PCI: ZYNQMP PS PCIe DMA driver: Devicetree binding for Root DMA
2105|5
 楼主| zhangmangui 发表于 2019-4-5 08:24 | 显示全部楼层 |阅读模式
Commit MessageRavi Shankar JonnalagaddaAug. 8, 2017, 11:12 a.m.
Binding explaining devicetree usage for using Root DMA capability of ZynqMPSoCSigned-off-by: Ravi Shankar Jonnalagadda <vjonnal@xilinx.com>--- .../devicetree/bindings/dma/xilinx/ps-pcie-dma.txt | 67 ++++++++++++++++++++++ 1 file changed, 67 insertions(+) create mode 100644 Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txt
Patch
diff
mbox
diff --git a/Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txt b/Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txtnew file mode 100644index 0000000..acdcc44--- /dev/null+++ b/Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txt@@ -0,0 +1,67 @@ +* Xilinx PS PCIe Root DMA++Required properties:+- compatible: Should be "xlnx,ps_pcie_dma-1.00.a"+- reg: Register offset for Root DMA channels+- reg-names: Name for the register. Should be "ps_pcie_regbase"+- interrupts: Interrupt pin for Root DMA+- interrupt-names: Name for the interrupt. Should be "ps_pcie_rootdma_intr"+- interrupt-parent: Should be gic in case of zynqmp+- rootdma: Indicates this platform device is root dma.+        This is required as the same platform driver will be invoked by pcie end points too+- dma_vendorid: 16 bit PCIe device vendor id.+        This can be later used by dma client for matching while using dma_request_channel+- dma_deviceid: 16 bit PCIe device id+        This can be later used by dma client for matching while using dma_request_channel+- numchannels: Indicates number of channels to be enabled for the device.+        Valid values are from 1 to 4 for zynqmp+- ps_pcie_channel : One for each channel to be enabled.+        This array contains channel specific properties.+        Index 0: Direction of channel+                Direction of channel can be either PCIe Memory to AXI memory i.e., Host to Card or+                AXI Memory to PCIe memory i.e., Card to Host+                PCIe to AXI Channel Direction is represented as 0x1+                AXI to PCIe Channel Direction is represented as 0x0+        Index 1: Number of Buffer Descriptors+                This number describes number of buffer descriptors to be allocated for a channel+        Index 2: Number of Queues+                Each Channel has four DMA Buffer Descriptor Queues.+                By default All four Queues will be managed by Root DMA driver.+                User may choose to have only two queues either Source and it's Status Queue or+                        Destination and it's Status Queue to be handled by Driver.+                The other two queues need to be handled by user logic which will not be part of this driver.+                All Queues on Host is represented by 0x4+                Two Queues on Host is represented by 0x2+        Index 3: Coalesce Count+                This number indicates the number of transfers after which interrupt needs to+                be raised for the particular channel. The allowed range is from 0 to 255+        Index 4: Coalesce Count Timer frequency+                This property is used to control the frequency of poll timer. Poll timer is+                created for a channel whenever coalesce count value (>= 1) is programmed for the particular+                channel. This timer is helpful in draining out completed transactions even though interrupt is+                not generated.++Client Usage:+        DMA clients can request for these channels using dma_request_channel API+++Xilinx PS PCIe Root DMA node Example+++++++++++++++++++++++++++++++++++++++        pci_rootdma: rootdma@fd0f0000 {+                compatible = "xlnx,ps_pcie_dma-1.00.a";+                reg = <0x0 0xfd0f0000 0x0 0x1000>;+                reg-names = "ps_pcie_regbase";+                interrupts = <0 117 4>;+                interrupt-names = "ps_pcie_rootdma_intr";+                interrupt-parent = <&gic>;+                rootdma;+                dma_vendorid = /bits/ 16 <0x10EE>;+                dma_deviceid = /bits/ 16 <0xD021>;+                numchannels = <0x4>;+                #size-cells = <0x5>;+                ps_pcie_channel0 = <0x1 0x7CF 0x4 0x0 0x3E8>;+                ps_pcie_channel1 = <0x0 0x7CF 0x4 0x0 0x3E8>;+                ps_pcie_channel2 = <0x1 0x7CF 0x4 0x0 0x3E8>;+                ps_pcie_channel3 = <0x0 0x7CF 0x4 0x0 0x3E8>;+    };
 楼主| zhangmangui 发表于 2019-4-5 08:51 | 显示全部楼层
 楼主| zhangmangui 发表于 2019-4-5 09:35 | 显示全部楼层
 楼主| zhangmangui 发表于 2019-4-5 09:38 | 显示全部楼层
 楼主| zhangmangui 发表于 2019-4-5 10:00 | 显示全部楼层
 楼主| zhangmangui 发表于 2019-4-5 22:19 | 显示全部楼层
个人签名:欢迎进入【TI DSP 论坛】 & 【DSP 技术】           TI忠诚粉丝!
935
