AHB-2
196|0
 楼主| 怎么叫都可以 发表于 2018-9-9 11:28 | 显示全部楼层 |阅读模式
hb, AN, ADDR, AD, DDR
All transfers in a burst must be aligned to the address boundary equal to the size of the transfer. For example, you must align word transfers to word address boundaries
(HADDR[1:0]= b00), and halfword transfers to halfword address boundaries (HADDR[0]= 0). The address for IDLE transfers must also be aligned, otherwise during simulation it is likely that bus monitors could report spurious warnings.
Now Why specification hasn\'t mentioned about HADDR[1] in halfword and HADDR for byte?
Can anyone help me ???
