- //74HC138引脚:P22,P23,P24,P25,P26,P27
- //24C02引脚:P20-SDA,P21-SCL
- //red595:11脚-P10,12脚-P11,14脚-P12,13脚控制脚-P16
- //green595:11脚-P13,12脚-P14,14脚-P15,13脚控制脚-P17
- //74HC595:11脚SH_CP是数据输入时钟线,12脚ST_CP是输出存储器锁存时钟线,13脚OE是输出有效(低电平有效),14脚DS是串行数据输入
- #include <intrins.h>
- #include <REGX52.H>
- #define uint unsigned int
- #define uchar unsigned char
- sbit saomiao1=P2^2;
- sbit saomiao2=P2^3;
- sbit saomiao3=P2^4;
- sbit saomiao4=P2^5;
- sbit saomiao5=P2^6;
- sbit saomiao6=P2^7;
- sbit redSH_CP=P1^0;
- sbit redST_CP=P1^1;
- sbit redOE=P1^6;
- sbit redDS=P1^2;
- sbit greenSH_CP=P1^3;
- sbit greenST_CP=P1^4;
- sbit greenOE=P1^7;
- sbit greenDS=P1^5;
- uchar a;
- uchar code display[]=
- 0xF7,0xF6,0x31,0x47,0xF7,0xFF,0xFD,0x85,0xB5,0xB5,0xB5,0xB5,0xB5,0x85,0xFD,0xFF,
- 0xFD,0xFE,0x00,0xFF,0xFC,0xFF,0x00,0xB6,0xB6,0xB6,0x80,0xB6,0xB6,0xB6,0x00,0xFF
- }; //福
- void delay(uint b)//延时
- while(b--);
- void shuaxin(uchar a)//138译码器刷新列
- switch(a)
- case(1):
- saomiao4=1;saomiao5=1;saomiao6=1; break;
- case(2):
- saomiao4=0;saomiao5=1;saomiao6=1; break;
- case(3):
- saomiao4=1;saomiao5=0;saomiao6=1; break;
- case(4):
- saomiao4=0;saomiao5=0;saomiao6=1; break;
- case(5):
- saomiao4=1;saomiao5=1;saomiao6=0; break;
- case(6):
- saomiao4=0;saomiao5=1;saomiao6=0; break;
- case(7):
- saomiao4=1;saomiao5=0;saomiao6=0; break;
- case(8):
- saomiao4=0;saomiao5=0;saomiao6=0; break;
- case(9):
- saomiao1=1;saomiao2=1;saomiao3=1; break;
- case(10):
- saomiao1=0;saomiao2=1;saomiao3=1; break;
- case(11):
- saomiao1=1;saomiao2=0;saomiao3=1; break;
- case(12):
- saomiao1=0;saomiao2=0;saomiao3=1; break;
- case(13):
- saomiao1=1;saomiao2=1;saomiao3=0; break;
- case(14):
- saomiao1=0;saomiao2=1;saomiao3=0; break;
- case(15):
- saomiao1=1;saomiao2=0;saomiao3=0; break;
- case(16):
- saomiao1=0;saomiao2=0;saomiao3=0; break;
- default :break;
- void Init_red595(uchar valueL,uchar valueH)//红色595发送函数初始化
- uchar i;
- for(i=0;i<8;i++)
- redDS=valueL>>7;//把valueL最高位的值赋给redDS
- valueL<<=1;//把valueL原来的值左移一位,再赋值给valueL,(有赋值操作,所以会改变原先的值)多出来的最低位自动用0来填充,valueL的最高位发送出去
- redSH_CP=0;
- _nop_();
- _nop_();
- redSH_CP=1;
- for(i=0;i<8;i++)
- redDS=valueH>>7;
- valueH<<=1;
- redSH_CP=0;
- _nop_();
- _nop_();
- redSH_CP=1;
- redST_CP=0;
- _nop_();
- _nop_();
- redST_CP=1;
- void red_send()//发送红色点阵数据
- uint index;
- greenOE=1;//绿色595输出不使能
- for(index=1;index<17;index++)
- redOE=1;//红色595输出不使能
- shuaxin(index);//138译码器刷新
- Init_red595(display[index+16],display[index]);//带入红色点阵要发送的数据
- redOE=0;//红色595输出使能
- delay(500);
- void Init_green595(uchar valueL,uchar valueH)//绿色595发送函数初始化
- uchar i;
- for(i=0;i<8;i++)
- greenDS=valueL>>7;
- valueL<<=1;
- greenSH_CP=0;
- _nop_();
- _nop_();
- greenSH_CP=1;
- for(i=0;i<8;i++)
- greenDS=valueH>>7;
- valueH<<=1;
- greenSH_CP=0;
- _nop_();
- _nop_();
- greenSH_CP=1;
- greenST_CP=0;
- _nop_();
- _nop_();
- greenST_CP=1;
- void green_send()//发送绿色点阵数据
- uint index;
- Init_green595(display[index+16],display[index]);//带入绿色点阵要发送的数据
- greenOE=0;//绿色595输出使能
- delay(500);
- void main()
- while(1)
- red_send();//红色显示
- //green_send();//绿色显示
