PCB专业英语
3049|1
 楼主| itxss 发表于 2009-7-28 13:12 | 显示全部楼层 |阅读模式
PCB, TI, IO, ST, TE
PCB专业英语<br /><br /><br />流程简介:开料--钻孔--干膜制程--压合--减铜--电镀--塞孔--防焊(绿漆/绿油)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;--镀金--喷锡--成型--开短路测试--终检--雷射钻孔<br /><br />A.&nbsp;开料(&nbsp;Cut&nbsp;Lamination)<br />a-1&nbsp;裁板(&nbsp;Sheets&nbsp;Cutting)<br />a-2&nbsp;原物料发料(Panel)(Shear&nbsp;material&nbsp;to&nbsp;Size)<br /><br />B.&nbsp;钻孔(Drilling)<br />b-1&nbsp;内钻(Inner&nbsp;Layer&nbsp;Drilling&nbsp;)<br />b-2&nbsp;一次孔(Outer&nbsp;Layer&nbsp;Drilling&nbsp;)<br /><br />b-3&nbsp;二次孔(2nd&nbsp;Drilling)<br /><br />b-4&nbsp;雷射钻孔(Laser&nbsp;Drilling&nbsp;)(Laser&nbsp;Ablation&nbsp;)<br /><br />b-5&nbsp;盲(埋)孔钻孔(Blind&nbsp;&&nbsp;Buried&nbsp;Hole&nbsp;Drilling)<br /><br />C.&nbsp;干膜制程(&nbsp;Photo&nbsp;Process(D/F))<br />c-1&nbsp;前处理(Pretreatment)<br /><br />c-2&nbsp;压膜(Dry&nbsp;Film&nbsp;Lamination)<br /><br />c-3&nbsp;曝光(Exposure)<br /><br />c-4&nbsp;显影(Developing)<br /><br />c-5&nbsp;蚀铜(Etching)<br /><br />c-6&nbsp;去膜(Stripping)<br /><br />c-7&nbsp;初检(&nbsp;Touch-up)<br /><br />c-8&nbsp;化学前处理,化学研磨(&nbsp;Chemical&nbsp;Milling&nbsp;)<br /><br />c-9&nbsp;选择性浸金压膜(Selective&nbsp;Gold&nbsp;Dry&nbsp;Film&nbsp;Lamination)<br /><br />c-10&nbsp;显影(Developing&nbsp;)<br /><br />c-11&nbsp;去膜(Stripping&nbsp;)<br /><br />Developing&nbsp;,&nbsp;Etching&nbsp;&&nbsp;Stripping&nbsp;(&nbsp;DES&nbsp;)<br /><br />D.&nbsp;压合Lamination<br />d-1&nbsp;黑化(Black&nbsp;Oxide&nbsp;Treatment)<br /><br />d-2&nbsp;微蚀(Microetching)<br /><br />d-3&nbsp;铆钉组合(eyelet&nbsp;)<br /><br />d-4&nbsp;叠板(Lay&nbsp;up)<br /><br />d-5&nbsp;压合(Lamination)<br /><br />d-6&nbsp;后处理(Post&nbsp;Treatment)<br /><br />d-7&nbsp;黑氧化(&nbsp;Black&nbsp;Oxide&nbsp;Removal&nbsp;)<br /><br />d-8&nbsp;铣靶(spot&nbsp;face)<br /><br />d-9&nbsp;去溢胶(resin&nbsp;flush&nbsp;removal)<br /><br />E.&nbsp;减铜(Copper&nbsp;Reduction)<br />e-1&nbsp;薄化铜(Copper&nbsp;Reduction)<br /><br />F.&nbsp;电镀(Horizontal&nbsp;Electrolytic&nbsp;Plating)<br />f-1&nbsp;水平电镀(Horizontal&nbsp;Electro-Plating)&nbsp;(Panel&nbsp;Plating)<br /><br />f-2&nbsp;锡铅电镀(&nbsp;Tin-Lead&nbsp;Plating&nbsp;)&nbsp;(Pattern&nbsp;Plating)<br /><br />f-3&nbsp;低于1&nbsp;mil&nbsp;(&nbsp;Less&nbsp;than&nbsp;1&nbsp;mil&nbsp;Thickness&nbsp;)<br /><br />f-4&nbsp;高于1&nbsp;mil&nbsp;(&nbsp;More&nbsp;than&nbsp;1&nbsp;mil&nbsp;Thickness)<br /><br />f-5&nbsp;砂带研磨(Belt&nbsp;Sanding)<br /><br />f-6&nbsp;剥锡铅(&nbsp;Tin-Lead&nbsp;Stripping)<br /><br />f-7&nbsp;微切片(&nbsp;Microsection)<br /><br />G.&nbsp;塞孔(Plug&nbsp;Hole)<br />g-1&nbsp;印刷(&nbsp;Ink&nbsp;Print&nbsp;)<br /><br />g-2&nbsp;预烤(Precure)<br /><br />g-3&nbsp;表面刷磨(Scrub)<br /><br />g-4&nbsp;后烘烤(Postcure)<br /><br />H.