[牛人杂谈] NUC029SGE的VBG
557|3
 楼主| 玛尼玛尼哄 发表于 2020-7-28 21:15 | 显示全部楼层 |阅读模式
 楼主| 玛尼玛尼哄 发表于 2020-7-28 21:16 | 显示全部楼层
DS_NUC029xGE_Series_EN_Rev1.00.pdf (2.17 MB, 下载次数: 0)
 楼主| 玛尼玛尼哄 发表于 2020-7-28 21:18 | 显示全部楼层
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
  4. * $Revision: 3 $
  5. * $Date: 17/05/04 1:15p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Perform A/D Conversion with ADC single cycle scan mode.
  7. * @note
  8. * Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
  9. *
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "NUC029xGE.h"
  13. #define PLL_CLOCK       72000000
  14. /*---------------------------------------------------------------------------------------------------------*/
  15. /* Define Function Prototypes        */
  16. /*---------------------------------------------------------------------------------------------------------*/
  17. void SYS_Init(void);
  18. void UART0_Init(void);
  19. void AdcVBG(void);
  20. void SYS_Init(void)
  21. {
  22.     /*---------------------------------------------------------------------------------------------------------*/
  23.     /* Init System Clock        */
  24.     /*---------------------------------------------------------------------------------------------------------*/
  25.     /* Enable HIRC clock (Internal RC 22.1184MHz) */
  26.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  27.     /* Waiting for HIRC clock ready */
  28.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  29.     /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
  30.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  31.     /* Enable HXT clock (external XTAL 12MHz) */
  32.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  33.     /* Waiting for HXT clock ready */
  34.     CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
  35.     /* Set core clock as PLL_CLOCK from PLL */
  36.     CLK_SetCoreClock(PLL_CLOCK);
  37.     /* Waiting for PLL clock ready */
  38.     CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
  39.     /* Enable UART module clock */
  40.     CLK_EnableModuleClock(UART0_MODULE);
  41.     /* Enable ADC module clock */
  42.     CLK_EnableModuleClock(ADC_MODULE);
  43.     /* Select UART module clock source as HXT and UART module clock divider as 1 */
  44.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
  45.     /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
  46.     CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADCSEL_HIRC, CLK_CLKDIV0_ADC(7));
  47.     /*---------------------------------------------------------------------------------------------------------*/
  48.     /* Init I/O Multi-function        */
  49.     /*---------------------------------------------------------------------------------------------------------*/
  50.     /* Set multi-function pins for UART0 RXD and TXD */
  51.     SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
  52.     SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
  53. }
  54. /*---------------------------------------------------------------------------------------------------------*/
  55. /* Init UART        */
  56. /*---------------------------------------------------------------------------------------------------------*/
  57. void UART0_Init()
  58. {
  59.     /* Reset IP */
  60.     SYS_ResetModule(UART0_RST);
  61.     /* Configure UART0 and set UART0 Baudrate */
  62.     UART_Open(UART0, 115200);
  63. }
  64. /*---------------------------------------------------------------------------------------------------------*/
  65. /* Function: AdcSingleCycleScanModeTest        */
  66. /*        */
  67. /* Parameters:        */
  68. /*   None.        */
  69. /*        */
  70. /* Returns:        */
  71. /*   None.        */
  72. /*        */
  73. /* Description:        */
  74. /*   ADC single cycle scan mode test.        */
  75. /*---------------------------------------------------------------------------------------------------------*/
  76. void AdcVBG()
  77. {
  78.     int32_t  i32ConversionData;
  79.     printf("\n");
  80.     printf("+----------------------------------------------------------------------+\n");
  81.     printf("|                              ADC VBG                                 |\n");
  82.     printf("+----------------------------------------------------------------------+\n");
  83.     while(1)
  84.     {
  85.         printf("\n\nSelect input mode:\n");
  86.         printf("  [1] Single end input (channel 29   VBG)\n");
  87.         {
  88.             /* Set the ADC operation mode as single-cycle, input mode as single-end and
  89.                  enable the analog input channel 29 */
  90.                                                 ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE_CYCLE, BIT29);
  91.             /* Power on ADC module */
  92.             ADC_POWER_ON(ADC);
  93.             /* Clear the A/D interrupt flag for safe */
  94.             ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  95.
  96.             /* Start A/D conversion */
  97.             ADC_START_CONV(ADC);
  98.             /* Wait conversion done */
  99.            while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT)){}
  100.             {
  101.                i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 29);
  102.                printf("VBG Conversion result of channel %d: 0x%X (%d)\n", 29, i32ConversionData, i32ConversionData);
  103.
  104.             }
  105.                                                 printf("\n--按任意键进入下一次测试--\n");
  106.                                                 getchar();
  107.         }
  108.     }
  109. }
  110. /*---------------------------------------------------------------------------------------------------------*/
  111. /* MAIN function        */
  112. /*---------------------------------------------------------------------------------------------------------*/
  113. int main(void)
  114. {
  115.     /* Unlock protected registers */
  116.     SYS_UnlockReg();
  117.     /* Init System, IP clock and multi-function I/O */
  118.     SYS_Init();
  119.     /* Lock protected registers */
  120.     SYS_LockReg();
  121.     /* Init UART0 for printf */
  122.     UART0_Init();
  123.     /*---------------------------------------------------------------------------------------------------------*/
  124.     /* SAMPLE CODE        */
  125.     /*---------------------------------------------------------------------------------------------------------*/
  126.     printf("\nSystem clock rate: %d Hz", SystemCoreClock);
  127.     /* Single cycle scan mode test */
  128.     AdcVBG();
  129.     /* Disable ADC module */
  130.     ADC_Close(ADC);
  131.     /* Disable ADC IP clock */
  132.     CLK_DisableModuleClock(ADC_MODULE);
  133.     /* Disable External Interrupt */
  134.     NVIC_DisableIRQ(ADC_IRQn);
  135.     printf("\nExit ADC sample code\n");
  136.     while(1);
  137. }
  138. /*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
根据这个结果测量VBG=1642,而12位的ADC满量程为4095
根据比例可以求出VCC=4095*1.21/1642=3.0176V
完全符合实际。
gaoyang9992006 发表于 2020-7-28 21:19 | 显示全部楼层
好像这个系列没有中文手册的,所以用起来有点小难。。。。
