[应用方案] NV32F100 , ADC采样(PC2 ) 数码管显示
1183|2
 楼主| tang87633187 发表于 2018-7-27 11:43 | 显示全部楼层 |阅读模式
void delay( int t )
{    int k,j;
            for(k=0;k<t;k++)
       for(j=0;j<1000;j++)
void SCLK(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTC0);
          else
            GPIO_PinClear(GPIO_PTC0);
        void RCLK(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTC1);
          else
            GPIO_PinClear(GPIO_PTC1);
        void DIO(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTD5);
          else
            GPIO_PinClear(GPIO_PTD5);
         void H595_Conver( int data)
        { char t;
                  RCLK(0);
                for(t=0;t<16;t++)
                {  if((data&0x8000)==0x8000)
                            DIO(1);
                          else
                                        DIO(0);
                           SCLK(1);
                                  data=data<<1;
                           SCLK(0);
                  RCLK(1);
char led[10]={ 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
int main (void);
void RTC_Task(void);
* Global functions
int main (void)
{ char temp;
        char i;
        int j,k;
  long int adc_data;
  char da[8];
        ADC_ConfigType  sADC_Config = {0};
    sysinit();
    cpu_identify();
    sADC_Config.u8ClockDiv = ADC_ADIV_DIVIDE_4;//ÉèÖÃʱÖÓÔ´4·ÖƵ
    sADC_Config.u8ClockSource = CLOCK_SOURCE_BUS_CLOCK;//Ñ¡ÔñʱÖÓԴΪBUSʱÖÓ
    sADC_Config.u8Mode = ADC_MODE_12BIT;//ת»»Ä£Ê½Ñ¡ÔñΪ12λת»»
     ADC_Init( ADC, &sADC_Config);//³õʼ»¯ADCÄ£¿é
                 GPIO_PinInit(GPIO_PTC0, GPIO_PinOutput);
                 GPIO_PinInit(GPIO_PTC1, GPIO_PinOutput);
                 GPIO_PinInit(GPIO_PTD5, GPIO_PinOutput);
         while(1)
  {   //printf("VREFH conversion= %d\r\n",ADC_PollRead(ADC,ADC_CHANNEL_AD10 )*3280/4096);
                 adc_data=ADC_PollRead(ADC,ADC_CHANNEL_AD10 )*3280/4096;
                 for(i=0;i<8;i++)
                  {da[7-i]=adc_data%10;
                                adc_data=adc_data/10;
                for(i=0;i<8;i++)
                 { if(i==4)
                           H595_Conver( ((0xff-led[da]-0x80)<<8)|(0x01<<(7-i)));
                         else
                                  H595_Conver( ((0xff-led[da])<<8)|(0x01<<(7-i)));
        delay(2);
* @ TRCÈÎÎñ×Óº¯ÊýÉÁ˸LED1
*  ÎÞ·µ·µ»Ø
void RTC_Task(void)
engao 发表于 2018-7-30 08:38 | 显示全部楼层
共阴数码管理共阳的
xujunyi3611 发表于 2018-8-26 17:28 | 显示全部楼层
共阴数码管理共阳的
看编码格式,应该是共阳的,低电平点亮。