&nbsp;防焊(绿漆/绿油):&nbsp;(Solder&nbsp;Mask)<br />h-1&nbsp;C面印刷(Printing&nbsp;Top&nbsp;Side)<br /><br />h-2&nbsp;S面印刷(Printing&nbsp;Bottom&nbsp;Side)<br /><br />h-3&nbsp;静电喷涂(Spray&nbsp;Coating)<br /><br />h-4&nbsp;前处理(Pretreatment)<br /><br />h-5&nbsp;预烤(Precure)<br /><br />h-6&nbsp;曝光(Exposure)<br /><br />h-7&nbsp;显影(Develop)<br /><br />h-8&nbsp;后烘烤(Postcure)<br /><br />h-9&nbsp;UV烘烤(UV&nbsp;Cure)<br /><br />h-10&nbsp;文字印刷(&nbsp;Printing&nbsp;of&nbsp;Legend&nbsp;)<br /><br />h-11&nbsp;喷砂(&nbsp;Pumice)(Wet&nbsp;Blasting)<br /><br />h-12&nbsp;印可剥离防焊(Peelable&nbsp;Solder&nbsp;Mask)<br /><br />I&nbsp;.&nbsp;镀金Gold&nbsp;plating<br />i-1&nbsp;金手指镀镍金(&nbsp;Gold&nbsp;Finger&nbsp;)<br /><br />i-2&nbsp;电镀软金(Soft&nbsp;Ni/Au&nbsp;Plating)<br /><br />i-3&nbsp;浸镍金(&nbsp;Immersion&nbsp;Ni/Au)&nbsp;(Electroless&nbsp;Ni/Au)<br /><br />J.&nbsp;喷锡(Hot&nbsp;Air&nbsp;Solder&nbsp;Leveling)<br />j-1&nbsp;水平喷锡(Horizontal&nbsp;Hot&nbsp;Air&nbsp;Solder&nbsp;Leveling)<br /><br />j-2&nbsp;垂直喷锡(&nbsp;Vertical&nbsp;Hot&nbsp;Air&nbsp;Solder&nbsp;Leveling)<br /><br />j-3&nbsp;超级焊锡(Super&nbsp;Solder&nbsp;)<br /><br />j-4.&nbsp;印焊锡突点(Solder&nbsp;Bump)<br /><br />K.&nbsp;成型(Profile)(Form)<br />k-1&nbsp;捞型(N/C&nbsp;Routing&nbsp;)&nbsp;(Milling)<br /><br />k-2&nbsp;模具冲(Punch)<br /><br />k-3&nbsp;板面清洗烘烤(Cleaning&nbsp;&&nbsp;Backing)<br /><br />k-4&nbsp;V型槽(&nbsp;V-Cut)(V-Scoring)<br /><br />k-5&nbsp;金手指斜边(&nbsp;Beveling&nbsp;of&nbsp;G/F)<br /><br />L.&nbsp;开短路测试(Electrical&nbsp;Testing)&nbsp;(Continuity&nbsp;&&nbsp;Insulation&nbsp;Testing)<br />l-1&nbsp;AOI&nbsp;光学检查(&nbsp;AOI&nbsp;Inspection)<br /><br />l-2&nbsp;VRS&nbsp;目检(Verified&nbsp;&&nbsp;Repaired)<br /><br />l-3&nbsp;泛用型治具测试(Universal&nbsp;Tester)<br /><br />l-4&nbsp;专用治具测试(Dedicated&nbsp;Tester)<br /><br />l-5&nbsp;飞针测试(Flying&nbsp;Probe)<br /><br />M.&nbsp;终检(&nbsp;Final&nbsp;Visual&nbsp;Inspection)<br />m-1&nbsp;压板翘(&nbsp;Warpage&nbsp;Remove)<br /><br />m-2&nbsp;X-OUT&nbsp;印刷(X-Out&nbsp;Marking)<br /><br />m-3&nbsp;包装及出货(Packing&nbsp;&&nbsp;shipping)<br /><br />m-4&nbsp;目检(&nbsp;Visual&nbsp;Inspection)<br /><br />m-5&nbsp;清洗及烘烤(&nbsp;Final&nbsp;Clean&nbsp;&&nbsp;Baking)<br /><br />m-6&nbsp;护铜剂(ENTEK&nbsp;Cu-106A)(OSP)<br /><br />m-7&nbsp;离子残余量测试(Ionic&nbsp;Contamination&nbsp;Test&nbsp;)(Cleanliness&nbsp;Test)<br /><br />m-8&nbsp;冷热冲击试验(Thermal&nbsp;cycling&nbsp;Testing)<br /><br />m-9&nbsp;焊锡性试验(&nbsp;Solderability&nbsp;Testing&nbsp;)<br /><br />N.&nbsp;雷射钻孔(Laser&nbsp;Ablation)<br />N-1&nbsp;雷射钻Tooling孔(Laser&nbsp;ablation&nbsp;Tooling&nbsp;Hole)<br /><br />N-2&nbsp;雷射曝光对位孔(Laser&nbsp;Ablation&nbsp;Registration&nbsp;Hole)<br /><br />N-3&nbsp;雷射Mask制作(Laser&nbsp;Mask)<br /><br />N-4&nbsp;雷射钻孔(Laser&nbsp;Ablation)<br /><br />N-5&nbsp;AOI&nbsp;检查及VRS&nbsp;(&nbsp;AOI&nbsp;Inspection&nbsp;&&nbsp;Verified&nbsp;&&nbsp;Repaired)<br /><br />N-6&nbsp;Blaser&nbsp;AOI&nbsp;(after&nbsp;Desmear&nbsp;and&nbsp;Microetching)<br /><br />N-7&nbsp;除胶渣(Desmear)<br /><br />N-8&nbsp;微蚀(Microetching&nbsp;)<br />
wly120985 发表于 2009-8-20 14:27 | 显示全部楼层
顶,辛苦你了
