- import cv2
- import dlib
- import os
- import sys
- from scipy import misc
- import time
- from multiprocessing import Process, JoinableQueue, Queue
- from random import random
- import time
- import glob
- import facenet.src.align.detect_face as detect_face
- import numpy as np
- import tensorflow as tf
- #tasks_queue = JoinableQueue()
- results_queue = Queue()
- convert_queue = Queue()
- message_queue = Queue()
- image_extension = ".jpg"
- target_img_size = 160
- IsCatchVideoQuit = False
- IsFaceDectecdQuit = False
- name = input('please input your name:')
- window_name = "face picture entry"
- src_path,_ = os.path.split(os.path.realpath(__file__))
- print(src_path)
- data_dir = os.path.join(src_path,"data")
- print(data_dir)
- output_dir = os.path.join(data_dir,name)
- #size = 64
- img_dir = os.path.join(src_path,"images")
- size_dir = os.path.join(img_dir,"%d" % target_img_size)
- if not os.path.exists(output_dir):
- os.makedirs(output_dir)
- # 改变图片的亮度与对比度
- def relight(img, light=1, bias=0):
- w = img.shape[1]
- h = img.shape[0]
- #image = []
- for i in range(0,w):
- for j in range(0,h):
- for c in range(3):
- tmp = int(img[j,i,c]*light + bias)
- if tmp > 255:
- tmp = 255
- elif tmp < 0:
- tmp = 0
- img[j,i,c] = tmp
- return img
- #使用dlib自带的frontal_face_detector作为我们的特征提取器
- detector = dlib.get_frontal_face_detector()
- #videoName = './' + name + '.avi'
- videoName = "rtsp://admin:ABC_123456@172.17.208.150:554/Streaming/Channels/101?transportmode=unicast"
- # 打开摄像头 参数为输入流,可以为摄像头或视频文件
- def CatchUsbVideo(out_queue,msg_q):
- process_flag = False
- cv2.namedWindow(window_name)
- #视频来源,可以来自一段已存好的视频,也可以直接来自USB摄像头
- cap = cv2.VideoCapture(videoName)
- n = 1
- while cap.isOpened():
- ok, frame = cap.read() #读取一帧数据
- if not ok:
- break
- #显示图像并等待10毫秒按键输入,输入‘q’退出程序
- cv2.namedWindow(window_name, cv2.WINDOW_NORMAL) #cv2.WND_PROP_FULLSCREEN)
- #cv2.moveWindow(window_name, screen.x - 1, screen.y - 1)
- cv2.setWindowProperty(window_name, cv2.WND_PROP_FULLSCREEN,
- cv2.WINDOW_FULLSCREEN)
- n = n + 1
- if n == 30:
- if process_flag == True:
- out_queue.put(frame)
- n = 1
- else:
- frameresize = cv2.resize(frame,(1280,800))
- cv2.imshow(window_name, frameresize)
- c = cv2.waitKey(10)
- if c & 0xFF == ord('q'):
- break
- if c & 0xFF == ord('d'):
- process_flag = True
- if not msg_q.empty():
- if msg_q.get() == "complate_msg":
- break
- #释放摄像头并销毁所有窗口
- cap.release()
- cv2.destroyAllWindows()
- def ConvertUseTensorflowMtcnn(in_queue,msg_q):
- margin = 32
- index_num = 0
- target_dir = os.path.join(img_dir,"images_data_%d" % target_img_size)
- output_user_dir = os.path.join(target_dir, name)
- if not os.path.exists(output_user_dir):
- os.makedirs(output_user_dir)
- minsize = 30 # minimum size of face
- threshold = [ 0.6, 0.7, 0.7 ] # three steps's threshold
- factor = 0.709 # scale factor
- with tf.Graph().as_default():
- gpu_options = tf.GPUOptions(per_process_gpu_memory_fraction=0.25)
- sess = tf.Session(config=tf.ConfigProto(gpu_options=gpu_options, log_device_placement=False))
- with sess.as_default():
- pnet, rnet, onet = detect_face.create_mtcnn(sess, None)
- while 1:
- file_name = in_queue.get()
- print("====== file: %s" % file_name)
