谁有这个函数的注释啊,大虾们显显手吧
3647|2
 楼主| darennet 发表于 2012-2-1 14:57 | 显示全部楼层 |阅读模式
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks)
  u32 tmp = 0,/* pllmull = 0, pllsource = 0,*/ presc = 0;
  u32 pll1mull = 0, pll1source = 0, prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
  /* Get SYSCLK source -------------------------------------------------------*/
  tmp = RCC->CFGR & CFGR_SWS_Mask;
  switch (tmp)
    case 0x00:  /* HSI used as system clock */
      RCC_Clocks->SYSCLK_Frequency = HSI_Value;
      break;
    case 0x04:  /* HSE used as system clock */
      RCC_Clocks->SYSCLK_Frequency = HSE_Value;
      break;
    case 0x08:  /* PLL used as system clock */
     /* Get PLL clock source and multiplication factor ----------------------*/
    pllmull = RCC->CFGR & CFGR_PLLMull_Mask;
      pllmull = ( pllmull >> 18) + 2;
     pllsource = RCC->CFGR & CFGR_PLLSRC_Mask
     if (pllsource == 0x00)
      {/* HSI oscillator clock divided by 2 selected as PLL clock entry */
       RCC_Clocks->SYSCLK_Frequency = (HSI_Value >> 1) * pllmull;
     else
     {/* HSE selected as PLL clock entry */
        if ((RCC->CFGR & CFGR_PLLXTPRE_Mask) != (u32)RESET)
       {/* HSE oscillator clock divided by 2 */
        RCC_Clocks->SYSCLK_Frequency = (HSE_Value >> 1) * pllmull;
       else
         RCC_Clocks->SYSCLK_Frequency = HSE_Value * pllmull;
      break;
/* STM32 connectivity line devices */
      /* Get PLL1 clock source and multiplication factor */
      pll1mull = RCC->CFGR & CFGR_PLL1Mull_Mask;
      pll1mull = ( pll1mull >> 18) + 2; /* !!!!!!!!!!! case where mul = 6.5 !!!!!!!!!!!!!!! */
      pll1source = RCC->CFGR & CFGR_PLL1SRC_Mask;
      if (pll1source == 0x00)
      {/* HSI oscillator clock divided by 2 selected as PLL1 clock entry */
        RCC_Clocks->SYSCLK_Frequency = (HSI_Value >> 1) * pll1mull;
      else
      {/* PREDIV1 selected as PLL1 clock entry */
       /* Get PREDIV1 clock source and division factor */
         prediv1source = RCC->CFGR2 & CFGR2_PREDIV1SRC;
         prediv1factor = (RCC->CFGR2 & CFGR2_PREDIV1) + 1;
        if (prediv1source == 0)
        {/* HSE oscillator clock selected as PREDIV1 clock entry */
           RCC_Clocks->SYSCLK_Frequency = (HSE_Value / prediv1factor) * pll1mull;
        else
        {/* PLL2 clock selected as PREDIV1 clock entry */
         /* Get PREDIV2 division factor and PLL2 multiplication factor */
            prediv2factor = ((RCC->CFGR2 & CFGR2_PREDIV2) >> 4) + 1;
            pll2mull = ((RCC->CFGR2 & CFGR2_PLL2MUL) >> 8 ) + 2;
            RCC_Clocks->SYSCLK_Frequency = (((HSE_Value / prediv2factor) * pll2mull) / prediv1factor) * pll1mull;
      break;
    default:
      break;
  /* Compute HCLK, PCLK1, PCLK2 and ADCCLK clocks frequencies ----------------*/
  /* Get HCLK prescaler */
  tmp = RCC->CFGR & CFGR_HPRE_Set_Mask;
  tmp = tmp >> 4;
  presc = APBAHBPrescTable[tmp];
  /* HCLK clock frequency */
  RCC_Clocks->HCLK_Frequency = RCC_Clocks->SYSCLK_Frequency >> presc;
  /* Get PCLK1 prescaler */
  tmp = RCC->CFGR & CFGR_PPRE1_Set_Mask;
  tmp = tmp >> 8;
  /* PCLK1 clock frequency */
  RCC_Clocks->PCLK1_Frequency = RCC_Clocks->HCLK_Frequency >> presc;
  /* Get PCLK2 prescaler */
  tmp = RCC->CFGR & CFGR_PPRE2_Set_Mask;
  tmp = tmp >> 11;
  /* PCLK2 clock frequency */
  RCC_Clocks->PCLK2_Frequency = RCC_Clocks->HCLK_Frequency >> presc;
  /* Get ADCCLK prescaler */
  tmp = RCC->CFGR & CFGR_ADCPRE_Set_Mask;
  tmp = tmp >> 14;
  presc = ADCPrescTable[tmp];
  /* ADCCLK clock frequency */
  RCC_Clocks->ADCCLK_Frequency = RCC_Clocks->PCLK2_Frequency / presc;
airwill 发表于 2012-2-3 08:19 | 显示全部楼层
这段代码里的注释已经比较详细了, 至于要更明白的说明, 可以看库带的 Reference_Manual, 以及数据手册里 cpu 各寄存器的介绍.
haitao10086 发表于 2012-2-3 14:24 | 显示全部楼层
