[技术问答] M487 power down mode
751|7
 楼主| 两只袜子 发表于 2020-12-10 11:01 | 显示全部楼层 |阅读模式
請問:
      我使用NuMaker-IoT-M487 開發板, 測試 SYS_SPDMode_Wakeup 這包sample code 然後在debug模式下執行, 並選擇RTC alarm進入power down mode , 接著在UART1視窗看到
      如下訊息後, 就沒看到有wake up的動作, 我將程式停止後 只看到停在這行程式而已 /* Restore HIRC control register */
    SYS->IRCTCTL = u32HIRCTRIMCTL;     請問這code的具體動作是如何以及怎麼知道已經喚醒?謝謝!!
CPU @ 192000000 Hz
Power manager Power Manager Status 0x0
|    SPD Power-down Mode and Wake-up Sample Code                  |
|    Please Select Power Down Mode and Wake up source.            |
|[1] SPD0 GPIO Wake-up pin(PA.0) and using rising edge wake up.   |
|[2] SPD0 Wake-up TIMER time-out interval is 1024 OSC10K clocks.  |
|[3] SPD0 Wake-up by ACMP0.(band-gap voltage)                     |
|[4] SPD0 Wake-up by RTC Tick.                                    |
|[5] SPD0 Wake-up by RTC Alarm.                                   |
|[6] SPD0 Wake-up by RTC Tamper0(PF.6), Low level.                |
|[7] SPD0 Wake-up by BOD.                                         |
|[8] SPD0 Wake-up by LVR.                                         |
|[a] SPD1 GPIO Wake-up pin(PA.0) and using rising edge wake up.   |
| SPD1 Wake-up TIMER time-out interval is 1024 OSC10K clocks.  |
|[c] SPD1 Wake-up by ACMP0.(band-gap voltage)                     |
|[d] SPD1 Wake-up by RTC Tick.                                    |
|[e] SPD1 Wake-up by RTC Alarm.                                   |
|[f] SPD1 Wake-up by RTC Tamper0(PF.6), Low level.                |
|[g] SPD1 Wake-up by BOD.                                         |
|[h] SPD1 Wake-up by LVR.                                         |
# Set RTC current date/time: 2020/09/04 10:00:00.
# Set RTC alarm   date/time: 2020/09/04 10:00:59.
Enter to SPD0 Power-Down mode......
gejigeji521 发表于 2020-12-10 22:47 | 显示全部楼层
这个系列没用过。
wiba 发表于 2021-1-7 12:10 | 显示全部楼层
可以通过何种方式唤醒呢
zljiu 发表于 2021-1-7 12:11 | 显示全部楼层
看看有没有相应的工作状态表现就行啊
coshi 发表于 2021-1-7 12:12 | 显示全部楼层
只有这一种掉电模式吗
aoyi 发表于 2021-1-7 12:13 | 显示全部楼层
有没有相应的数据手册啊
drer 发表于 2021-1-7 12:15 | 显示全部楼层
外部中断应该可以唤醒
powerantone 发表于 2021-2-11 11:59 | 显示全部楼层
SPD模式不支持DEBUG下运行,请全速运行进行测试
