| #include"DSP28x_Project.h"
 #define CPU_CLK 150e6   //系统时钟150MHz
 #define TBCTLVAL 0x200E     //控制寄存器的值
 Uint32 PWM_CLK,PWM_CLK1,PWM_CLK2;
 float SP,SP1,SP2;
 void main(void)
 InitSysCtrl();   //初始化系统
 InitGpio();     //初始化GPIIO
 InitPieCtrl();  //清除所有中断
 IER = 0x0000;
 IFR = 0x0000;
 InitPieVectTable();  //初始化中断向量表
 InitEPwm3Gpio();    //初始化PWM1引脚
 PWM_CLK = 1000;
 SP = CPU_CLK/(2*PWM_CLK);
 EPwm3Regs.TBSTS.all = 0;   //将时基的状态寄存器清零
 EPwm3Regs.TBPHS.half.TBPHS = 0;  //相位寄存器设置为0
 EPwm3Regs.TBCTR = 0;   //时基计数器清零
 EPwm3Regs.CMPCTL.all = 0x50;  //CMPA和CMPB配置为立即模式
 EPwm3Regs.CMPA.half.CMPA = SP/2;  //设置占空比为0.5,SP是周期寄存器的值
 EPwm3Regs.CMPB = 0;
 EPwm3Regs.AQCTLA.all = 0x60;   //当时间基准计数器的值等于CMPA的值,且正在递增计数,EPWMxA输出高电平;当时间基准计数器的值等于CMPA的值,且正在递减计数,EPWMxA输出低电平
 EPwm3Regs.AQCTLB.all = 0;
 EPwm3Regs.AQSFRC.all = 0;
 EPwm3Regs.AQCSFRC.all = 0;
 EPwm3Regs.DBCTL.all = 0xb;    //EPwm1B与EPwm1A相关联,即EPwm1B随着EPwm1A的变化而变化
 EPwm3Regs.DBRED = 25;          //上升沿的死区时间设置为25
 EPwm3Regs.DBFED = 25;          //下降沿的死区时间设置为25
 EPwm3Regs.TZSEL.all = 0;      //没有用到联防区模块,全部失效
 EPwm3Regs.TZCTL.all = 0;
 EPwm3Regs.TZEINT.all = 0;
 EPwm3Regs.TZ**.all = 0;
 EPwm3Regs.TZCLR.all = 0;
 EPwm3Regs.TZFRC.all = 0;
 EPwm3Regs.ETSEL.all = 0;
 EPwm3Regs.ET**.all = 0;
 EPwm3Regs.ETCLR.all = 0;
 EPwm3Regs.ETFRC.all = 0;
 EPwm3Regs.PCCTL.all = 0;
 EPwm3Regs.TBCTL.all = 0x0010 + TBCTLVAL;    //增减模式
 EPwm3Regs.TBPRD = SP;
 PWM_CLK1 = 500;
 SP1 = CPU_CLK/(2*PWM_CLK1);
 InitEPwm1Gpio();
 EPwm1Regs.TBSTS.all = 0;   //将时基的状态寄存器清零
 EPwm1Regs.TBPHS.half.TBPHS = 0;  //相位寄存器设置为0
 EPwm1Regs.TBCTR = 0;   //时基计数器清零
 EPwm1Regs.CMPCTL.all = 0x50;  //CMPA和CMPB配置为立即模式
 EPwm1Regs.CMPA.half.CMPA = SP1/2;  //设置占空比为0.5,SP是周期寄存器的值
 EPwm1Regs.CMPB = 0;
 EPwm1Regs.AQCTLA.all = 0x60;   //当时间基准计数器的值等于CMPA的值,且正在递增计数,EPWMxA输出高电平;当时间基准计数器的值等于CMPA的值,且正在递减计数,EPWMxA输出低电平
 EPwm1Regs.AQCTLB.all = 0;
 EPwm1Regs.AQSFRC.all = 0;
 EPwm1Regs.AQCSFRC.all = 0;
 EPwm1Regs.DBCTL.all = 0xb;    //EPwm1B与EPwm1A相关联,即EPwm1B随着EPwm1A的变化而变化
 EPwm1Regs.DBRED = 25;          //上升沿的死区时间设置为25
 EPwm1Regs.DBFED = 25;          //下降沿的死区时间设置为25
 EPwm1Regs.TZSEL.all = 0;      //没有用到联防区模块,全部失效
 EPwm1Regs.TZCTL.all = 0;
 EPwm1Regs.TZEINT.all = 0;
 EPwm1Regs.TZ**.all = 0;
 EPwm1Regs.TZCLR.all = 0;
 EPwm1Regs.TZFRC.all = 0;
 EPwm1Regs.ETSEL.all = 0;
 EPwm1Regs.ET**.all = 0;
 EPwm1Regs.ETCLR.all = 0;
 EPwm1Regs.ETFRC.all = 0;
 EPwm1Regs.PCCTL.all = 0;
 EPwm1Regs.TBCTL.all = 0x0010 + TBCTLVAL;    //增减模式
 EPwm1Regs.TBPRD = SP1;
 PWM_CLK2 = 2000;
 SP2 = CPU_CLK/(2*PWM_CLK2);
 InitEPwm2Gpio();
 EPwm2Regs.TBSTS.all = 0;   //将时基的状态寄存器清零
 EPwm2Regs.TBPHS.half.TBPHS = 0;  //相位寄存器设置为0
 EPwm2Regs.TBCTR = 0;   //时基计数器清零
 EPwm2Regs.CMPCTL.all = 0x50;  //CMPA和CMPB配置为立即模式
 EPwm2Regs.CMPA.half.CMPA = SP2/2;  //设置占空比为0.5,SP是周期寄存器的值
 EPwm2Regs.CMPB = 0;
 EPwm2Regs.AQCTLA.all = 0x60;   //当时间基准计数器的值等于CMPA的值,且正在递增计数,EPWMxA输出高电平;当时间基准计数器的值等于CMPA的值,且正在递减计数,EPWMxA输出低电平
 EPwm2Regs.AQCTLB.all = 0;
 EPwm2Regs.AQSFRC.all = 0;
 EPwm2Regs.AQCSFRC.all = 0;
 EPwm2Regs.DBCTL.all = 0xb;    //EPwm1B与EPwm1A相关联,即EPwm1B随着EPwm1A的变化而变化
 EPwm2Regs.DBRED = 25;          //上升沿的死区时间设置为25
 EPwm2Regs.DBFED = 25;          //下降沿的死区时间设置为25
 EPwm2Regs.TZSEL.all = 0;      //没有用到联防区模块,全部失效
 EPwm2Regs.TZCTL.all = 0;
 EPwm2Regs.TZEINT.all = 0;
 EPwm2Regs.TZ**.all = 0;
 EPwm2Regs.TZCLR.all = 0;
 EPwm2Regs.TZFRC.all = 0;
 EPwm2Regs.ETSEL.all = 0;
 EPwm2Regs.ET**.all = 0;
 EPwm2Regs.ETCLR.all = 0;
 EPwm2Regs.ETFRC.all = 0;
 EPwm2Regs.PCCTL.all = 0;
 EPwm2Regs.TBCTL.all = 0x0010 + TBCTLVAL;    //增减模式
 EPwm2Regs.TBPRD = SP2;
 for(; ;)
 //看了示波器,只有输出2000Hz的波形,其他500Hz和1000Hz的为啥没有??哪里写错了,请指教,小白一枚。
