//安装目录下的EXE文件打开后可在电脑上显示当前温度值
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit DS=P2^2; //define interface
uint temp; // variable of temperature
uchar flag1; // sign of the result positive or negative
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
0x87,0xff,0xef};
void delay(uint count) //delay
uint i;
while(count)
i=200;
while(i>0)
i--;
count--;
///////功能:串口初始化,波特率9600,方式1///////
void Init_Com(void)
TMOD = 0x20;
PCON = 0x00;
SCON = 0x50;
TH1 = 0xFd;
TL1 = 0xFd;
TR1 = 1;
void dsreset(void) //send reset and initialization command 18B20复位,初始化函数
uint i;把这里uint改为uchar为什么就不行?整型数据和 字 符型数据不是一样吗?
DS=0;
i=103;
while(i>0)i--;
DS=1;
i=4;
while(i>0)i--;
bit tmpreadbit(void) //read a bit 读1位数据函数
uint i;
bit dat;
DS=0;i++; //i++ for delay
DS=1;i++;i++;
dat=DS;
i=8;while(i>0)i--;
return (dat);
uchar tmpread(void) //read a byte date 读1字节函数
uchar i,j,dat;
dat=0;
for(i=1;i<=8;i++)
j=tmpreadbit();
dat=(j<<7)|(dat>>1); //读出的数据最低位在最前面,这样刚好一个字节在DAT里
return(dat);
void tmpwritebyte(uchar dat) //write a byte to ds18b20 向1820写一个字节数据函数
uint i;
uchar j;
bit testb;
for(j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if(testb) //write 1
DS=0;
i++;i++;
DS=1;
i=8;while(i>0)i--;
else
DS=0; //write 0
i=8;while(i>0)i--;
DS=1;
i++;i++;
void tmpchange(void) //DS18B20 begin change 开始获取数据并转换
dsreset();
delay(1);
tmpwritebyte(0xcc); // address all drivers on bus 写跳过读ROM指令
tmpwritebyte(0x44); // initiates a single temperature conversion 写温度转换指令
uint tmp() //get the temperature 读取寄存器中存储的温度数据
float tt;
uchar a,b;
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0xbe);
a=tmpread(); //读低8位
b=tmpread(); //读高8位
temp=b;
temp<<=8; //two byte compose a int variable 两个字节组合为1个字
temp=temp|a;
tt=temp*0.0625; //温度在寄存器中是12位,分辨率是0.0625
temp=tt*10+0.5; //乘10表示小数点后只取1位,加0.5是四折五入
return temp;
void readrom() //read the serial
uchar sn1,sn2;
dsreset();
delay(1);
tmpwritebyte(0x33);
sn1=tmpread();
sn2=tmpread();
void delay10ms() //delay
uchar a,b;
for(a=10;a>0;a--)
for(b=60;b>0;b--);
void display(uint temp) //显示程序
uchar A1,A2,A2t,A3,ser;
ser=temp/10;
SBUF=ser;
A1=temp/100;
A2t=temp%100;
A2=A2t/10;
A3=A2t%10;
dula=0;
P0=table[A1]; //显示百位
dula=1;
dula=0;
wela=0;
P0=0x7e;
wela=1;
wela=0;
delay(1);
dula=0;
P0=table1[A2]; //显示十位
dula=1;
dula=0;
wela=0;
P0=0x7d;
wela=1;
wela=0;
delay(1);
P0=table[A3]; //显示个位
dula=1;
dula=0;
P0=0x7b;
wela=1;
wela=0;
delay(1);
void main()
uchar a;
Init_Com();
do
tmpchange();
// delay(200);
for(a=10;a>0;a--)
{ display(tmp());
} while(1);
