- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V0.10
- * $Revision: 2 $
- * $Date: 14/01/28 11:43a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] ADC and PWM sample for M051 learning board
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M051Series.h"
- #include "lcd_driver.h"
- void SYS_Init(void)
- /* Init System Clock */
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Enable ADC and PWM23 clock */
- CLK->APBCLK = CLK_APBCLK_PWM23_EN_Msk | CLK_APBCLK_ADC_EN_Msk;
- /* ADC clock source is 22.1184MHz, set divider to (3 + 1), ADC clock is 22.1184/4 MHz */
- CLK->CLKDIV |= (3 << CLK_CLKDIV_ADC_N_Pos);
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set P4.3 to PWM3 function */
- SYS->P4_MFP = SYS_MFP_P43_PWM3;
- /* Set P1.0 to AIN0 function */
- SYS->P1_MFP = SYS_MFP_P10_AIN0;
- /* Disable digital input path of analog pin AIN0 to prevent leakage */
- P1->OFFD |= 1 << GPIO_OFFD_OFFD_Pos;
- /* Lock protected registers */
- SYS_LockReg();
- void PWM_Init(void)
- /* Set PWM 3 clock prescale to 60, and divider to 1*/
- PWMA->PPR = 60 << PWM_PPR_CP23_Pos;
- PWMA->CSR = PWM_CLK_DIV_1 << PWM_CSR_CSR3_Pos;
- /* Enable PWM3 and set to auto-reload mode.
- Configure PWM mode before setting CNR, CMR. Otherwise CNR will be reset */
- PWMA->PCR = PWM_PCR_CH3EN_Msk | PWM_PCR_CH3MOD_Msk;
- /* PWM 3 frequency = HCLK / (prescale * divider * (CNR + 1))
- PWM 3 duty ratio = (CMR + 1) / (CNR + 1) */
- PWMA->CNR3 = 1843 - 1;
- PWMA->CMR3 = 1833 - 1;
- /* Enable PWM3 Output */
- PWMA->POE = PWM_POE_PWM3_Msk;
- void ADC_Init(void)
- /* Set to convert ADC channel 0 */
- ADC->ADCHER = 0x1;
- /* Enable the ADC converter */
- ADC->ADCR = ADC_ADCR_ADEN_Msk;
- /* Main function */
- int main(void)
- uint32_t u32Data, u32Sum, u32Count;
- char adc_value[20];
- /* Init System, IP clock and multi-function I/O
- In the end of SYS_Init() will issue SYS_LockReg()
- to lock protected register. If user want to write
- protected register, please issue SYS_UnlockReg()
- to unlock protected register if necessary */
- SYS_Init();
- /* Initial LCD panel. SPI clock and interface is configured in this function. */
- LCD_Init();
- /* Clear LCD screen. Do this before turn back light on */
- LCD_ClearScreen();
- /* Enable LCD back light */
- LCD_EnableBackLight();
- /* Show messages on LCD */
- LCD_Print(0, "ADC_PWM");
- LCD_Print(1, "Sample code");
- LCD_Print(2, "ADC Value:");
- /* Init PWM channel 3 */
- PWM_Init();
- /* Init ADC to get the value of variable resistor */
- ADC_Init();
- u32Count = 0;
- u32Sum = 0;
- while(1)
- /* Start convert */
- ADC_START_CONV(ADC);
- /* Waiting for convert complete */
- while(ADC_IS_BUSY(ADC));
- /* Read the result from ADC */
- u32Data = ADC->ADDR[0] & ADC_ADDR_RSLT_Msk;
- /* Determine the sum */
- u32Sum += u32Data;
- u32Count++;
- if(u32Count == 128)
- /* Determine the average */
- u32Data = u32Sum / 128;
- /* Update the average ADC conversion result to LCD */
- sprintf(adc_value, " %4d", u32Data);
- LCD_Print(3, adc_value);
- /* Adjust the duty cycle of PWM3 according to the average ADC value. */
- PWMA->CMR3 = (u32Data * PWMA->CNR3) / 4096;
- /* Reset count and sum */
- u32Count = 0;
- u32Sum = 0;
- /*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
