick->VAL=0X00;                              //  初值
  •   SysTick->LOAD=72*nTime;                   //  重装值;48个时钟周期=1us
  •   SysTick->CTRL=0x00000005;               //  第0位:使能时钟   第3位:使用内部时钟
  •   while(!(SysTick->CTRL&0x00010000));  //计时
  •   SysTick->CTRL|=0x00000004;             // 第1位:产生异常请求
  • int main(void)
  •   GPIO_InitPara GPIO_InitStructure;
  •   RCC_AHBPeriphClock_Enable(RCC_AHBPERIPH_GPIOB, ENABLE);
  •   GPIO_InitStructure.GPIO_Pin = GPIO_PIN_10;
  •   GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
  •   GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT;
  •   GPIO_InitStructure.GPIO_OType = GPIO_OTYPE_PP;
  •   GPIO_InitStructure.GPIO_PuPd = GPIO_PUPD_NOPULL;
  •   GPIO_Init(GPIOB, &GPIO_InitStructure);
  •   SysTick_Config(72000);    /// 72000 / 72000000(72MHz) = 0.001秒。
  •   while(1) {
  •     //GPIO_SetBits(GPIOB, GPIO_PIN_11);
  •     //delay_us(1000000);
  •     //GPIO_ResetBits(GPIOB, GPIO_PIN_11);
  •   return 0;
jerow 发表于 2018-7-27 10:36 | 显示全部楼层
支持下,谢谢分享!
