试了一下,刚开始以为是楼主没处理发送中断。。结果不是 啊,好奇怪。
- #include "ML51.h"
- unsigned char c;
- void UART0_ISR(void) interrupt 4
- if((SCON&SET_BIT0)==SET_BIT0)
- c = SBUF;
- SBUF = c;
- clr_SCON_RI;
- else if((SCON&SET_BIT1)==SET_BIT1)
- clr_SCON_TI;
- P03 ^= 1;
- void main (void)
- //LED端口初始化为数字输出推挽模式
- MFP_P03_GPIO;
- P03_PUSHPULL_MODE;
- For UART0 P0.5 asTXD output setting
- * include uart.c in Common Setting for UART0
- MFP_P31_UART0_TXD; /* set P3.1 and P3.0 as Quasi mode for UART0 trasnfer */
- MFP_P30_UART0_RXD;
- P31_QUASI_MODE;
- P30_QUASI_MODE;
- UART_Open(24000000,UART0_Timer1,115200); // Open UART0 use timer1 as baudrate generate and baud rate = 115200
- //启用串口0中断,并开启全局中断
- UART_Interrupt_Enable(UART0,Enable);
- ENABLE_GLOBAL_INTERRUPT;
- while(1)