- img = cv2.imread(file_name)
- bounding_boxes, _ = detect_face.detect_face(img, minsize, pnet, rnet, onet, threshold, factor)
- print(bounding_boxes)
- nrof_faces = bounding_boxes.shape[0]
- print(nrof_faces)
- if nrof_faces>0:
- det = bounding_boxes[:,0:4]
- det_arr = []
- img_size = np.asarray(img.shape)[0:2]
- print("====nrof_face: %d img size:" % nrof_faces)
- print(img_size)
- if nrof_faces == 1:
- bounding_box_size = (det[:,2]-det[:,0])*(det[:,3]-det[:,1])
- img_center = img_size / 2
- offsets = np.vstack([ (det[:,0]+det[:,2])/2-img_center[1], (det[:,1]+det[:,3])/2-img_center[0] ])
- offset_dist_squared = np.sum(np.power(offsets,2.0),0)
- index = np.argmax(bounding_box_size-offset_dist_squared*2.0) # some extra weight on the centering
- det_arr.append(det[index,:])
- for i, det in enumerate(det_arr):
- det = np.squeeze(det)
- bb = np.zeros(4, dtype=np.int32)
- bb[0] = np.maximum(det[0]-margin/2, 0)
- bb[1] = np.maximum(det[1]-margin/2, 0)
- bb[2] = np.minimum(det[2]+margin/2, img_size[1])
- bb[3] = np.minimum(det[3]+margin/2, img_size[0])
- cropped = img[bb[1]:bb[3],bb[0]:bb[2],:]
- scaled = misc.imresize(cropped, (target_img_size, target_img_size), interp='bilinear')
- output_filename = os.path.join(output_user_dir, ("%d" % index_num) +'.png')
- filename_base, file_extension = os.path.splitext(output_filename)
- output_filename_n = "{}{}".format(filename_base, file_extension)
- misc.imsave(output_filename_n, scaled)
- index_num += 1
- #if os.path.exists(file_name):
- #os.remove(file_name)
- if index_num >= 5:
- msg_q.put("complate_msg")
- break
- add = 30
- def FaceDectection(in_queue,out_convert_queue,msg_q):
- index = 0
- num = 0
- temporary_dir = os.path.join(output_dir,"%d" % index)
- if not os.path.exists(temporary_dir):
- os.makedirs(temporary_dir)
- while 1:
- img = in_queue.get()
- g_img = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY)
- # 使用detector进行人脸检测
- dets = detector(g_img, 1)
- for i, d in enumerate(dets):
- print("----- i:%d\n" % i)
- x1 = d.top() if d.top() > 0 else 0
- y1 = d.bottom() if d.bottom() > 0 else 0
- x2 = d.left() if d.left() > 0 else 0
- y2 = d.right() if d.right() > 0 else 0
- print("index: %d num %d " % (index,num))
- face = img[x1-add:y1 + add,x2-add:y2 + add]
- if face.shape[0] > 300 : # check picture size
- g_img = cv2.cvtColor(face, cv2.COLOR_BGR2GRAY)
- if cv2.Laplacian(g_img, cv2.CV_64F).var() < 300:
- continue
- file = os.path.join(temporary_dir,str(num)+image_extension)
- cv2.imwrite(file, face)
- #out_convert_queue.put(file)
- num += 1
- if num >= 5:
- img_file = os.path.join(temporary_dir,"*" + image_extension)
- print(img_file)
- img_name_list = glob.glob(img_file)
- for nm in img_name_list:
- out_convert_queue.put(nm)
- index += 1
- num = 0
- break
- #if __name__ == '__main__':
- # CatchUsbVideo()
- processes = []
- p = Process(target=CatchUsbVideo, args=(results_queue,message_queue,))
- p.start()
- processes.append(p)
- p = Process(target=FaceDectection, args=(results_queue,convert_queue,message_queue,))
- p.start()
- p = Process(target=ConvertUseTensorflowMtcnn, args=(convert_queue,message_queue,))
- p.start()
- for p in processes:
- p.join()
- while 1:
- time.sleep(1)
